Wireless Outdoor Camera Kits with Radar & PIR Motion Detection
Wireless Outdoor Camera Kit with Radar and PIR Motion Detection
When it comes to securing your home or outdoor space, having a reliable wireless outdoor camera kit equipped with advanced motion detection technologies like radar and PIR (Passive Infrared) sensors is essential. These features ensure precise detection of movement, reducing false alarms and enhancing your security system's responsiveness. Wyze offers a range of cutting-edge outdoor cameras and kits that combine wireless convenience, radar and PIR motion detection, and robust weather resistance to keep your property safe around the clock.
Wyze Battery Cam Pro: Wireless Freedom with Radar + PIR Motion Detection
Experience true wireless security with the Wyze Battery Cam Pro, designed for flexible placement without the hassle of wiring.
Key Features:
  • 2.5K HDR Video Resolution: Crystal-clear footage with vibrant colors and sharp details.
  • Radar + PIR Motion Detection: Dual sensor technology detects motion accurately by combining radar sensing with PIR heat detection, minimizing false alerts.
  • Wire-Free Operation: Powered by removable, rechargeable 6200mAh battery packs offering up to 6 months of battery life on a single charge.
  • Integrated Spotlight & Siren: Motion-activated spotlight and a loud 100 dB siren deter intruders effectively.
  • IP65 Weatherproof Rating: Built to withstand rain, snow, and harsh outdoor conditions.
  • Dual-Band WiFi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for reliable streaming.
  • Two-Way Audio: Communicate through the built-in speaker and microphone with noise and echo cancellation.
  • Local Storage: Supports up to 256GB microSD cards for continuous local recording.
This camera is perfect for those seeking a truly wireless, smart outdoor security solution with advanced motion detection technologies.
Wyze Cam v4 Outdoor Bundle: Wired Power with Enhanced Color Night Vision
For users who prefer a wired solution with continuous power and recording, the Wyze Cam v4 Outdoor Bundle offers unmatched clarity and smart features.
Highlights:
  • 2.5K Quad HD Resolution: Capture stunningly detailed video with vibrant colors, even at night.
  • Enhanced Color Night Vision: See beyond traditional black-and-white night vision with enhanced hardware that reveals rich colors in low light.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, improving visibility and security.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection at greater distances (requires Wi-Fi 6 router).
  • 24/7 Local Recording: Continuous event capture with a built-in microSD card slot (128GB included in bundle).
  • Compatibility: Works with Alexa and Google Assistant for voice control and smart home integration.
  • Requires Wyze Outdoor Power Adapter: Ensures safe and reliable outdoor power supply.
This bundle is ideal for homeowners wanting a wired outdoor camera with superior image quality and smart detection features.
Wyze Cam Pan v3: 360° Coverage with IP65 Weather Resistance
Cover every angle with the Wyze Cam Pan v3, a versatile indoor/outdoor camera featuring pan and tilt capabilities.
Features:
  • 360° Horizontal & 180° Vertical View Range: Pan and tilt your camera remotely to monitor wide areas without blind spots.
  • 1080p Full HD Video: Clear and smooth video streaming with 4 IR LEDs for night vision.
  • IP65 Weatherproof: Durable for outdoor use in rain or snow (requires Wyze Outdoor Power Adapter).
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Magnetic Mounting: Easy installation with a screw-free magnetic base.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
  • Motion Alerts: Receive push notifications when motion is detected.
Perfect for users who want flexible, wide-area coverage with pan-tilt control and reliable weather resistance.
Why Choose Wyze for Your Outdoor Security?
"Wyze cameras combine advanced motion detection technologies like radar and PIR sensors with high-resolution video and smart home compatibility, providing comprehensive outdoor security solutions."
  • Advanced Motion Detection: Radar + PIR sensors reduce false alarms by detecting both heat signatures and movement.
  • Weather-Resistant Designs: IP65-rated cameras withstand rain, snow, and extreme temperatures.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice commands and automation.
  • Flexible Power Options: Choose between wired continuous power or wireless battery operation.
  • Local and Cloud Storage: Options for continuous local recording and cloud event storage with subscription plans.
Enhance Your Security Setup with Wyze Kits
For a complete security solution, consider Wyze's bundled kits that combine cameras with additional accessories like floodlights and video doorbells, providing layered protection for your home.
Outdoor Security Camera in Snowy Yard Wyze Cam Pan v3 providing weather-resistant outdoor security in snowy conditions Two-Way Audio Communication Communicate clearly with two-way audio on Wyze outdoor cameras
Summary of Wireless Outdoor Cameras with Radar and PIR Motion Detection
Product NameWirelessRadar + PIR Motion DetectionVideo ResolutionPower SourceWeather ResistanceSpecial Features
Wyze Battery Cam ProYesYes2.5K HDRRechargeable Battery PacksIP65Spotlight, Siren, Dual-Band WiFi
Wyze Cam v4 OutdoorNoPIR (Motion Detection)2.5K QHDWired (Outdoor Power Adapter)IP65Enhanced Color Night Vision, Wi-Fi 6
Wyze Cam Pan v3NoPIR (Motion Detection)1080p HDWired (Outdoor Power Adapter)IP65360° Pan & Tilt, Magnetic Mount
Secure your outdoor spaces with Wyze’s advanced wireless outdoor camera kits featuring radar and PIR motion detection. Whether you prefer wireless freedom or wired reliability, Wyze has the perfect solution to keep your home safe day and night.
