Wyze Duo Cam: Modular Video Doorbell for Future Expansion
Wyze Video Doorbell v2: Modular and Future-Ready Security
The Wyze Video Doorbell v2 is the perfect choice for those seeking a video doorbell with modular components designed for potential future expansions. This wired video doorbell delivers crystal-clear 2K (2048 x 1536) resolution video, ensuring you never miss a detail at your doorstep. Its polycarbonate body and resin lens are built to last, with an IP65 weather resistance rating that keeps it operational in harsh weather conditions.
Key Features and Specs:
  • 2K HD Video Quality with a wide 166.8° diagonal field of view for comprehensive coverage.
  • Local microSD Storage support up to 256GB FAT32 format, plus optional cloud storage with Wyze Security Plan.
  • Two-Way Audio with ECM microphone and 8Ω 1W speaker for clear communication.
  • Motion-Activated Voice Deterrence to ward off unwanted visitors.
  • Power Requirements: 16V-24V AC, ≥10VA.
  • Smart Integrations: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Operating Temperatures: -4°F to 122°F (-20°C to 50°C).
  • Included Accessories: Chime controller, wall plate, wedge (30°), installation kit, wire caps, extension wires, screws, and quick start guide.
This doorbell is designed with future expansions in mind, allowing you to add accessories like the Wyze Video Doorbell v2 Wedge Kit to optimize your viewing angle and coverage.
Enhance Your Doorbell’s View with the Wedge Kit
For homes with angled door frames or porches with stairs, the Wyze Video Doorbell v2 Wedge Kit is an essential accessory. It allows you to adjust the doorbell’s angle horizontally and vertically, eliminating blind spots and maximizing your home security coverage.
  • Includes a 15° horizontal bracket and two 7.5° vertical brackets.
  • Quick and easy installation.
  • Weather-resistant plastic construction.
  • Compatible exclusively with Wyze Video Doorbell v2.
  • Backed by a 1-year warranty.
This modular approach means you can customize your doorbell setup now and expand it later as your security needs evolve.
The Front Porch Security Bundle: Comprehensive Smart Home Protection
If you want an all-in-one solution that combines video doorbell functionality with smart lock capabilities, the Front Porch Security Bundle is an excellent choice. This bundle includes the Wyze Video Doorbell (1080p HD) and Chime, plus the Wyze Lock, giving you full control over your front door security from anywhere.
Bundle Highlights:
  • 1080p HD Video Doorbell with two-way audio and motion alerts.
  • Wyze Lock lets you lock/unlock your door remotely and view lock history via the Wyze app.
  • Smart Home Compatibility: Works with Alexa and Google Assistant.
  • Weather-Resistant Doorbell: IP65 rating ensures durability.
  • Multiple Doorbell Sounds: Choose from modern, classic, animal, automation, and intruder alarm sounds.
  • Lock Features: Ultra-fast fingerprint reader, backlit anti-peep keypad, auto-lock, jam detection alarm, and emergency one-time codes.
  • Power: Doorbell powered by 16V-24V AC; lock powered by 4x AA batteries with 5-6 months battery life.
This bundle is ideal for users who want a modular, expandable smart home security system that integrates video monitoring and access control in one package.
Why Choose Wyze for Modular Video Doorbell Solutions?
Wyze’s video doorbells and accessories are designed with modularity and future-proofing in mind. Whether you start with the Wyze Video Doorbell v2 alone or opt for the comprehensive Front Porch Security Bundle, you can expand your system with accessories like the Wedge Kit or smart locks such as the Wyze Lock Bolt.
“Wyze Video Doorbell v2 offers the clearest 2K video and modular components for future expansions, making it a smart investment for evolving home security needs.”
Visualize Your Smart Security Setup
Wyze Video Doorbell v2 in Action Experience seamless home security with Wyze’s modular video doorbell and smart devices. Wyze Cam Floodlight v2 Lighting Up a Driveway Enhance your home’s security with smart lighting and video monitoring. Wyze Lock Bolt on Front Door Secure your home with Wyze Lock Bolt’s ultra-fast fingerprint sensor and app control.
Summary
  • Wyze Video Doorbell v2: 2K wired doorbell with modular design, local storage, and voice deterrence.
  • Wyze Video Doorbell v2 Wedge Kit: Accessory to adjust viewing angles for better coverage.
  • Front Porch Security Bundle: Combines video doorbell, chime, and smart lock for full front door security.
