If you're looking to monitor livestock with your Wyze Cam, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here's why we recommend it:
- Extended Reach: With a length of 20ft, this USB extension cable allows you to position your Wyze Cam at a greater distance from the power source, providing flexibility in camera placement.
- Compatibility: This cable is compatible with a wide range of Wyze Cams, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Weather Resistance: It features an IP67 weather rating, making it suitable for outdoor use, which is ideal for monitoring livestock in various weather conditions.
- Easy Installation: The cable is designed for easy installation, ensuring a hassle-free setup process.
Please note that this cable is for charging purposes only and does not support data transmission. It is compatible with any 5V/2A Wyze-branded power adapters.
Can you tell me more about the weather resistance of the Wyze Cam USB Extension Cable?Is the Wyze Cam USB Extension Cable easy to install?Do you have any deals, ongoing sales, discounts, or promotions available?