FeatureWyze Battery Cam ProWyze Cam v4 Outdoor BundleWyze Cam v4Wyze Cam Pan v3
Video Resolution2.5K HDR (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)1080p (1920x1080)
Color OptionsBlack, WhiteBlack, Grey, WhiteBlack, Clear, Grey, WhiteBlack, White
Power SourceBattery (removable, rechargeable), Solar panel optionWired with Outdoor Power Adapter includedWired (requires Outdoor Power Adapter for outdoor use)Wired (requires Outdoor Power Adapter for outdoor use)
Wireless Connectivity2.4 & 5 GHz Wi-FiWi-Fi 62.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi only
Weather ResistanceIP65IP65IP65IP65
Night Vision2.5K HDR, Color Night Vision, Integrated Spotlight (150 lumens)Enhanced Color Night Vision, Motion-activated spotlightColor Night Vision, 4 IR LEDs + 2 white spotlight LEDs (72 lumens)4 IR LEDs (850 nm)
Field of View (FOV)Not specifiedNot specifiedDFOV 115.8°, HFOV 98.5°, VFOV 53.1°120° FOV
Motion DetectionRadar + PIR Motion Detection, Custom zonesMotion and Sound Detection, Motion zonesMotion Detection, Motion zonesMotion Detection
AudioTwo-way audio, built-in sirenTwo-way audioTwo-way audio, built-in sirenTwo-way audio, built-in siren
Local StoragemicroSD card (optional)128GB microSD card includedmicroSD card up to 512GB (required)Supports up to 256GB microSD
Cloud StorageCam Plus subscription availableCam Plus subscription availableCam Plus subscription availableCam Plus subscription available
DimensionsNot specifiedNot specified2in x 2in x 2 3/8in124mm x 60mm x 63mm
WeightNot specifiedNot specified0.49 lb (222 g)11.29 oz (320 g)
Mounting OptionsFlexible, includes ceiling mount optionNot specifiedStand, Wall mount, Ceiling mount, Magnetic mountScrew mount (1/4" - 20), circular base
Special FeaturesRemovable battery packs, Solar panel compatible, Bird DetectionWi-Fi 6 support, Smoke & CO alertsWi-Fi 6 support, Smoke & CO alerts360° pan, 180° tilt, redesigned for indoor/outdoor
Price Range$89.98 (1 pack) to $219.98 (3 pack)$69.99 (bundle)$35.98 - $107.94 (varies by pack/color)$39.98 (1 pack)
What is radar and PIR motion detection in Wyze outdoor cameras?Radar and PIR (Passive Infrared) motion detection are advanced technologies used in Wyze outdoor cameras to accurately detect movement. Radar senses motion by detecting changes in radio waves, while PIR detects heat signatures from people or animals. Combining both reduces false alarms and ensures precise motion alerts.
Which Wyze outdoor camera offers true wireless operation?The Wyze Battery Cam Pro offers true wireless operation, powered by removable, rechargeable battery packs that can last up to 6 months on a single charge. This allows for flexible placement without the need for wiring.
Are Wyze outdoor cameras weatherproof?Yes, Wyze outdoor cameras such as the Wyze Battery Cam Pro, Wyze Cam v4 Outdoor, and Wyze Cam Pan v3 are IP65 weatherproof. This means they are designed to withstand rain, snow, and harsh outdoor conditions, making them suitable for year-round outdoor use.
What video resolution do Wyze outdoor cameras provide?Wyze outdoor cameras offer high-definition video quality. The Wyze Battery Cam Pro and Wyze Cam v4 Outdoor provide 2.5K HDR and 2.5K Quad HD resolution respectively, while the Wyze Cam Pan v3 delivers 1080p Full HD video.
Can Wyze outdoor cameras record continuously?Yes, Wyze outdoor cameras support continuous local recording. The Wyze Cam v4 Outdoor bundle includes a 128GB microSD card for 24/7 recording, and the Wyze Battery Cam Pro supports up to 256GB microSD cards for continuous local storage.
Do Wyze outdoor cameras have night vision?Yes, Wyze outdoor cameras feature night vision capabilities. The Wyze Cam v4 Outdoor offers enhanced color night vision, allowing you to see rich colors even in low light, while the Wyze Cam Pan v3 uses infrared LEDs for clear night vision.
Are Wyze outdoor cameras compatible with smart home systems?Yes, Wyze outdoor cameras are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT. This allows for voice control and integration with other smart home devices.
What are the power options for Wyze outdoor cameras?Wyze offers both wireless and wired power options for outdoor cameras. The Wyze Battery Cam Pro operates on rechargeable battery packs, while the Wyze Cam v4 Outdoor and Wyze Cam Pan v3 require a Wyze Outdoor Power Adapter for continuous wired power.
How does two-way audio work on Wyze outdoor cameras?Wyze outdoor cameras are equipped with built-in speakers and microphones, allowing you to communicate with visitors or deter intruders in real time. The two-way audio feature includes noise and echo cancellation for clear conversations.
What is included in Wyze outdoor camera kits?Wyze outdoor camera kits may include cameras, power adapters, microSD cards for local storage, and additional accessories such as spotlights or sirens. Some bundles also offer floodlights or video doorbells for enhanced security coverage.
What makes Wyze outdoor cameras a good choice for home security?Wyze outdoor cameras combine advanced motion detection (radar and PIR sensors), high-resolution video, weather-resistant designs, flexible power options, and smart home integration. These features provide comprehensive and reliable outdoor security solutions for any home.
What are the key features of the Wyze Battery Cam Pro?Can you tell me more about the Wyze Cam v4 Outdoor Bundle?Are there any ongoing sales or discounts for Wyze products?
