Buy Replacement Micro USB Adapter for Wyze Cam v3 Pro Online
If you are looking for a replacement micro USB adapter for your Wyze Cam v3 Pro, it’s important to understand the compatible power options and accessories designed specifically for this model. The Wyze Cam v3 Pro uses a micro USB port for power, and while the camera itself is sold with a power adapter, replacement adapters or alternative power solutions can be found within Wyze’s accessory lineup. Below, we explore the Wyze Cam v3 Pro and compatible accessories that can serve as replacement power sources or enhance your camera’s setup.
Wyze Cam v3 Pro: Features and Power Requirements
The Wyze Cam v3 Pro is the advanced version of Wyze’s best-selling camera, offering:
  • 2.5K resolution (2560x1440) for crystal-clear video quality.
  • Built-in spotlight and integrated siren for enhanced security.
  • Edge AI for smart detection and alerts.
  • Color Night Vision with 4 IR LEDs.
  • Weatherproof IP65 rating for indoor and outdoor use.
  • Micro USB power port with a power adapter input of 110-240V AC/DC and output of 5V/2000mA.
  • 6ft (1.8m) power cable included with the original adapter.
For safe outdoor use, the Wyze Cam v3 Pro requires the Wyze Outdoor Power Adapter v2, which is sold separately.
This camera supports mounting via magnetic, screw, or tape methods, making it versatile for various installation needs. Wyze Cam v3 Pro lifestyle image showing two-way audio interaction Experience seamless two-way audio with Wyze Cam v3 Pro
Compatible Power Accessories for Wyze Cam v3 Pro
Wyze Cam v4 + Lamp Socket v2 Bundle
This innovative bundle includes a lamp socket that allows you to power your Wyze Cam v3 Pro (as well as other Wyze cameras like v3, v4, OG, and Pan v3) directly from a light socket without needing a traditional outlet or micro USB adapter.
  • Device Compatibility: Wyze Cam v3, v3 Pro, v4, OG, Pan v3.
  • Power Input: 120V~, 60Hz.
  • Socket Connector Type: E26.
  • Max Lamp Power: 20W (recommended CFL or LED bulbs).
  • Features: Motion-activated lights, dusk to dawn scheduling, and linkability with other Wyze devices.
  • Connectivity: 2.4 GHz Wi-Fi and Bluetooth.
  • Operating Temperature: -4°F to 120°F (-20°C to 50°C).
  • Warranty: 1 year.
This solution is perfect if you want to avoid replacing the micro USB adapter and instead power your camera through existing lighting fixtures.
Pan v3 + Lamp Socket v2 Bundle
Similar to the above, this bundle powers the Wyze Cam v3 Pro and other compatible cameras via a lamp socket, providing a convenient alternative to the micro USB adapter.
  • Same specs and features as the Cam v4 + Lamp Socket v2 Bundle.
  • Available in Black or White to match your home decor.
Refurbished Wyze Cam v3 Pro: Affordable Replacement Option
If you are considering a full replacement rather than just the adapter, the Refurbished Wyze Cam v3 Pro offers a like-new camera at a reduced price. It includes all the features of the new v3 Pro model and comes with a micro USB port and power adapter.
  • Price: More affordable than new.
  • Warranty: 1 year.
  • Features: Same 2.5K resolution, built-in spotlight, integrated siren, Edge AI, and IP65 rating.
  • Power: Comes with a micro USB power adapter compatible with the camera.
This is a great option if your current camera or adapter is beyond repair. Wyze Cam v3 Pro lifestyle image showing child playing guitar near camera Wyze Cam v3 Pro captures every moment with clarity
Summary: Where to Get Replacement Micro USB Adapters for Wyze Cam v3 Pro
  • Original Replacement Adapter: Wyze sells the Outdoor Power Adapter v2 separately, which is compatible with the v3 Pro for outdoor use.
  • Alternative Power Solution: Use the Wyze Cam v4 + Lamp Socket v2 Bundle or Pan v3 + Lamp Socket v2 Bundle to power your camera via a lamp socket, eliminating the need for a micro USB adapter.
  • Full Camera Replacement: Consider the Refurbished Wyze Cam v3 Pro if you want a complete replacement with a new micro USB adapter included.
By choosing any of these options, you ensure your Wyze Cam v3 Pro stays powered and functional, maintaining your home’s security and monitoring capabilities. Wyze Cam v3 Pro lifestyle image showing baby monitor use Wyze Cam v3 Pro: versatile for home security and baby monitoring
Final Tips
  • Always use Wyze-approved power adapters or accessories to avoid damage.
  • Check the power output specifications: 5V/2000mA for the Wyze Cam v3 Pro.
  • For outdoor installations, ensure you use weatherproof adapters like the Wyze Outdoor Power Adapter v2.
  • Consider lamp socket bundles for convenient and smart power solutions.
Keep your Wyze Cam v3 Pro running smoothly with the right replacement micro USB adapter or power accessory tailored to your needs.
