Wyze Cam v4 Event Tagging & Filtering: Effortless Clip Searches with Advanced AI Detection
Wyze Cam v4 Event Tagging and Filtering Options for Easy Clip Searches
When it comes to home security, having a smart camera that not only captures high-quality footage but also helps you quickly find important events is essential. The Wyze Cam v4 and its related bundles offer advanced event tagging and filtering options that make searching through clips effortless. Whether you want to review motion events, person detections, or specific alerts, Wyze’s intelligent system streamlines your security monitoring experience.
Discover Wyze Cam v4: The Ultimate Smart Security Camera
The Wyze Cam v4 is the clearest and most feature-packed Wyze camera to date, designed to keep your home safe with cutting-edge technology.
Key Features for Event Tagging and Filtering
  • 2.5K QHD Resolution: Capture crystal-clear video with vibrant details, making it easier to identify people, packages, or vehicles in your clips.
  • Enhanced Color Night Vision: See full-color footage even in low-light conditions, improving the accuracy of event recognition at night.
  • Motion-Activated Spotlight & Siren: Automatically triggers to deter intruders and highlight events worth reviewing.
  • Person Detection & Smart Focus: With Cam Plus subscription, the camera uses AI to tag clips with person, package, and vehicle detections, allowing you to filter clips by event type.
  • Motion Detection Zones: Customize specific areas to monitor, so you only get alerts and clips for relevant motion events.
  • Smoke & CO Alerts: Receive instant notifications and video clips when smoke or carbon monoxide alarms are detected.
  • Wi-Fi 6 Support: Ensures a stable connection for smooth live streaming and quick clip uploads.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 512GB) lets you review footage anytime without missing a moment.
Event Tagging and Clip Filtering in the Wyze App
Wyze’s app interface organizes your recorded clips by event type, date, and time. With AI-powered tagging, you can:
  • Filter clips by Person, Package, Vehicle, or Sound detection.
  • Search for specific events quickly without scrolling through hours of footage.
  • Use Smart Focus to zoom in on moving objects while keeping the full scene visible.
  • Access Cloud Storage with Cam Plus for unlimited video length and advanced AI detection.
This intelligent event tagging system transforms your Wyze Cam v4 into a proactive security assistant, saving you time and enhancing your peace of mind. Wyze Cam v4 in Home Setting
Wyze Cam v4 Outdoor Bundle: Enhanced Security with Convenience
For those looking to secure outdoor spaces with the same smart features, the Wyze Cam v4 Outdoor Bundle is an excellent choice.
What’s Included?
  • Wyze Cam v4 camera (available in Black, Grey, or White)
  • Wyze Outdoor Power Adapter for reliable outdoor power supply
  • 128GB Wyze MicroSD Card for continuous local recording
Outdoor-Ready Features
  • IP65 Weather Resistance: Designed to withstand rain, snow, and harsh weather conditions.
  • Motion-Activated Spotlight & Siren: Provides extra deterrence for outdoor intruders.
  • Advanced AI Detection: Person, package, and vehicle detection with event tagging for easy clip filtering.
  • Wi-Fi 6 Connectivity: Maintains a strong connection even at greater distances outdoors.
  • Continuous Recording: Local storage with the included 128GB microSD card ensures you never miss an event.
This bundle is perfect for users who want a plug-and-play outdoor security solution with all the smart event tagging and filtering capabilities of the Wyze Cam v4.
Wyze Cam v4 Home Security Bundle: Complete Protection with Expanded Storage
The Wyze Cam v4 Home Security Bundle offers the same powerful camera features with added storage and accessories for comprehensive home monitoring.
