For those interested in wireless outdoor security cameras, we offer a variety of options that cater to different needs and preferences:
Wyze Cam Outdoor v1
- Completely wireless, allowing for flexible placement and easy installation.
- Features include IP65 weather resistance, 1080P livestream & recording, and built-in motion detection technology.
- Night vision capabilities extend up to 25 feet, and the battery life ranges from 3-6 months with normal use.
Wyze Video Doorbell Pro
- Offers a wider view and higher resolution at an affordable price.
- Can be installed in just 30 seconds and supports both wired and wireless battery power options.
- Equipped with 1440x1440p Full HD video resolution and color night vision for enhanced security.
Wyze Battery Cam Pro
- Delivers 2.5K HDR video resolution and operates wire-free, eliminating the need for a hub.
- Comes with an integrated spotlight and siren, along with radar and PIR motion detection.
- Features removable, rechargeable battery packs with a battery life of up to 6 months.
These cameras provide a range of features, from high-resolution video to long-lasting battery life and easy installation, ensuring you find the perfect fit for your security needs.
