Extend Your Wyze Cam Reach with a 20ft USB Extension Cable for Seamless Installation Behind Decorative Wall Paneling
If you're looking to extend the reach of your Wyze Cam behind decorative wall paneling, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here are some key features of this product:
  • Length: Enjoy the freedom of a 20ft cable, allowing you to place your Wyze Cam in more convenient locations.
  • Compatibility: This extension cable is compatible with a range of Wyze Cams, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Weather Resistance: With an IP67 weather rating, this cable is designed to withstand various weather conditions, making it suitable for both indoor and outdoor use.
  • Easy Installation: The cable is easy to install, ensuring a hassle-free setup process.
Please note that this extension cable is not compatible with Wyze Cam Outdoor and Wyze Doorbell products.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?Is the Wyze Cam USB Extension Cable suitable for outdoor use?Do you have any ongoing promotions or discounts for the Wyze Cam USB Extension Cable?