Bundle Highlights
  • Wyze Cam v4 with 2.5K QHD resolution and enhanced color night vision
  • 128GB Class 10 UHS-3 microSD card for up to 192 hours of HD video storage locally
  • Improved 2-way audio for clear communication
  • IP65 weather resistance for indoor/outdoor use
  • Motion-activated spotlight and 99dB siren for active deterrence
  • AI-powered person detection and customizable motion zones for precise event tagging
Advanced Clip Management
With this bundle, you can take full advantage of Wyze’s event tagging system to:
  • Quickly filter and search clips by event type (person, package, vehicle)
  • Access continuous 24/7 recordings locally without subscription fees
  • Use Cam Plus subscription for unlimited cloud storage and enhanced AI detection features
This bundle is ideal for users who want a robust security setup with ample local storage and smart event management. Wyze Cam v4 Home Security Lifestyle
Why Choose Wyze Cam v4 for Event Tagging and Filtering?
Wyze Cam v4 stands out in the smart camera market due to its combination of:
  • High-resolution video that captures fine details for better event recognition.
  • AI-powered event tagging that categorizes clips automatically, saving you time.
  • Customizable motion zones to reduce false alerts and focus on what matters.
  • Integration with Alexa, Google Assistant, and IFTTT for seamless smart home control.
  • Flexible storage options including local microSD and cloud with Cam Plus subscription.
  • Reliable wired power with Wi-Fi 6 for consistent performance indoors and outdoors.
These features make it easier than ever to find, review, and respond to important security events captured by your Wyze Cam v4. Wyze Cam v4 Spotlight in Action
Summary
If you’re searching for a smart security camera with advanced event tagging and filtering options, the Wyze Cam v4 and its bundles provide an unbeatable combination of:
  • Crystal-clear 2.5K QHD video with enhanced color night vision
  • AI-driven person, package, and vehicle detection for smart clip tagging
  • Motion detection zones and smoke/CO alerts for precise notifications
  • Continuous local recording with large microSD card support
  • Wi-Fi 6 connectivity for reliable streaming and quick clip access
  • Compatibility with popular smart assistants and automation platforms
Choose the Wyze Cam v4 or one of its bundles to simplify your clip searches and enhance your home security experience.
Products Mentioned
  • Wyze Cam v4
  • Wyze Cam v4 Outdoor Bundle
  • Wyze Cam v4 Home Security Bundle
  • Wyze Cam v4 + FREE 32GB MicroSD Card
Optimize your home security with Wyze Cam v4’s intelligent event tagging and filtering — making clip searches faster, easier, and more effective than ever before.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Color Night VisionYes (Enhanced)Yes (Enhanced)Yes (Enhanced)Yes
Motion-Activated SpotlightYesYesYesYes
SirenYesYesYesYes
Weather ResistanceIP65 (Indoor/Outdoor)IP65 (Outdoor Ready)IP65 (Indoor/Outdoor)IP65
PowerWired (USB cable included)Wired + Outdoor Power Adapter includedWired (USB cable included)Wired (USB cable included)
Included Power AdapterIndoor USB AdapterOutdoor Power Adapter (included)Indoor USB AdapterIndoor USB Adapter
microSD Card IncludedNoYes (128GB)Yes (128GB Class 10 UHS-3)Yes (32GB)
Local RecordingYes (microSD card required)Yes (128GB microSD included)Yes (128GB microSD included)Yes (32GB microSD included)
Cloud Storage (Cam Plus)Optional subscriptionOptional subscriptionOptional subscriptionOptional subscription
AI Event Tagging (Person, Package, Vehicle)Yes (with Cam Plus)Yes (with Cam Plus)Yes (with Cam Plus)Yes (with Cam Plus)
Motion Detection ZonesYesYesYesYes
Wi-Fi Support2.4 GHz + Wi-Fi 62.4 GHz + Wi-Fi 62.4 GHz + Wi-Fi 62.4 GHz + Wi-Fi 6
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Dimensions2in x 2in x 2 3/8in2in x 2in x 2 3/8in2in x 2in x 2 3/8in2in x 2in x 2 3/8in
PriceVaries (from $24.72 to $105.94)$69.99$169.99$35.98
If you would like more help, you can chat with an agent via our Wyze Support chat.
