Wireless Battery Outdoor Cameras with PIR and Radar Motion Detection
When it comes to securing your outdoor spaces, having a reliable wireless battery camera equipped with advanced motion detection technologies is essential. For those seeking top-tier outdoor security, Wyze offers innovative solutions that combine PIR (Passive Infrared) and radar motion detection to provide precise, early alerts and comprehensive monitoring without the hassle of wires or hubs.
Wyze Battery Cam Pro: Advanced Wireless Outdoor Security
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers crystal-clear 2.5K HDR video resolution, ensuring every detail is captured with vibrant colors and balanced lighting. Whether it's day or night, this camera’s color night vision lets you see more clearly in low-light conditions.
Dual Motion Detection: Radar + PIR
This camera features a powerful combination of radar and PIR sensors, doubling the accuracy of motion detection. This means earlier alerts and fewer false alarms, as the camera intelligently distinguishes between different types of movement. Customize detection zones through the Wyze app for tailored security coverage.
Wire-Free and Weatherproof
Designed for true outdoor freedom, the Wyze Battery Cam Pro requires no wires or hubs. Its IP65 weatherproof rating means it can withstand rain, dust, and extreme conditions, making it perfect for any outdoor environment.
Flexible Power Options
The camera runs on removable, rechargeable battery packs, allowing you to hot-swap batteries without downtime. For extended use, you can add the Wyze Solar Panel accessory to convert sunlight into power, reducing the need for frequent recharging.
Integrated Spotlight and Siren
Enhance your security with a built-in 150-lumen spotlight and siren. The spotlight activates automatically with motion or can be manually controlled via the app, deterring intruders and illuminating your property.
Connectivity and Setup
Supports both 2.4 GHz and 5 GHz WiFi networks for faster, more reliable connections. Setup is quick and easy with Bluetooth, eliminating the need for QR code scanning.
"Protect anywhere. See everything in 2.5K HDR. No power outlet or electrician needed."
Alt text: Wyze Battery Cam Pro mounted outdoors with spotlight at dusk
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Ultimate Security
All the Features of Wyze Battery Cam Pro
This bundle includes the Wyze Battery Cam Pro with all its advanced features: 2.5K HDR video, radar + PIR motion detection, integrated spotlight and siren, and IP65 weatherproofing.
Solar-Powered Convenience
The included Wyze Solar Panel converts sunlight into energy, providing continuous power to your camera. This means less frequent battery charging and uninterrupted security coverage, ideal for remote or hard-to-reach locations.
Easy Installation and Weather Resistance
The solar panel is designed to be weather resistant (IP65) and mountable anywhere outdoors. It comes with a 13-foot power cable for flexible placement to maximize sun exposure.
"Turn this wireless cam into a solar security cam by adding a Wyze Solar Panel."
Wyze Battery Cam Solar Panel Accessory: Extend Your Camera’s Battery Life
Designed for Wyze Battery Cam Pro
This accessory is perfect for those who already own the Wyze Battery Cam Pro and want to extend its battery life with solar power.
Weatherproof and Flexible Mounting
Rated IP65 for weather resistance, the solar panel can be mounted on walls, poles, or other outdoor surfaces with a 360° adjustable mount to capture optimal sunlight.
Complete Installation Kit
Includes the solar panel, wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide for hassle-free setup.
"Record for longer. Attach a solar panel to your Wyze Battery Cam Pro to extend the battery life."
Why Choose Wyze Wireless Battery Outdoor Cameras?
- No Wires, No Hubs: True wireless freedom means easy installation anywhere outdoors without complicated wiring or additional hubs.
- Dual Motion Detection: Radar + PIR sensors provide superior motion detection accuracy, reducing false alerts.
- High-Resolution Video: 2.5K HDR and color night vision ensure clear, detailed footage day and night.
- Weatherproof Durability: IP65 rating protects your camera and accessories from rain, dust, and harsh weather.
- Flexible Power Solutions: Rechargeable batteries with hot-swap capability and optional solar panels for continuous power.
- Integrated Security Features: Built-in spotlight and siren enhance deterrence and visibility.
- Smart App Control: Customize detection zones, control spotlight, and receive instant alerts via the Wyze app.
Conclusion
For outdoor security that combines cutting-edge motion detection with flexible, wire-free installation, the Wyze Battery Cam Pro and its solar-powered variants stand out as top choices. Whether you want a standalone wireless camera or a solar-powered system for extended monitoring, Wyze offers reliable, weatherproof solutions that keep your property safe and visible around the clock.
What is the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro is a wireless, battery-powered outdoor security camera that features advanced motion detection using both radar and PIR (Passive Infrared) sensors. It offers 2.5K HDR video quality, color night vision, and is designed for easy, wire-free installation in any outdoor environment.How does dual motion detection work on the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro uses a combination of radar and PIR (Passive Infrared) sensors for motion detection. This dual system increases accuracy, providing earlier alerts and reducing false alarms by intelligently distinguishing between different types of movement.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is rated IP65 for weather resistance, making it suitable for outdoor use in rain, dust, and extreme weather conditions.What video quality does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, ensuring clear, detailed footage with vibrant colors and balanced lighting, both day and night.Does the Wyze Battery Cam Pro have night vision?
Yes, the Wyze Battery Cam Pro features color night vision, allowing you to see more clearly in low-light conditions.How is the Wyze Battery Cam Pro powered?
The camera runs on removable, rechargeable battery packs that can be hot-swapped for continuous operation. For extended use, you can add the Wyze Solar Panel accessory to convert sunlight into power, reducing the need for frequent recharging.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The bundle includes the Wyze Battery Cam Pro with all its advanced features, plus a Wyze Solar Panel for continuous, solar-powered operation. The solar panel comes with a 13-foot power cable for flexible placement and is weather resistant (IP65).Can I add a solar panel to my existing Wyze Battery Cam Pro?
Yes, the Wyze Battery Cam Solar Panel Accessory is designed specifically for the Wyze Battery Cam Pro. It extends your camera’s battery life by converting sunlight into energy and includes all necessary mounting hardware and adapter cables.How easy is it to install the Wyze Battery Cam Pro and Solar Panel?
Both the Wyze Battery Cam Pro and the Solar Panel are designed for easy, wire-free installation. The camera supports Bluetooth setup for quick connection, and the solar panel includes a 360° adjustable mount and a complete installation kit for flexible outdoor placement.What security features are integrated into the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro includes a built-in 150-lumen spotlight and a siren. The spotlight can be triggered automatically by motion or controlled manually via the Wyze app, helping to deter intruders and illuminate your property.Does the Wyze Battery Cam Pro support both 2.4 GHz and 5 GHz WiFi?
Yes, the Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi networks, ensuring faster and more reliable wireless connections.Can I customize motion detection zones with the Wyze Battery Cam Pro?
Yes, you can customize detection zones through the Wyze app, allowing you to tailor security coverage to specific areas and reduce unwanted alerts.What are the main benefits of choosing Wyze wireless battery outdoor cameras?
Wyze wireless battery outdoor cameras offer true wire-free installation, advanced dual motion detection (radar + PIR), high-resolution 2.5K HDR video, color night vision, weatherproof durability, flexible power options (rechargeable batteries and solar panels), integrated spotlight and siren, and smart app control for customized security.
