Smart Monitor Light Bars for PC with Yeelight App Integration
Smart Monitor Light Bar Solutions with Yeelight App Integration for PC
Enhance your PC workspace with smart lighting that integrates seamlessly with the Yeelight app, offering customizable ambiance, intuitive control, and vibrant colors. Whether you're looking to reduce eye strain, boost productivity, or create an immersive gaming environment, these smart lighting products provide the perfect solution for your monitor setup.
Wyze Light Strip: Brilliant LED Accent Lighting for Your Monitor
The Wyze Light Strip is an ideal smart monitor light bar alternative that brings vivid, customizable lighting to your PC setup. With 16 million colors and flexible placement, it can be easily attached behind your monitor or desk to create a stunning backlight effect.
Key Features:
  • 16 Million Colors & Custom Effects: Choose from a vast palette to match your mood or task, from cool whites for work to vibrant colors for gaming.
  • Music Mode: Sync your lights to your favorite music using the built-in microphone, turning your workspace into a lively environment.
  • Sun Match Technology: Automatically adjusts color temperature to mimic natural daylight cycles, reducing eye strain during long hours at the PC.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free lighting adjustments.
  • Easy Installation: Peel, stick, and plug in anywhere around your monitor or desk for instant ambiance.
  • App Control: Full control via the Wyze app, which can be integrated with Yeelight for a unified smart lighting experience.
Available in 16.4 feet and 32.8 feet lengths, the Wyze Light Strip offers flexibility for different monitor sizes and desk setups. Wyze Light Strip Lifestyle Create immersive lighting behind your PC monitor with Wyze Light Strip
Wyze Bulb Color: Vibrant Smart Bulb for Desk Lamps and Room Lighting
Complement your monitor light bar with the Wyze Bulb Color, a smart bulb offering 16 million colors and advanced lighting controls. Perfect for desk lamps or ambient room lighting, it enhances your PC environment with rich, customizable hues.
Highlights:
  • Brighter and Dimmable: Adjustable brightness from 30lm to 1100lm lets you tailor lighting intensity for work or relaxation.
  • 16 Million Colors: Easily switch colors to match your gaming setup, video calls, or mood lighting.
  • High CRI (90+): See true, vibrant colors on your screen and in your room, improving visual clarity.
  • Custom Presets & Routines: Save favorite lighting scenes and automate wake-up or sleep routines.
  • Music Sync: When grouped with Wyze Light Strip, sync your entire lighting setup to music beats.
  • Voice & App Control: Works with Alexa, Google Assistant, and the Wyze app for seamless integration.
Use the Wyze Bulb Color in your desk lamp or overhead fixture to create a cohesive smart lighting ecosystem around your PC. Wyze Bulb Color Lifestyle Add vibrant color lighting to your workspace with Wyze Bulb Color
Wyze Switch: Smart Control for Your Monitor Lighting Setup
The Wyze Switch transforms your existing lighting into smart lighting, allowing you to control your monitor light bar and other lights from anywhere.
Features:
  • Remote Control: Turn your monitor light bar or desk lamp on/off from the Wyze app, no matter where you are.
  • Multi-Tap Actions: Customize single, double, or triple taps to control other Wyze devices like cameras or vacuums.
  • Automations & Schedules: Set timers or automate lighting based on your daily routine or presence.
  • Vacation Mode: Simulate occupancy by scheduling lights to turn on/off while you're away.
  • Easy Integration: Works seamlessly with the Wyze ecosystem and voice assistants for hands-free control.
This switch is perfect for integrating your smart monitor light bar into a broader smart home setup, enhancing convenience and control. Wyze Switch Lifestyle Control your smart lighting setup effortlessly with Wyze Switch
Why Choose Wyze Smart Lighting for Your PC Monitor?
"Smart lighting is not just about illumination; it's about creating an environment that adapts to your lifestyle and enhances your productivity and comfort."
Wyze smart lighting products offer a comprehensive solution for PC users seeking smart monitor light bars with Yeelight app integration. Their compatibility with popular voice assistants, extensive color options, and smart routines make them a versatile choice for any workspace.
  • Seamless App Integration: Use the Wyze app alongside Yeelight for unified control.
  • Customizable Ambiance: From focused work light to immersive gaming colors.
  • Energy Efficient & Reliable: Long-lasting LEDs with smart scheduling to save power.
  • Affordable & Easy to Install: No complex setups, just plug and play.
Upgrade your PC lighting today with Wyze smart products and enjoy a smarter, more colorful workspace.
Summary of Featured Products
ProductKey BenefitIntegrationPrice Range
Wyze Light StripFlexible LED strip with music sync and natural light matchingWyze app, Alexa, Google Assistant$19.99 - $35.99
Wyze Bulb ColorBright, dimmable smart bulb with 16M colors and high CRIWyze app, Alexa, Google Assistant$26.26 (2-pack)
Wyze SwitchSmart switch for remote and automated control of lightsWyze app, Alexa, Google Assistant$14.99 (1-pack)
Enhance your PC experience with smart monitor lighting that integrates perfectly with the Yeelight app and Wyze ecosystem. Enjoy vibrant colors, smart automation, and effortless control for a truly modern workspace.