  • Wyze Lock Bolt: Smart deadbolt replacement with fingerprint sensor and app control.
Upgrade your home security today with Wyze’s modular video doorbell solutions designed for easy expansion and smart home integration.
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellSecurity Bundle (Wyze Lock + Video Doorbell and more)Accessory (Wedge Kit for Doorbell v2)
Video Resolution2K (2304 x 1296)1080p HD (Video Doorbell)N/A
Local StoragemicroSD card slot for 24/7 local recordingIncluded (Video Doorbell)N/A
Two-way AudioYesYesN/A
Motion-activated Voice DeterrenceYes (requires Cam Plus subscription)Yes (Video Doorbell)N/A
Chime CompatibilityWorks with existing chime (includes chime controller)Wyze Video Doorbell and Chime includedN/A
Additional Devices IncludedN/AWyze Lock (smart lock with remote control and lock history)N/A
Video Doorbell FeaturesPre-roll motion recording, AI detections with Cam Plus, IP65 weatherproof, night color vision2-way audio, 1080p HD video, lock/unlock door remotelyN/A
Wedge Kit IncludedYes (angled mounting wedge included)NoYes (15° horizontal bracket, 2x 7.5° vertical brackets)
Compatible WithDoorbell v2 onlyWyze Lock + Wyze Video Doorbell (varies by bundle)Doorbell v2 only
Price$44.98$123.99 - $173.97 (depending on variant)$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge Kit)
Weather ResistanceIP65IP65 (Video Doorbell)Weather resistant
InstallationWiredBundle includes devices, installation variesQuick installation
WarrantyNot specifiedNot specified1 year
What is the Wyze Video Doorbell v2 and what are its main features?The Wyze Video Doorbell v2 is a wired video doorbell designed with modular components for future expansion. It features 2K HD video quality (2048 x 1536 resolution), a wide 166.8° diagonal field of view, local microSD storage up to 256GB, two-way audio, motion-activated voice deterrence, and IP65 weather resistance. It also supports smart integrations with Alexa, Google Assistant, and IFTTT.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 supports local microSD storage up to 256GB in FAT32 format. It also offers optional cloud storage through the Wyze Security Plan.
Is the Wyze Video Doorbell v2 weatherproof?Yes, the Wyze Video Doorbell v2 has an IP65 weather resistance rating, making it suitable for use in harsh weather conditions and temperatures ranging from -4°F to 122°F (-20°C to 50°C).
What smart home systems are compatible with the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 works seamlessly with Alexa, Google Assistant, and IFTTT for easy smart home integration.
What is included with the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 comes with a chime controller, wall plate, 30° wedge, installation kit, wire caps, extension wires, screws, and a quick start guide.
What is the Wyze Video Doorbell v2 Wedge Kit and why should I use it?The Wyze Video Doorbell v2 Wedge Kit is an accessory that allows you to adjust the doorbell’s angle horizontally and vertically, eliminating blind spots and maximizing security coverage. It includes a 15° horizontal bracket and two 7.5° vertical brackets, is weather-resistant, and is compatible exclusively with the Wyze Video Doorbell v2.
Can I expand my Wyze Video Doorbell v2 system in the future?Yes, the Wyze Video Doorbell v2 is designed with modularity in mind, allowing you to add accessories like the Wedge Kit or integrate with other Wyze smart home devices as your security needs evolve.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes a Wyze Video Doorbell (1080p HD) with chime and the Wyze Lock. This bundle provides video doorbell functionality, two-way audio, motion alerts, and smart lock features such as remote locking/unlocking, lock history, fingerprint reader, backlit keypad, auto-lock, jam detection alarm, and emergency one-time codes.
How is the Wyze Lock powered and what is its battery life?The Wyze Lock is powered by 4 AA batteries, which typically last 5-6 months depending on usage.
Why should I choose Wyze for modular video doorbell solutions?Wyze offers modular and future-ready video doorbell solutions that are easy to expand and integrate with other smart home devices. Whether you start with the Wyze Video Doorbell v2 or the Front Porch Security Bundle, you can customize and upgrade your system with accessories like the Wedge Kit and smart locks such as the Wyze Lock Bolt.
Can you tell me more about the features of the Wyze Video Doorbell v2?What accessories are compatible with the Wyze Video Doorbell v2?Are there any ongoing promotions or discounts for the Wyze Video Doorbell v2?
