If you're looking for a weather-resistant 20ft USB cable to power your Wyze Cam near a porch, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here are some key features that make it ideal for your needs:
- Compatibility: This extension cable is designed to work seamlessly with a variety of Wyze Cameras, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Weather Resistance: With an IP67 weather rating, this cable is built to withstand various weather conditions, making it perfect for outdoor use.
- Length: The 20ft length provides ample reach, allowing you to position your camera exactly where you need it without worrying about the distance to the power source.
- Easy Installation: The cable is easy to install, ensuring a hassle-free setup process.
This extension cable does not support data transmission and is not compatible with Wyze Cam Outdoor and Wyze Doorbell products. It also requires a compatible 5V/2A Wyze-branded power adapter, which is not included.
