For those looking to extend the reach of their Wyze Cam in a garage workshop, the
Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here’s why it stands out:
- Extended Reach: With a length of 20 feet, this cable provides ample length to position your camera exactly where you need it.
- Compatibility: It works seamlessly with a variety of Wyze Cams, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and Wyze Cam OG series.
- Weather Resistance: Rated IP67, it can withstand harsh conditions, making it suitable for both indoor and outdoor use.
- Easy Installation: The cable is designed for straightforward installation, ensuring you can set up your camera quickly and efficiently.
Additionally, if you need to power your Wyze Cam without a plug, consider the
Wyze Lamp Socket. It conveniently powers Wyze Cam v3 and v4, making it a versatile option for smart lighting and camera setups.
