Weatherproof Bird Feeder with Wyze Battery Cam Pro and Optional Solar Panel
Experience birdwatching like never before with a seamless combination of Wyze’s weatherproof bird feeder, the advanced Wyze Battery Cam Pro, and the optional Wyze Solar Panel. This setup is designed for bird lovers who want to enjoy live streaming and recording of feathered visitors in any weather, with minimal maintenance and maximum convenience.
Wyze Bird Feeder: Durable and Designed to Attract
Weather-Resistant Construction for All Seasons
The Wyze Bird Feeder is crafted from durable polycarbonate material, built to withstand rain, wind, and sun with an IP65 weatherproof rating. Whether it’s a chilly winter morning or a hot summer afternoon, this feeder remains a safe and inviting spot for birds to gather.
- Dimensions: 7.48 in x 10.12 in x 8.58 in (190mm x 257mm x 218mm)
- Weight: 2.5 lb (net), 3.42 lb (gross)
- Bird Seed Capacity: 1 Liter
- Operating Temperature: -4°F to 122°F (-20°C to 50°C)
- Humidity Tolerance: < 90%
Vibrant Design and Easy Installation
Featuring a vibrant blue body with an orange top, the feeder is visually attractive to a variety of bird species. Installation is flexible with five mounting options including wall, tree, pole, cord, and suction cup mounts, allowing you to place it wherever birds frequent most.
Camera Compatibility and Macro Lens Adapter
The feeder supports multiple Wyze cameras, including the Wyze Battery Cam Pro, Cam v3/v4, and Cam Outdoor v1/v2. It comes with a macro lens adapter that corrects focus for close-up shots, ensuring crystal-clear views of your bird visitors.
“Birdwatching on easy mode” is the promise of the Wyze Bird Feeder, making it a must-have for any bird enthusiast.
Wyze Battery Cam Pro: Wire-Free, Weatherproof, and High Definition
Stunning 2.5K HDR Video Quality
Capture every detail of your feathered friends with the Wyze Battery Cam Pro’s 2.5K HDR resolution. The camera delivers vibrant, balanced images day or night, enhanced by color night vision and two IR LEDs.
Wire-Free and Weatherproof Design
With an IP65 weatherproof rating, the Battery Cam Pro is built to endure all weather conditions. Its wire-free design means no complicated wiring or hubs are needed, making it perfect for outdoor bird feeder monitoring.
Long-Lasting Battery and Solar Panel Compatibility
The camera features removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge. For extended power, pair it with the Wyze Solar Panel to keep your camera running continuously without frequent recharging.
Advanced Motion Detection and Smart Features
Equipped with radar and PIR motion sensors, the camera detects movement with precision and sends instant notifications via the Wyze app. It also includes an integrated spotlight and siren for added security and visibility.
Easy Setup and Integration
Supports dual-band Wi-Fi (2.4 & 5 GHz) and BluetoothⓇ setup for quick installation. Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
Wyze Solar Panel: Sustainable Power for Continuous Monitoring
Efficient Solar Charging
The Wyze Solar Panel is designed specifically for the Wyze Battery Cam Pro, converting sunlight into power to keep your camera charged longer. This reduces the need for manual battery swaps and ensures uninterrupted birdwatching.
- Dimensions: 173 mm x 120 mm x 17 mm
- Power Rating: 2.5W, 5VDC
- Weather Resistance: IP65 rated for outdoor durability
- Includes a 13 ft (4m) micro USB-C cable for flexible placement
Easy Installation
Mount the solar panel near your camera with the included mounting hardware, and enjoy hassle-free, eco-friendly power.
Complete Birdwatching Bundle: Wyze Bird Feeder Wireless Camera Bundle
For the ultimate birdwatching experience, consider the Wyze Bird Feeder Wireless Camera Bundle. This all-in-one package includes:
- Wyze Bird Feeder (Blue or Brown)
- Wyze Battery Cam Pro (White or Black)
- Wyze Solar Panel
This bundle offers a weather-resistant, wire-free solution that lets you watch and record every bird visitor live through the Wyze app. It also includes the macro lens adapter and multiple mounting options for both the feeder and camera.
