If you're looking for weather-resistant products, we have a variety of options to suit your needs:
- Wyze Cam v4:
- IP65 weather resistance ensures durability in various weather conditions.
- Features 2.5K QHD resolution and Enhanced Color Night Vision for clear video quality.
- Compatible with Alexa and Google Assistant for smart home integration.
- Wyze Cam Pan v3:
- Offers 360° pan and 180° tilt for comprehensive coverage.
- IP65 weather-resistant, making it suitable for both indoor and outdoor use.
- Includes automatic motion tracking and two-way audio.
- Wyze Battery Cam Pro:
- Wire-free with removable, rechargeable battery packs.
- IP65 weatherproof, supporting both 2.4 GHz and 5 GHz Wi-Fi.
- Equipped with 2.5K HDR video resolution and integrated spotlight and siren.
- Wyze Cam Floodlight Pro:
- Combines a 180° wide-angle lens with 2.5K QHD video.
- Features 3,000 lumen LED lights and IP65 weather resistance.
- Supports dual-band Wi-Fi (2.4 GHz & 5 GHz) for flexible connectivity.
- Wyze Cam v3:
- Known for its Color Night Vision and IP65 weatherproofing.
- Suitable for both indoor and outdoor monitoring.
- Offers person detection and motion and sound detection.
- Wyze Cam Floodlight (v1):
- Provides 270° customizable motion detection and 2600 lumens of light.
- IP65-rated for weather resistance, ideal for outdoor security.
- Includes two-way audio and color night vision.
- Wyze Video Doorbell v2:
- Delivers 2K video with local microSD storage.
- Features two-way audio and motion-activated voice deterrence.
- Designed for outdoor use with weather-resistant construction.
These products are designed to withstand various weather conditions while providing reliable security and smart features.
Can you tell me more about the Wyze Cam v4's features?What are the differences between the Wyze Cam Pan v3 and the Wyze Cam v3?Do you have any deals, ongoing sales, discounts, or promotions?
