How to Mount Wyze Cam Floodlight on a Ceiling or Overhang
If you're looking for a ceiling mount solution for your Wyze Cam Floodlight, we have several options that might interest you:
  • Wyze Cam Floodlight Plug-In Mount: This is an easy, plug-n-play solution that eliminates the need for a junction box. It's compatible with Wyze Floodlights, including Wyze Cam Floodlight v1, v2, and Pro. It features a 20 ft power cord and is outdoor safe, making it a versatile choice for various installations.
  • Wyze Cam Floodlight Pro + Plug-In Mount: This bundle includes both the Wyze Cam Floodlight Pro and a plug-in mount. The Floodlight Pro offers 2.5K QHD resolution, color night vision, and a 180° ultra-wide field of view. It's designed for easy installation without a junction box and is IP65 water-resistant.
  • Wyze Cam Floodlight v2 + Plug-In Mount: This option provides 2.5K QHD resolution and color night vision with a 160° wide field of view. It also includes a plug-in mount for easy installation and is IP65 rated for weather resistance.
  • Wyze Cam Floodlight (v1): Known for its 270° customizable motion detection and 2600 lumens of bright LED light, this model offers two-way audio and color night vision. It's a hardwired solution, ideal for those who prefer a more permanent installation.
  • Wyze Cam Floodlight Pro: With a 180° wide-angle lens and 2.5K QHD video, this model provides detailed surveillance. It features 3000-lumen LED lights and supports both 2.4 GHz and 5 GHz Wi-Fi, offering flexibility in connectivity.
  • Wyze Cam Floodlight v2: This model offers 2800 lumens of LED light, 2K video with color night vision, and a 160° wide-angle view. It includes features like 24/7 local recording and AI-powered light control, making it a comprehensive security solution.
These options provide a range of features and installation methods to suit your needs. Whether you prefer a plug-in or hardwired solution, we have products that can enhance your home security with ease.
What are the features of the Wyze Cam Floodlight Plug-In Mount?Can you tell me more about the installation process for the Wyze Cam Floodlight?Do you have any ongoing sales or promotions for Wyze products?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