Perfect for bird lovers who want a ready-to-go, high-quality birdwatching setup with minimal fuss.
Why Choose This Setup?
- Weatherproof and durable: Both the feeder and camera are IP65 rated, built to last through all seasons.
- Wireless convenience: No need for power outlets or hubs; the battery cam and solar panel keep things simple.
- High-quality video: 2.5K HDR resolution with color night vision captures every detail.
- Smart notifications: Stay updated on bird activity with motion alerts and live streaming.
- Flexible installation: Multiple mounting options for both feeder and camera to suit your outdoor space.
Summary
Combining the Wyze Bird Feeder with the Wyze Battery Cam Pro and optional Solar Panel creates a powerful, weatherproof birdwatching system. Whether you’re a casual bird lover or a serious birder, this setup offers easy installation, stunning video quality, and sustainable power options to enjoy nature’s visitors anytime, rain or shine.
Enjoy birdwatching from the comfort of your home with Wyze’s weatherproof bird feeder and wireless camera.
Wyze Battery Cam Pro mounted near the bird feeder, capturing every moment in 2.5K HDR.
Keep your Wyze Battery Cam Pro charged sustainably with the Wyze Solar Panel.
What makes the Wyze Bird Feeder weatherproof and durable?
The Wyze Bird Feeder is crafted from durable polycarbonate material and features an IP65 weatherproof rating, making it resistant to rain, wind, and sun. It is designed to withstand temperatures from -4°F to 122°F (-20°C to 50°C) and humidity levels below 90%, ensuring year-round durability.Which Wyze cameras are compatible with the Wyze Bird Feeder?
The Wyze Bird Feeder supports multiple Wyze cameras, including the Wyze Battery Cam Pro, Wyze Cam v3/v4, and Wyze Cam Outdoor v1/v2. It also comes with a macro lens adapter for close-up, crystal-clear bird footage.How does the Wyze Battery Cam Pro enhance birdwatching?
The Wyze Battery Cam Pro offers 2.5K HDR video quality, color night vision, and advanced motion detection with radar and PIR sensors. Its wire-free, weatherproof design and long-lasting rechargeable battery make it ideal for outdoor birdwatching, providing live streaming and instant notifications via the Wyze app.Can the Wyze Battery Cam Pro be powered by solar energy?
Yes, the Wyze Battery Cam Pro is compatible with the Wyze Solar Panel, which provides efficient solar charging. This setup reduces the need for manual battery swaps and ensures continuous, eco-friendly power for uninterrupted birdwatching.What are the mounting options for the Wyze Bird Feeder?
The Wyze Bird Feeder offers five flexible mounting options: wall, tree, pole, cord, and suction cup mounts. This allows you to place the feeder wherever birds are most likely to visit in your outdoor space.What is included in the Wyze Bird Feeder Wireless Camera Bundle?
The Wyze Bird Feeder Wireless Camera Bundle includes a Wyze Bird Feeder (available in blue or brown), a Wyze Battery Cam Pro (white or black), and a Wyze Solar Panel. The bundle also comes with a macro lens adapter and multiple mounting options for both the feeder and camera.How long does the Wyze Battery Cam Pro battery last?
The Wyze Battery Cam Pro features removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.Is the Wyze Bird Feeder easy to install?
Yes, the Wyze Bird Feeder is designed for easy installation with multiple mounting options and a vibrant, bird-attracting design. The included hardware and flexible mounting choices make setup quick and convenient.Does the Wyze Battery Cam Pro support smart home integration?
Yes, the Wyze Battery Cam Pro supports dual-band Wi-Fi (2.4 & 5 GHz) and BluetoothⓇ setup. It is compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.What are the benefits of using the Wyze Solar Panel with the camera?
The Wyze Solar Panel provides sustainable, continuous power to the Wyze Battery Cam Pro, reducing the need for frequent battery recharging. It is IP65 weather-resistant and comes with a 13 ft (4m) micro USB-C cable for flexible placement.
