Does Wyze Battery Cam Pro Support Cloud Storage? Find Out Here!
The Wyze Battery Cam Pro is a fantastic choice for those looking to enhance their home security with cloud storage capabilities. Here are some key features of the Wyze Battery Cam Pro that make it a great option:
  • 2.5K HDR Video Resolution: Enjoy crystal-clear video quality, ensuring you don't miss any details.
  • Wire-Free and No Hub Required: Easy to install and set up without the need for additional equipment.
  • Integrated Spotlight & Siren: Provides added security with a built-in spotlight and siren to deter intruders.
  • Radar + PIR Motion Detection: Advanced motion detection technology for accurate alerts.
  • Removable, Rechargeable Battery Packs: Offers convenience with long-lasting battery life and easy recharging.
  • IP65 Weatherproof: Designed to withstand various weather conditions, making it suitable for outdoor use.
  • Cloud Storage with Cam Plus: Record and store your videos in the cloud with a Cam Plus subscription, ensuring you have access to your footage anytime, anywhere.
These features make the Wyze Battery Cam Pro a reliable and versatile option for your security needs.
FeatureWyze Battery Cam Pro + Solar PanelWyze Battery Cam Pro
Video Resolution2.5K HDR2.5K HDR
Power SourceWire-Free, Solar PanelWire-Free
Battery Capacity6200mAh6200mAh
Charging TimeApproximately 9 hoursApproximately 9 hours
Battery LifeUp to 6 MonthsUp to 6 Months
Weather ResistanceIP65IP65
Operating Temperature-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)
Night Vision2 IR LEDs, 2 White LEDs2 IR LEDs, 2 White LEDs
Motion DetectionRadar + PIRRadar + PIR
Connectivity2.4 & 5Ghz WiFi2.4 & 5Ghz WiFi
Local StorageSupports up to 256 GB microSDSupports up to 256 GB microSD
Cloud StorageCam PlusCam Plus
Integrated Spotlight & SirenYesYes
Mounting Methods1/4” - 20 standard, Wall mount included1/4” - 20 standard, Wall mount included
Solar PanelIncludedNot Included
What are the benefits of using cloud storage with the Wyze Battery Cam Pro?Can you explain how the Radar + PIR motion detection works?What is the warranty policy for the Wyze Battery Cam Pro?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
