Secure Your Rental Property with the Mark-Free Wyze Window Mount for Optimal Camera Performance
If you're looking for a solution to mount your Wyze Cam on a window without leaving marks, the Wyze Window Mount is an excellent choice. Here's why we recommend it:
  • Compatibility: This mount is compatible with a range of Wyze Cams, including Wyze Cam v3, v3 Pro, v4, Cam OG, and Cam OG Telephoto.
  • Glare Reduction: It provides a clear view by reducing glare and reflections, ensuring optimal camera performance.
  • Easy Installation: Designed to attach directly to glass surfaces, making it ideal for rental properties where you want to avoid permanent marks or damage.
  • Available Style: The v2 style, which works with the latest Wyze Cam models, is currently in stock.
This mount is perfect for enhancing your security setup without compromising the integrity of your rental property.
Can you tell me more about the installation process for the Wyze Window Mount?Is the Wyze Window Mount compatible with all Wyze Cam models?Do you have any ongoing promotions or discounts for the Wyze Window Mount?
