Where to Buy Wyze Secure Entry Doorbell and Smart Lock Bundle
If you're looking to upgrade your home security with a smart, connected entry system, the
Wyze Secure Entry Doorbell and Smart Lock Bundle is an excellent choice. This bundle combines the convenience of a high-definition video doorbell with the advanced security features of a smart lock, all manageable through the Wyze app. Below, we explore the key products in this bundle and why they are the perfect solution for your front porch security needs.
The Front Porch Security Bundle: Complete Smart Home Access
Overview of the Bundle
The
Front Porch Security Bundle is designed to provide comprehensive control and monitoring of your home's entry points. It includes:
- Wyze Video Doorbell and Chime: See and speak to visitors in crisp 1080p HD with two-way audio.
- Wyze Lock: Lock and unlock your door remotely, monitor lock history, and manage access with ease.
This bundle integrates seamlessly with Alexa and Google Assistant, allowing voice control and smart home automation.
Key Features
- 1080p HD Video Doorbell with night vision and a wide 120° vertical by 88° horizontal field of view.
- Two-way Audio for real-time communication with visitors.
- Remote Lock/Unlock via the Wyze app.
- Motion Detection and event history for both doorbell and lock.
- Weather-resistant design for outdoor durability (IP65 rating for doorbell).
- Multiple chime sounds to customize your alert preferences.
The bundle is priced competitively, offering great value for a full smart entry system.
Secure your front door with Wyze smart lock and video doorbell
Wyze Lock Bolt: The Smart Lock That Replaces Your Deadbolt
Advanced Security and Convenience
The
Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your existing deadbolt. It offers a sleek, modern design with a backlit keypad and an ultra-fast fingerprint sensor for quick access.
Specifications and Features
- Ultra-Fast Fingerprint Sensor: Unlock your door in less than a second with a simple touch.
- Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light.
- Auto-Lock Function: Automatically locks your door if you forget.
- Lock and Unlock History: Track access events directly in the Wyze app.
- Built-in Alarm: Detects jam attempts and alerts you immediately.
- Emergency One-Time Codes: Provide temporary access to guests or service personnel.
- Bluetooth 5.0 Communication with a 16 ft range.
- Weather Resistance: Rated IPX5, suitable for various climates.
- Battery Life: Powered by 4 AA batteries lasting 10-12 months.
Installation and Compatibility
- Fits standard door thicknesses from 1-3/8" to 1-3/4".
- Compatible with backset sizes 2-3/8" and 2-3/4".
- Available in Matte Black and Satin Nickel finishes to match your door hardware.
Wyze Lock Bolt with fingerprint sensor and backlit keypad
Additional Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning smoothly, Wyze offers several replacement parts:
- Wyze Lock Replacement Part Kit: Includes essential components compatible only with Wyze Lock.
- Wyze Lock Bolt Screws: Replacement screws set for secure installation.
- Wyze Lock Bolt Interior Assembly Battery Cover: Replacement cover for the battery compartment.
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly firmly to your door.
These parts ensure your smart lock remains reliable and easy to maintain.
Why Choose the Wyze Secure Entry Bundle?
"The Wyze Secure Entry Doorbell and Smart Lock Bundle offers a seamless, smart home security solution that combines convenience, safety, and modern technology — all at an affordable price."
- Integrated Control: Manage your doorbell and lock from a single app.
- Enhanced Security: Real-time alerts and history logs keep you informed.
- Easy Installation: Designed for DIY installation with standard door compatibility.
- Smart Home Compatibility: Works with Alexa and Google Assistant for voice commands.
- Weather-Resistant and Durable: Built to withstand outdoor conditions.
Summary
The Wyze Secure Entry Doorbell and Smart Lock Bundle is your all-in-one solution for smart home access management. Whether you want to see who's at your door, communicate remotely, or unlock your door with a fingerprint or app, this bundle has you covered.
Upgrade your home security today with Wyze's trusted technology and enjoy peace of mind knowing your front porch is protected.
### Product Tags and Highlights
Where can I buy the Wyze Secure Entry Doorbell and Smart Lock Bundle?
You can purchase the Wyze Secure Entry Doorbell and Smart Lock Bundle directly from the official Wyze website. This bundle is designed to provide comprehensive front porch security and is available for online order.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes the Wyze Video Doorbell and Chime, as well as the Wyze Lock. This combination allows you to see and speak to visitors in 1080p HD, remotely lock and unlock your door, and manage everything through the Wyze app.What are the key features of the Wyze Video Doorbell?
The Wyze Video Doorbell features 1080p HD video with night vision, a wide 120° vertical by 88° horizontal field of view, two-way audio for real-time communication, motion detection, event history, and a weather-resistant IP65 rating. It also offers multiple chime sounds for customizable alerts.How does the Wyze Lock work with the Wyze app?
The Wyze Lock can be controlled remotely via the Wyze app, allowing you to lock and unlock your door, monitor lock history, and manage access from anywhere. The app also provides real-time alerts and integrates with Alexa and Google Assistant for voice control.Is the Wyze Secure Entry Bundle compatible with smart home systems?
Yes, the Wyze Secure Entry Bundle is compatible with popular smart home systems, including Amazon Alexa and Google Assistant. This allows you to control your doorbell and lock using voice commands and integrate them into your smart home routines.What is the Wyze Lock Bolt and how does it enhance security?
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your existing deadbolt. It features an ultra-fast fingerprint sensor, a backlit keypad with anti-peep technology, auto-lock function, lock and unlock history, a built-in alarm for jam attempts, and emergency one-time codes for guest access.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy DIY installation and fits standard door thicknesses from 1-3/8" to 1-3/4" with backset sizes of 2-3/8" and 2-3/4". It comes in Matte Black and Satin Nickel finishes to match your door hardware.Are replacement parts available for the Wyze Lock Bolt?
Yes, Wyze offers several replacement parts for the Lock Bolt, including a replacement part kit, screws, interior assembly battery cover, and interior assembly metal plate. These parts help maintain the reliability and longevity of your smart lock.How long does the battery last on the Wyze Lock Bolt?
The Wyze Lock Bolt is powered by 4 AA batteries, which typically last between 10 to 12 months depending on usage.Why should I choose the Wyze Secure Entry Doorbell and Smart Lock Bundle for my home?
The Wyze Secure Entry Doorbell and Smart Lock Bundle offers integrated control through a single app, enhanced security with real-time alerts and history logs, easy DIY installation, compatibility with Alexa and Google Assistant, and weather-resistant durability—all at an affordable price.
