Is the Wyze Battery Cam Pro Compatible with the Wyze Base Station? Find Out Here!
The Wyze Battery Cam Pro is not compatible with the Wyze Base Station. However, it offers a range of features that make it a versatile and powerful security solution on its own. Here are some key features of the Wyze Battery Cam Pro:
  • 2.5K HDR Video Resolution: Capture clear and detailed footage with high-definition video quality.
  • Wire-Free and No Hub Required: Enjoy the flexibility of a wire-free setup without the need for a hub.
  • Integrated Spotlight & Siren: Enhance security with a built-in spotlight and a 100 dB siren.
  • Radar + PIR Motion Detection: Advanced motion detection technology for accurate alerts.
  • Removable, Rechargeable Battery Packs: Convenient power management with up to 6 months of battery life.
  • IP65 Weatherproof: Designed to withstand various weather conditions, making it suitable for outdoor use.
  • 2.4 & 5Ghz WiFi Support: Reliable connectivity with dual-band WiFi support.
For those looking to extend the battery life of their Wyze Battery Cam Pro, consider the Wyze Battery Cam Solar Panel. It is designed to be weather-resistant and can be mounted anywhere, providing a sustainable power solution. Additionally, the Wyze Outdoor Power Adapter can be used with the Wyze Battery Cam Pro for continuous power supply in outdoor settings.
Feature/SpecificationWyze Battery Cam Pro + Solar PanelWyze Battery Cam Solar PanelWyze Outdoor Power Adapter
Video Resolution2.5K HDRN/AN/A
WiFi Support2.4 & 5 GHzN/AN/A
Weather ResistanceIP65IP65IP67
Battery LifeUp to 6 MonthsExtends Battery LifeN/A
Power SourceRemovable, Rechargeable BatterySolar PowerHardwired
Mounting1/4” - 20 standard360° Freestyle MountN/A
Compatibility
What are the key features of the Wyze Battery Cam Pro?Can the Wyze Battery Cam Pro be used outdoors?Do you have any ongoing sales or promotions for the Wyze Battery Cam Pro?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