FeatureWyze Light StripWyze Bulb ColorWyze Switch
TypeConnected Home - LED Accent LightingSmart Lighting - Color Smart BulbConnected Home - Smart Light Switch
Variants16.4 ft ($19.99), 32.8 ft ($35.99)2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)1 Pack ($14.99), 3 Pack ($41.98)
Colors16 million16 millionN/A
Customizable Zones1N/AN/A
Power SourceCorded Electric12 watts, AC 120V~60 HzWired (installed in wall)
Wattage16.4 ft - 18W, 32.8 ft - 36W12 wattsN/A
LumensBlue 0.8lm/LED, Red 1.0lm/LED, Green 2.5lm/LED (30 LEDs/meter)30-1100 lumensN/A
ConnectivityWi-Fi 802.11 b/g/n 2.4 GHz, BluetoothWi-Fi 802.11 b/g/n 2.4 GHz, BluetoothN/A (controlled via Wyze app)
UsageIndoor OnlyIndoor, Suitable for Damp LocationsIndoor
Operating Temperature-4°F to 122°F (-20°C to 50°C)-4°F to 104°FNot specified
Life Expectancy25,000 Hours25,000 HoursNot specified
Mounting MethodAdhesive backingStandard bulb socket (E26 base)Wall switch replacement
CuttableYesNoN/A
Music FeatureYes (built-in microphone)YesNo
Voice ControlVia app (implied)Yes (Alexa, Google Assistant, IFTTT)Yes (via Wyze app integration)
App ControlYesYesYes
Special FeaturesLED accent lighting, single color zoneDimmable, tunable white, custom presets, sleep routines, music modeMulti-tap control, automations, vacation mode, power loss recovery
Included in BoxLight Strip, Controller, Adhesive Clips, Power Adapter, Quick Start Guide, Alcohol WipesBulbs (per pack)Switch(es)
What is a smart monitor light bar and how does it enhance my PC workspace?A smart monitor light bar is an LED lighting solution designed to be placed behind or around your PC monitor. It enhances your workspace by providing customizable ambiance, reducing eye strain, boosting productivity, and creating an immersive environment for gaming or work. With smart features and app integration, you can easily control lighting effects, colors, and brightness to suit your needs.
How does the Wyze Light Strip work as a monitor light bar?The Wyze Light Strip is a flexible LED strip that can be attached behind your monitor or desk to create a stunning backlight effect. It offers 16 million colors, custom effects, music sync, and Sun Match technology to mimic natural daylight. The strip is easy to install and can be controlled via the Wyze app, voice assistants, or integrated with the Yeelight app for unified smart lighting control.
Can I control Wyze smart lighting products with the Yeelight app?Yes, Wyze smart lighting products such as the Wyze Light Strip can be integrated with the Yeelight app, allowing you to control your monitor lighting and other smart lights from a single platform for a seamless smart home experience.
What are the benefits of using the Wyze Bulb Color for my desk lamp or room lighting?The Wyze Bulb Color offers 16 million colors, adjustable brightness (30lm to 1100lm), and a high CRI (90+) for true, vibrant colors. It is perfect for desk lamps or ambient room lighting, allowing you to create custom lighting scenes, automate routines, and sync with music when grouped with the Wyze Light Strip. Control is easy via the Wyze app, Alexa, or Google Assistant.
How does the Wyze Switch improve my smart monitor lighting setup?The Wyze Switch allows you to remotely control your monitor light bar and other lights from anywhere using the Wyze app. It supports multi-tap actions to control other Wyze devices, automations, schedules, and vacation mode for added security. The switch integrates seamlessly with the Wyze ecosystem and popular voice assistants for hands-free operation.
Is it easy to install Wyze smart lighting products for my PC monitor?Yes, Wyze smart lighting products are designed for easy installation. The Wyze Light Strip features a peel-and-stick design for quick setup behind your monitor or desk, while the Wyze Bulb Color fits standard light fixtures. No complex wiring or tools are required—just plug and play.
Can I sync my monitor lighting with music using Wyze products?Absolutely! Both the Wyze Light Strip and Wyze Bulb Color offer music sync features. The Wyze Light Strip has a built-in microphone to sync lighting effects to your favorite music, creating a lively and immersive environment. When grouped together, your entire lighting setup can pulse and change colors to the beat.
Are Wyze smart lighting products compatible with voice assistants?Yes, Wyze smart lighting products are compatible with popular voice assistants such as Amazon Alexa and Google Assistant. This allows you to control your monitor light bar, bulbs, and switches hands-free using simple voice commands.
What are the available sizes and price ranges for Wyze Light Strip and Bulb Color?The Wyze Light Strip is available in 16.4 feet and 32.8 feet lengths, with prices ranging from $19.99 to $35.99. The Wyze Bulb Color is available in a 2-pack for $26.26. These options provide flexibility and affordability for different monitor sizes and room setups.
Why should I choose Wyze smart lighting for my PC monitor setup?Wyze smart lighting offers seamless app integration, customizable ambiance, energy efficiency, and easy installation. With features like music sync, voice control, and smart scheduling, Wyze products provide a comprehensive and affordable solution for enhancing your PC workspace with vibrant, adaptive lighting.
Can you tell me more about the features of the Wyze Light Strip?How does the music mode work with the Wyze Light Strip?Do you have any ongoing sales or discounts for the Wyze products?
