Wyze Battery Cam Pro Solar Charging: Power with Wyze Solar Panel
Wyze Battery Cam Pro Charging with Wyze Solar Panel
If you're looking to keep your Wyze Battery Cam Pro powered continuously without the hassle of frequent recharging, pairing it with the Wyze Solar Panel is the perfect solution. This combination ensures your security camera stays charged using clean, renewable solar energy, making it ideal for outdoor monitoring with minimal maintenance.
Wyze Battery Cam Pro: Advanced Wireless Security Camera
High-Resolution Video & Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), providing crystal-clear footage day and night. Equipped with a CMOS-Starlight sensor and an F1.6 lens, it captures vibrant, detailed images even in low light. The camera features radar plus PIR motion detection, enhancing accuracy and reducing false alerts.
Long-Lasting Battery & Weatherproof Design
Powered by removable, rechargeable 6200mAh battery packs, the Battery Cam Pro offers up to 6 months of battery life on a single charge. It is IP65 weatherproof rated, making it durable against rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F). This makes it perfect for outdoor use in various climates.
Integrated Spotlight & Siren
For added security, the camera includes a built-in spotlight and a 100 dB siren to deter intruders. Night vision is enhanced with 2 IR LEDs and 2 white LEDs, providing clear color night vision up to a wide field of view (134° diagonal).
Connectivity & Compatibility
The camera supports dual-band Wi-Fi (2.4 GHz and 5 GHz) and Bluetooth 5.1 for easy setup and reliable connection. It integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
Wyze Solar Panel: Continuous Power for Your Battery Cam Pro
Efficient Solar Charging
The Wyze Solar Panel is designed specifically to extend the battery life of your Wyze Battery Cam Pro by harnessing solar energy. With a 2.5W, 5V DC power rating, it provides a steady charge to keep your camera running longer without manual recharging.
Weather-Resistant & Flexible Mounting
Built with an IP65 weatherproof rating, the solar panel withstands outdoor elements such as rain and dust. It features an easy 360° mount, allowing you to position it optimally for maximum sun exposure anywhere around your home or property.
Long Power Cable & Compatibility
The included 13-foot micro USB cable offers flexible installation options, so you can place the panel in the sunniest spot while your camera remains mounted securely. It is compatible with Wyze Battery Cam Pro as well as Wyze Cam Outdoor v1 and v2.
"Record for longer. Attach a solar panel to your Wyze Battery Cam Pro to extend the battery life."
Wyze Battery Cam Pro + Solar Panel Bundle: Ready for Solar-Powered Security
For those who want a complete solar-powered security solution, the Wyze Battery Cam Pro + Solar Panel bundle offers everything you need in one package. This bundle combines the advanced features of the Battery Cam Pro with the convenience of solar charging, ensuring your camera stays powered wire-free and hassle-free.
Key Features of the Bundle
  • 2.5K HDR video with color night vision
  • Radar + PIR motion detection for precise alerts
  • Up to 6 months battery life with solar panel support
  • IP65 weatherproof rating for all-season durability
  • Local and cloud recording options
  • Compatible with Alexa, Google Assistant, and IFTTT
This bundle is perfect for outdoor security in locations where power outlets are unavailable or inconvenient.
Why Choose Solar Charging for Your Wyze Battery Cam Pro?
Using the Wyze Solar Panel with your Battery Cam Pro means:
  • Extended Battery Life: No need to remove and recharge batteries frequently.
  • Eco-Friendly Power: Harness renewable solar energy to reduce electricity use.
  • Convenient Installation: Flexible mounting and long cable length for optimal placement.
  • Reliable Outdoor Performance: Both camera and solar panel are built to withstand harsh weather.
Outdoor Security with Solar Power Image: Wyze Battery Cam Pro mounted outdoors with solar panel charging under sunlight, showcasing a wire-free, eco-friendly security setup.
Summary
The Wyze Battery Cam Pro combined with the Wyze Solar Panel offers a powerful, wireless security solution that keeps your camera charged and ready at all times. Whether purchased separately or as a bundle, this setup is ideal for anyone seeking reliable, long-lasting outdoor surveillance without the hassle of frequent battery changes.
Product Highlights
Wyze Battery Cam Pro 2.5K HDR, wire-free, rechargeable battery, IP65 weatherproof, integrated spotlight & siren, radar + PIR motion detection. Wyze Solar Panel 2.5W solar charging, IP65 weatherproof, 360° mount, 13-foot cable, compatible with Wyze Battery Cam Pro. Wyze Battery Cam Pro + Solar Panel Bundle Complete solar-powered security kit, includes camera and solar panel, optimized for long-term outdoor use.
