Maximize Nighttime Security: Tips for Using Wyze Window Mount with Night Vision Through Sliding Glass Doors
For optimal nighttime camera usage through a sliding glass door with the Wyze Window Mount, we recommend utilizing the Night Vision feature available on compatible Wyze cameras. This feature allows you to view the live stream clearly in low light conditions, which is particularly useful at night. The Wyze Window Mount is designed to attach your Wyze Cam v3, v3 Pro, v4, or Cam OG series to a glass surface, providing a clear view free of glare or reflection. This setup ensures that your camera can effectively monitor the exterior while being protected indoors. Wyze Window Mount: Clear view free of glare, Compatible with multiple Wyze Cam models, Enhances exterior security.
What are the compatible Wyze camera models for the Wyze Window Mount?How does the Night Vision feature work on Wyze cameras?Can the Wyze Window Mount be used for indoor monitoring as well?
