Enhance Camera Stability in High Winds with Wyze Window Mount and Accessories for Multi-Story Buildings
For those looking to stabilize their camera feed in multi-story buildings with strong winds, we recommend the following products:
  • Wyze Window Mount: This accessory is perfect for mounting your Wyze Cam v3, v3 Pro, v4, Cam OG, or Cam OG Telephoto on a glass surface. It reduces glare and provides a clear view free of reflections, making it ideal for exterior security in windy conditions.
  • Wyze Universal Mount (Long): Designed for versatile mounting applications, this durable camera mount features a longer neck, allowing for secure installation on ceilings or patios. It is compatible with a wide range of Wyze Cameras, except for the Wyze Cam OG and OG Telephoto.
  • Wyze Cam Mounting Kit: This kit includes a mounting bracket, adhesive, and a longer Micro USB cable, providing a comprehensive solution for securely mounting your Wyze Cam v2, v3, or v3 Pro.
These products are designed to enhance the stability and performance of your Wyze cameras, ensuring reliable security footage even in challenging conditions.
FeatureWyze Window MountWyze Universal Mount (Long)Wyze Cam Mounting Kit
CompatibilityWyze Cam v3, v3 Pro, v4, Cam OG, Cam OG TelephotoWyze Cameras with a standard 1/4”-20 mount (not compatible with Wyze Cam OG/OG Telephoto)Wyze Cam v2, v3, v3 Pro
Price$4.99$9.99$5.99
Stock AvailabilityAvailableAvailableAvailable
Mounting SurfaceGlass surfacesCeilings, patios, versatile mounting applicationsWalls
Key FeaturesReduces glare, clear view free of reflectionDurable, longer neck, adjustable angle, heavy-duty metal, suitable for outdoor useIncludes mounting bracket, adhesive, longer Micro USB cable
Outdoor UseYesYes, but recommended to protect from direct exposure to extreme weatherNot specified
AdjustabilityNot specifiedYes, adjustable angleNot specified
InstallationEasy to mount on glassEasy installation on fences, trees, siding, and moreIncludes adhesive and screw set for easy installation
Return PolicyRefund only30-day hassle-free returnsRefund only
Can you tell me more about the Wyze Universal Mount and its features?Is the Wyze Cam Mounting Kit compatible with the Wyze Cam OG?Do you have any ongoing sales or discounts for camera accessories?
