Smartwatches Compatible with Wyze Devices for Home Automation
Smartwatch Compatible with Wyze Devices for Home Automation Control
If you're looking to seamlessly control your Wyze smart home devices right from your wrist, the Wyze Watch is the perfect companion. Designed to integrate effortlessly with Wyze's ecosystem, the Wyze Watch offers convenient shortcuts and real-time notifications, empowering you to manage your home automation with ease and style. Below, explore the top Wyze products compatible with the Wyze Watch, enabling you to create a smarter, safer, and more connected home environment.
Wyze Watch: Your Smart Home Command Center on Your Wrist
Lightweight and Customizable Design
The Wyze Watch comes in two sizes—44mm and 47mm—with a vibrant 1.75-inch screen. Its lightweight aluminum alloy body and multiple strap options (silicone, faux leather) ensure comfort and style for everyday wear.
Comprehensive Health Suite & Long Battery Life
Beyond home control, the watch tracks your heart rate, blood oxygen levels, and menstrual cycle, making it a versatile wearable. With up to 9 days of battery life on a single charge, it stays powered through your busy schedule.
Direct Control of Wyze Devices
Use Wyze Watch shortcuts to control your Wyze smart devices instantly. Whether turning on lights, checking cameras, or receiving alerts, the watch keeps your home automation at your fingertips.
Waterproof Durability
Rated IP68, the Wyze Watch is waterproof up to 2 meters, so you can wear it confidently in all conditions.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoors
Wyze Cam Floodlight v2 illuminating a driveway at dusk Powerful outdoor lighting with smart security
Key Features:
  • 2800 Lumens LED Lighting with dimmable panels and 5000K color temperature for bright, clear illumination.
  • 2K HD Video with Color Night Vision and a wide 160° diagonal field of view to monitor large outdoor areas.
  • AI-Powered Light Control and dusk-to-dawn automation for energy-efficient operation.
  • Two-Way Audio & 105dB Siren for real-time communication and deterrence.
  • Weather Resistant (IP65) to withstand harsh outdoor conditions.
  • Seamless Integration with Alexa, Google Assistant, IFTTT, and Wyze Watch for effortless voice and wrist control.
This floodlight camera is ideal for enhancing your home’s security while providing smart lighting that you can control remotely or via your Wyze Watch.
Wyze Bulb Cam: The 2-in-1 Smart Light and Security Camera
Wyze Bulb Cam installed in an outdoor light fixture Discreet security with smart lighting
Highlights:
  • 2K HD Video with Color Night Vision captures clear footage day and night.
  • Standard E26 Socket fits most light fixtures for easy installation.
  • Up to 800 Lumens Brightness with motion-activated and ambient light controls.
  • Two-Way Audio & 95dB Siren for communication and alerting.
  • Local and Cloud Storage Options with no subscription required.
  • IP65 Weather Resistance for reliable outdoor use.
  • Bluetooth and Wi-Fi Connectivity for smooth integration with Wyze Watch and app control.
Control your outdoor lighting and monitor your property effortlessly from your wrist or smartphone.
Essential Security Bundle: Comprehensive Home Protection
All-in-One Smart Security Solution
This bundle combines multiple Wyze devices to cover every angle of your home:
  • Wyze Video Doorbell v2: Crisp 1080p HD video, two-way audio, and person detection to monitor your front door.
  • Wyze Lock Bolt: Smart lock with fingerprint sensor and backlit keypad for secure, keyless entry.
  • Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, motion tracking, and color night vision.
  • Two Wyze Cam OG Cameras: Plug-in cameras with motion-activated spotlights and color night vision for indoor/outdoor use.
Smart Home Integration
All devices in this bundle support local and cloud recording, real-time alerts, and voice assistant compatibility. Use your Wyze Watch to arm/disarm, view live feeds, or control locks and lights instantly.
Enhance Your Smart Home Network with Wyze Wi-Fi 6 Mesh Router
While not a camera, the Wyze Wi-Fi 6 Mesh Router is essential for a reliable smart home experience. It supports over 50 devices per router with speeds up to 1 Gbps, ensuring your Wyze devices and Wyze Watch stay connected without interruption.
Why Choose Wyze for Your Smartwatch Home Automation?
  • Unified Ecosystem: Wyze Watch works seamlessly with Wyze cameras, lights, locks, and more.
  • Affordable Smart Home: High-quality devices at budget-friendly prices.
  • Easy Setup & Control: Intuitive app and watch interface for effortless management.
  • Robust Security Features: Advanced AI detection, two-way audio, and sirens keep your home safe.
  • Weatherproof & Durable: Designed for indoor and outdoor use with IP65 ratings.
Take control of your home automation with the Wyze Watch and compatible Wyze devices. From floodlights to smart locks, manage your smart home effortlessly right from your wrist.