Enhance your home security with Wyze’s innovative solar charging solution and enjoy peace of mind with continuous, wire-free monitoring.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Solar Panel
TypeCameraCameraAccessory
Video Resolution2560 x 1440 (2.5K)2560 x 1440 (2.5K)N/A
Video EncodingH.264H.264N/A
WirelessYesYesN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery PacksSolar Panel
Battery Capacity6200mAh6200mAhN/A
Battery LifeUp to 6 MonthsUp to 6 MonthsExtends battery life
Charging TimeApproximately 9 hoursApproximately 9 hoursN/A
Weather ResistanceIP65IP65IP65
Operating Temperature-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)N/A
Humidity Tolerance< 90%< 90%N/A
Storage Temperature-40°C to +50°C (-40°F to +122°F)-40°C to +50°C (-40°F to +122°F)N/A
Local Storage SupportUp to 256 GB microSD cardsUp to 256 GB microSD cardsN/A
Cloud StorageNot specifiedRecord to cloud with Cam PlusN/A
Image SensorCMOS-Starlight SensorCMOS-Starlight SensorN/A
Lens ApertureF1.6F1.6N/A
Field of View134° (DFOV), 108° (HFOV), 56° (VFOV)134° (DFOV), 108° (HFOV), 56° (VFOV)N/A
Night Vision2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)N/A
AudioTwo-way Audio with built-in speaker and microphoneTwo-way AudioN/A
MicrophoneMEMS Digital MicMEMS Digital MicN/A
Siren100 dB SPL @ 0.1m100 dB SPL @ 0.1mN/A
CPU Speed500 MHz500 MHzN/A
Memory128 MB RAM128 MB RAMN/A
Mounting Methods1/4” - 20 standard1/4” - 20 standardN/A
Wall Mount IncludedYesYesYes
Wall Mount Dimensions2 in x 2 in x 2.2 in2 in x 2 in x 2.2 inIncluded
Wall Mount Weight1.5 oz (44 g)1.5 oz (44 g)Included
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/A
BluetoothBLE 5.1BLE 5.1N/A
WiFi2.4 GHz and 5 GHz, 802.11a/n/g/b2.4 GHz and 5 GHz, 802.11a/n/g/bN/A
Phone CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+N/A
Color OptionsBlack, WhiteBlack, WhiteWhite frame and mount, Black solar cells
Dimensions2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches173 mm x 120 mm x 17 mm
Weight0.94 lbs0.94 lbsN/A
FinishMatte finishMatte finishN/A
Mechanical StructurePC plasticsPC plasticsN/A
Additional FeaturesIntegrated Spotlight & Siren, Radar + PIR Motion DetectionIntegrated Spotlight, Radar + PIR Motion Detection, Color Night Vision, Local recordingIP65 Weather Resistant, Easy 360° Mount, Run on Sun Power, 13-foot Power Cable
Price$89.98 (1 Pack), $159.98 (1 Pack), $219.98 (2 Pack), $269.94 (2 Pack)$109.98$24.99
Included ItemsCamera, Wall MountCamera, Wall MountSolar panel, Wall mount, Micro USB adapter cable, USB-C adapter cable, Screws, Wall anchors, Quick start guide
How does the Wyze Solar Panel charge the Wyze Battery Cam Pro?The Wyze Solar Panel provides continuous power to the Wyze Battery Cam Pro by harnessing solar energy. With a 2.5W, 5V DC output and a 13-foot micro USB cable, it keeps your camera charged for longer periods, reducing the need for manual battery recharging.
What is the video quality of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features 2.5K HDR video resolution (2560 x 1440), delivering crystal-clear footage both day and night. It also includes color night vision for enhanced clarity in low-light conditions.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65 weatherproof rated, making it resistant to rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F). This ensures reliable outdoor performance in various climates.
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro is powered by removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge. Using the Wyze Solar Panel can further extend the battery life by providing continuous solar charging.
What smart features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro includes radar plus PIR motion detection for accurate alerts, an integrated spotlight, a 100 dB siren, and supports dual-band Wi-Fi (2.4 GHz and 5 GHz) and Bluetooth 5.1. It is compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
Is the Wyze Solar Panel weather-resistant?Yes, the Wyze Solar Panel is IP65 weatherproof rated, making it suitable for outdoor use in various weather conditions, including rain and dust.
Can I use the Wyze Solar Panel with other Wyze cameras?The Wyze Solar Panel is compatible with the Wyze Battery Cam Pro as well as Wyze Cam Outdoor v1 and v2, providing flexible solar charging options for multiple Wyze camera models.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the advanced Battery Cam Pro and the Wyze Solar Panel, offering a complete solar-powered security solution for wire-free, long-lasting outdoor surveillance.
What are the benefits of using solar charging with the Wyze Battery Cam Pro?Solar charging with the Wyze Solar Panel extends the camera's battery life, reduces the need for frequent recharging, provides eco-friendly power, and allows for convenient installation with flexible mounting and a long cable for optimal sun exposure.
How do I install the Wyze Solar Panel for optimal performance?The Wyze Solar Panel features a 360° adjustable mount and a 13-foot cable, allowing you to position it in the sunniest location while keeping your camera securely mounted. This ensures maximum solar exposure and efficient charging.
How does the Wyze Solar Panel connect to the Wyze Battery Cam Pro?What are the installation requirements for the Wyze Solar Panel?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro or solar panel?