# Product Tags Summary
FeatureWyze Cam v3 ProCam v4 + Lamp Socket v2 BundlePan v3 + Lamp Socket v2 Bundle(Refurbished) Wyze Cam v3 Pro
TypeCameraBundle (Cam v4 + Lamp Socket v2)Bundle (Pan v3 + Lamp Socket v2)Refurbished Camera
Resolution2.5K (2560x1440)Cam v4: 2.5K QHDPan v3: 1080p (1920x1080)2.5K (2560x1440)
SpotlightBuilt-in, motion-activated, 70 lumensCam v4: motion-activated spotlightNo spotlightBuilt-in, motion-activated, 70 lumens
SirenIntegrated 89 dB user-activated sirenNot includedNot includedIntegrated 89 dB user-activated siren
AI FeaturesEdge AI with free person detectionNot specifiedNot specifiedEdge AI with free person detection
Night VisionColor Night VisionEnhanced Color Night VisionIR Night Vision (4 IR LEDs 850 nm)Color Night Vision
AudioTwo-way audioNot specifiedTwo-way audioTwo-way audio
Weather ResistanceIP65 (with Outdoor Power Adapter v2)Lamp Socket: Not weatherproof, suitable for damp locationsLamp Socket: Not weatherproof, suitable for damp locationsIP65 (with Outdoor Power Adapter v2)
Outdoor UseYes, requires Wyze Outdoor Power Adapter v2 (sold separately)Cam v4: Yes (included Outdoor Power Adapter in bundle)Pan v3: Yes, requires Outdoor Power Adapter (sold separately)Yes, requires Wyze Outdoor Power Adapter v2 (sold separately)
Power SourceWiredLamp Socket powers Cam v4 without outletLamp Socket powers Pan v3 without outletWired
StoragemicroSD card slot (up to 128 GB recommended)microSD card slot (up to 512 GB supported)microSD card slot (up to 256 GB supported)microSD card slot (up to 128 GB recommended)
Connectivity2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Bluetooth2.4 GHz Wi-Fi, Bluetooth2.4 GHz Wi-Fi
App FeaturesRedesigned Wyze app, Smart Focus, Customized Detection ZonesNot specifiedNot specifiedRedesigned Wyze app, Smart Focus, Customized Detection Zones
CompatibilityWorks with Alexa and Google AssistantCompatible with Android 7.0+ and iOS 12.0+Compatible with Android 7.0+ and iOS 12.0+Works with Alexa and Google Assistant
Dimensions (Camera)Not specifiedLamp Socket: 56.5mm x 56.5mm x 65mmLamp Socket: 56.5mm x 56.5mm x 65mmNot specified
Weight (Camera)Not specifiedLamp Socket: 80 gLamp Socket: 80 gNot specified
Price (Single Unit)$34.98 (sold out)Cam v4: $49.96 (bundle price)Pan v3: $53.96 (bundle price)$24.98 (sold out)
Warranty1 Year1 Year1 Year1 Year
Additional NotesRequires Outdoor Power Adapter v2 sold separatelyLamp Socket: Use CFL or LED bulbs under 20W; not weatherproofLamp Socket: Use CFL or LED bulbs under 20W; not weatherproofFinal sale, Wyze decision, like new condition
What type of power adapter does the Wyze Cam v3 Pro use?The Wyze Cam v3 Pro uses a micro USB power adapter with an input of 110-240V AC/DC and an output of 5V/2000mA. The original camera comes with a 6ft (1.8m) power cable and adapter.
Where can I buy a replacement micro USB adapter for Wyze Cam v3 Pro?You can purchase a replacement micro USB adapter for the Wyze Cam v3 Pro directly from Wyze. For outdoor use, Wyze recommends the Outdoor Power Adapter v2, which is sold separately and is weatherproof.
Are there alternative ways to power the Wyze Cam v3 Pro without a micro USB adapter?Yes, you can use the Wyze Cam v4 + Lamp Socket v2 Bundle or the Pan v3 + Lamp Socket v2 Bundle to power your Wyze Cam v3 Pro directly from a light socket, eliminating the need for a traditional micro USB adapter.
Is the Wyze Outdoor Power Adapter v2 compatible with the Wyze Cam v3 Pro?Yes, the Wyze Outdoor Power Adapter v2 is compatible with the Wyze Cam v3 Pro and is recommended for safe outdoor installations due to its weatherproof design.
Can I use third-party power adapters with the Wyze Cam v3 Pro?It is recommended to use only Wyze-approved power adapters or accessories to avoid potential damage to your Wyze Cam v3 Pro. Always check that the power output matches 5V/2000mA.
What are the benefits of using the Lamp Socket v2 Bundle with Wyze Cam v3 Pro?The Lamp Socket v2 Bundle allows you to power your Wyze Cam v3 Pro through a standard E26 light socket, offering features like motion-activated lights, dusk to dawn scheduling, and easy installation without the need for a traditional outlet or micro USB adapter.
Does the refurbished Wyze Cam v3 Pro come with a power adapter?Yes, the refurbished Wyze Cam v3 Pro includes a micro USB power adapter and offers all the features of the new model at a more affordable price, along with a 1-year warranty.
What should I consider when choosing a replacement power adapter for Wyze Cam v3 Pro?Ensure the replacement adapter provides an output of 5V/2000mA and is approved by Wyze. For outdoor use, select a weatherproof adapter like the Wyze Outdoor Power Adapter v2.
Can the Wyze Cam v3 Pro be powered by a lamp socket?Yes, with the Wyze Cam v4 + Lamp Socket v2 Bundle or Pan v3 + Lamp Socket v2 Bundle, you can power the Wyze Cam v3 Pro directly from a lamp socket, making installation more flexible and convenient.
What is included with the original Wyze Cam v3 Pro purchase?The original Wyze Cam v3 Pro comes with a micro USB power adapter, a 6ft (1.8m) power cable, and mounting accessories for magnetic, screw, or tape installation.
What are the power requirements for the Wyze Cam v3 Pro?Can you tell me more about the features of the Wyze Cam v3 Pro?What is the warranty policy for the Wyze Cam v3 Pro?