Product Summary
ProductKey FeaturesPrice (USD)
Wyze WatchIP68 waterproof, health suite, 9-day batteryN/A
Wyze Cam Floodlight v22800 lumens, 2K video, AI light control$89.98
Wyze Bulb Cam2-in-1 light & camera, 2K video, motion alerts$49.98
Essential Security BundleDoorbell, lock, pan cam, 2 OG cams$199.99
Wyze Wi-Fi 6 Mesh RouterWi-Fi 6, 50+ devices, 1500 sq ft coverage$99.99 (2-pack)
FeaturePan v3 + Lamp Socket v2 BundleWyze Cam Floodlight v2Wyze Bulb CamEssential Security Bundle
Product TypeCamera Bundle with Lamp SocketFloodlight CameraBulb CameraSecurity Bundle
Price$53.96$89.98$49.98$199.99
Camera ResolutionNot specified (Pan v3 camera)2K (2304 x 1296)2K (2304 x 1296)Wyze Cam Pan v3: 1080p HD; Wyze Cam OG: 1080p HD; Wyze Video Doorbell v2: 1080p HD
Field of ViewPan v3: 360° horizontal, 180° vertical160° wide-angle160° horizontal, 166° diagonalPan v3: 360° horizontal, 180° vertical; OG: Not specified; Doorbell: Not specified
Night VisionColor Night VisionColor Night VisionColor Night VisionPan v3 & OG: Color Night Vision; Doorbell: Not specified
AudioTwo-way audioTwo-way talk + 105dB sirenTwo-way audioTwo-way audio on cameras and doorbell
LightingPowered via Lamp Socket (no outlet needed)2800 Lumens LEDs, motion-activated floodlightsSmart LED light bulb up to 800 lmMotion-activated spotlights on Wyze Cam OG; no floodlight included
Power SourceLamp Socket v2 (powers Pan v3 via light fixture)Hardwired 110V-120VStandard E26 socket, 120V ACCameras powered individually (plug-in or wired)
Weather ResistanceNot specifiedIP65 ratedIP65 ratedIP65 rated cameras
Motion DetectionYes (via Pan v3 camera)270° PIR motion detectionYesYes (motion-activated features on cameras and doorbell)
StorageNot specified24/7 local recording (microSD up to 256GB)Local storage support up to 256GB microSDCloud and local storage options
Smart FeaturesLinkable lamp sockets, dusk-to-dawn automationAI-Powered Light Control, Ambient Light ModeMotion-activated light, schedule, automationsPerson detection, automatic motion tracking, smart lock with fingerprint and keypad
InstallationScrew-in lamp socket installationDIY install, no junction box neededFits most fixtures, easy installCameras and devices included; installation varies by device
WarrantyNot specified1-Year1-YearNot specified
Included DevicesWyze Cam Pan v3 + Lamp Socket v2Wyze Cam Floodlight v2Wyze Bulb CamWyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2× Wyze Cam OG
What Wyze devices can I control with the Wyze Watch?The Wyze Watch allows you to control a variety of Wyze smart home devices, including Wyze Cam Floodlight v2, Wyze Bulb Cam, Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and Wyze Cam OG Cameras. You can use shortcuts on your watch to manage lights, cameras, locks, and receive real-time notifications.
How does the Wyze Watch enhance home automation?The Wyze Watch acts as a smart home command center on your wrist, providing instant shortcuts to control Wyze devices, receive real-time alerts, and manage your home automation system with ease. Its seamless integration with the Wyze ecosystem ensures you can monitor and control your home from anywhere.
Is the Wyze Watch waterproof?Yes, the Wyze Watch is rated IP68 waterproof, allowing you to wear it confidently in all conditions, including up to 2 meters underwater.
What health features does the Wyze Watch offer?The Wyze Watch includes a comprehensive health suite that tracks your heart rate, blood oxygen levels, and menstrual cycle, making it a versatile wearable for daily health monitoring.
How long does the Wyze Watch battery last?The Wyze Watch offers up to 9 days of battery life on a single charge, ensuring it stays powered through your busy schedule.
Can I use the Wyze Watch to control outdoor security devices?Yes, the Wyze Watch can control outdoor security devices such as the Wyze Cam Floodlight v2 and Wyze Bulb Cam, allowing you to manage lighting, monitor video feeds, and receive alerts directly from your wrist.
What are the key features of the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 features 2800 lumens of LED lighting, 2K HD video with color night vision, AI-powered light control, two-way audio, a 105dB siren, and weather resistance (IP65). It integrates seamlessly with the Wyze Watch for easy control.
What makes the Wyze Bulb Cam unique?The Wyze Bulb Cam is a 2-in-1 smart light and security camera that fits standard E26 sockets. It offers 2K HD video, color night vision, up to 800 lumens brightness, motion-activated lighting, two-way audio, a 95dB siren, and both local and cloud storage options.
What is included in the Wyze Essential Security Bundle?The Essential Security Bundle includes the Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This bundle provides comprehensive home protection with features like HD video, motion tracking, person detection, and smart lock access.
How does the Wyze Wi-Fi 6 Mesh Router improve my smart home experience?The Wyze Wi-Fi 6 Mesh Router supports over 50 devices per router and delivers speeds up to 1 Gbps, ensuring all your Wyze devices and the Wyze Watch stay connected reliably for uninterrupted smart home automation.
Why should I choose Wyze for smartwatch home automation?Wyze offers a unified ecosystem where the Wyze Watch works seamlessly with cameras, lights, locks, and more. Wyze devices are affordable, easy to set up, and feature robust security, weatherproof durability, and intuitive control through both the app and watch interface.
Are Wyze devices compatible with voice assistants?Yes, Wyze devices are compatible with popular voice assistants such as Alexa and Google Assistant, as well as IFTTT, allowing for convenient voice and automation control alongside the Wyze Watch.
Can you tell me more about the features of the Wyze Watch?How does the Wyze Watch integrate with the Wyze Cam Floodlight v2?Do you have any ongoing sales or discounts for the Wyze Watch?