What is event tagging and filtering on the Wyze Cam v4?Event tagging and filtering on the Wyze Cam v4 uses AI to automatically categorize recorded clips by event type, such as person, package, vehicle, or sound detection. This allows users to quickly search and filter through footage in the Wyze app, making it easy to find important security events without scrolling through hours of video.
How does the Wyze Cam v4 help me find specific security events quickly?The Wyze Cam v4 features advanced event tagging and filtering options in the Wyze app. With AI-powered detection, you can filter clips by person, package, vehicle, or sound events, and search by date and time. This streamlines the process of locating specific incidents, saving you time and enhancing your home security monitoring.
What are the key features of the Wyze Cam v4 for home security?The Wyze Cam v4 offers 2.5K QHD resolution for clear video, enhanced color night vision, motion-activated spotlight and siren, person detection, customizable motion detection zones, smoke and CO alert notifications, Wi-Fi 6 support, and 24/7 local recording to a microSD card. These features work together to provide comprehensive and intelligent home security.
Does the Wyze Cam v4 support continuous local recording?Yes, the Wyze Cam v4 supports continuous 24/7 local recording to a microSD card (up to 512GB). This ensures you never miss a moment and can review footage anytime, even without a subscription.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera (available in Black, Grey, or White), a Wyze Outdoor Power Adapter for reliable outdoor power, and a 128GB Wyze MicroSD Card for continuous local recording. The bundle is designed for outdoor use with IP65 weather resistance and advanced AI detection features.
Is the Wyze Cam v4 weather resistant for outdoor use?Yes, the Wyze Cam v4 is IP65 weather resistant, making it suitable for both indoor and outdoor use. It is designed to withstand rain, snow, and harsh weather conditions, especially when used with the Outdoor Bundle.
How does the Wyze Cam v4 Home Security Bundle enhance home monitoring?The Wyze Cam v4 Home Security Bundle includes the Wyze Cam v4, a 128GB Class 10 UHS-3 microSD card for up to 192 hours of HD video storage, improved 2-way audio, IP65 weather resistance, a motion-activated spotlight, a 99dB siren, and AI-powered person detection with customizable motion zones. This bundle provides robust security with ample local storage and smart event management.
What are the benefits of using Cam Plus with Wyze Cam v4?With a Cam Plus subscription, Wyze Cam v4 users gain access to unlimited cloud storage for video clips, advanced AI detection features (including person, package, and vehicle detection), and longer video clip lengths. This enhances the camera’s event tagging and filtering capabilities for more effective security monitoring.
Can I customize motion detection zones on the Wyze Cam v4?Yes, the Wyze Cam v4 allows you to set up customizable motion detection zones. This means you can choose specific areas to monitor, reducing false alerts and ensuring you only receive notifications and clips for relevant motion events.
Is the Wyze Cam v4 compatible with smart home assistants?Yes, the Wyze Cam v4 integrates with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home control and automation.
What storage options are available for Wyze Cam v4 recordings?The Wyze Cam v4 supports both local storage via microSD card (up to 512GB) for continuous 24/7 recording and cloud storage through the Cam Plus subscription for unlimited video clip storage and advanced AI features.
How does the Wyze Cam v4’s enhanced color night vision improve security?The enhanced color night vision on the Wyze Cam v4 allows you to see full-color footage even in low-light conditions. This improves the accuracy of event recognition at night, making it easier to identify people, packages, or vehicles in your clips.
What makes the Wyze Cam v4 a good choice for event tagging and filtering?The Wyze Cam v4 stands out due to its high-resolution video, AI-powered event tagging, customizable motion zones, flexible storage options, reliable Wi-Fi 6 connectivity, and compatibility with smart home platforms. These features make it easy to find, review, and respond to important security events efficiently.
What are the specific features of the Wyze Cam v4 that enhance event tagging and filtering?Can you explain how the AI-powered tagging works for the Wyze Cam v4?Do you have any ongoing sales or discounts for the Wyze Cam v4?
