Smart Doorbell with Cam Plus Free Trial & Easy Installation
Smart Doorbell with Cam Plus Free Trial and Easy Installation Guide
Looking for a smart doorbell that offers crystal-clear video, easy installation, and a free trial of advanced features? Discover the Wyze Video Doorbell v2, a top-tier wired video doorbell that combines 2K resolution, local storage, and smart notifications. Plus, explore complementary Wyze cameras that enhance your home security with weatherproof designs, pan-tilt capabilities, and wireless convenience.
Wyze Video Doorbell v2: Your Front Door Guardian
Stunning 2K Video Quality
Wyze Video Doorbell v2 delivers sharp 2K (2048 x 1536) video resolution, ensuring you never miss a detail at your doorstep. Equipped with a CMOS Starlight Sensor and 6 IR lights, it provides clear day and night vision with a wide 166.8° diagonal field of view.
Two-Way Audio & Real-Time Alerts
Communicate instantly with visitors or deter unwanted guests using the built-in microphone and speaker. Receive motion-activated alerts on your phone, so you’re always connected no matter where you are.
Local and Cloud Storage Options
Store your video footage locally on a microSD card (up to 256GB) or opt for cloud storage with the Wyze Security Plan. This flexibility ensures your data is safe and accessible.
Easy Installation Kit Included
The doorbell comes with everything you need for a hassle-free setup: chime controller, wall plate, wedge for angled mounting, wire caps, screws, anchors, and a quick start guide. Compatible with standard 16V-24V AC power, it fits most home wiring systems.
Weather Resistant for All Seasons
Rated IP65, the Wyze Video Doorbell v2 withstands rain, snow, and extreme temperatures from -20°C to 50°C (-4°F to 122°F), making it perfect for any climate.
“Answer your door from anywhere with our clearest and most capable wired video doorbell yet.”
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Panoramic Security with Free Trial
360° Pan and 180° Tilt Coverage
The Wyze Cam Pan v3 offers full-room coverage with its smooth 360° horizontal pan and 180° vertical tilt. Now you can monitor every corner of your home or yard with a single camera.
Weatherproof and Outdoor Ready
With an IP65 rating, this camera is designed for indoor and outdoor use. Pair it with the Wyze Outdoor Power Adapter (sold separately) for reliable all-weather performance.
Automatic Motion Tracking
The camera detects motion, follows moving objects automatically, and records them quietly without disturbing your household. This feature ensures you capture every important moment.
Privacy Mode & Two-Way Audio
Enable Privacy Mode to spin the camera downward and disable recording when you want peace of mind. Use two-way audio to talk and listen through the Wyze app, perfect for greeting guests or checking on pets.
Cam Plus Free Trial
Enjoy a 30-day free trial of Cam Plus, which unlocks unlimited event video cloud storage and smart notifications for people, packages, and vehicles. After the trial, continue with a low monthly subscription or cancel anytime. Wyze Cam Pan v3 Outdoor Lifestyle Wyze Cam Pan v3 in snowy outdoor setting, showcasing weather resistance and 360° coverage.
Wyze Battery Cam Pro: Wire-Free, Powerful Security Anywhere
High-Resolution 2.5K HDR Video
Capture crisp, detailed footage with 2560 x 1440 resolution and a CMOS-Starlight sensor that excels in low light.
Completely Wire-Free with Rechargeable Battery
No wiring hassles—mount the camera anywhere with removable 6200mAh rechargeable batteries lasting up to 6 months on a single charge. Charging takes approximately 9 hours.
Integrated Spotlight and Siren
The built-in spotlight and 100 dB siren provide active deterrence against intruders, while radar + PIR motion detection ensures accurate alerts.
Dual-Band WiFi and Smart Home Integration
Supports both 2.4 GHz and 5 GHz WiFi for stable connections. Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
Weatherproof and Durable
IP65-rated for protection against rain and dust, and built to operate in temperatures from -20°C to 50°C (-4°F to 122°F).
Wyze Cam v4: Indoor/Outdoor Versatility with Enhanced Features
Crystal-Clear 2.5K QHD Resolution
Enjoy sharp video quality with enhanced color night vision and a motion-activated spotlight to keep your home safe day and night.
Wi-Fi 6 Support and Smart Assistant Compatibility
Experience faster, more reliable connections with Wi-Fi 6. Works with Alexa and Google Assistant for voice control and automation.
24/7 Local Recording
Supports continuous local recording with microSD cards, ensuring you never miss a moment.
Easy Installation Guide for Wyze Video Doorbell v2
1. Turn Off Power: Switch off power at your circuit breaker to ensure safety. 2. Remove Old Doorbell: Detach your existing doorbell and disconnect wires. 3. Mount Chime Controller: Install the included chime controller inside your home. 4. Connect Wires: Attach your home’s doorbell wires to the Wyze Video Doorbell terminals. 5. Mount Doorbell: Use the wall plate and wedge (if needed) to mount the doorbell securely. 6. Restore Power: Turn the power back on and follow the Wyze app instructions to complete setup. 7. Activate Cam Plus Free Trial: Sign up in the app to enjoy 30 days of free advanced features.
With the included quick start guide and app walkthrough, installation is straightforward even for beginners.
Why Choose Wyze for Your Smart Doorbell and Security Cameras?
  • Affordable Pricing: High-end features without breaking the bank.
  • Free 30-Day Cam Plus Trial: Experience premium cloud storage and smart alerts risk-free.
  • Robust Weather Resistance: IP65-rated devices built for all climates.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • User-Friendly App: Easy control, notifications, and privacy settings at your fingertips.
Two-Way Audio Lifestyle Communicate effortlessly with visitors or family through two-way audio on Wyze cameras.
Secure your home with Wyze’s smart doorbell and camera solutions today. Enjoy peace of mind with easy installation, free trials, and advanced security features designed for modern living.
FeatureWyze Video Doorbell v2Wyze Cam Pan v3 + 30-Day Cam Plus BundleWyze Cam Pan v3Wyze Battery Cam ProWyze Cam v4
TypeWired Video DoorbellIndoor/Outdoor Pan & Tilt Camera + Cam PlusIndoor/Outdoor Pan & Tilt CameraWire-Free Battery CameraWired Indoor/Outdoor Camera
Video Resolution2K (2304 x 1296)1080p (1920 x 1080)1080p (1920 x 1080)2.5K HDR (2560 x 1440)2.5K QHD (2560 x 1440)
Field of ViewHead-to-toe view (exact FOV not specified)120° FOV120° FOV134° DFOV, 108° HFOV, 56° VFOVDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Pan & TiltNo360° pan, 180° tilt360° pan, 180° tiltNoNo
Night VisionColor Night Vision (Starlight Sensor)Color Night Vision (Starlight Sensor)Color Night Vision (Starlight Sensor)2 IR LEDs + 2 White LEDs (Color Night Vision)Enhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)
AudioTwo-way audioTwo-way audioTwo-way audioTwo-way audio with built-in speaker & micImproved two-way audio
StorageLocal microSD (continuous 24/7 recording)Supports microSD (up to 256GB)Supports microSD (up to 256GB)Local microSD support (up to 256GB)microSD card up to 512GB
Cloud StorageOptional Cam Plus subscriptionCam Plus 30-day free trial includedOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional subscription plan
Power SourceWiredWired (requires outdoor power adapter for outdoor use)Wired (requires outdoor power adapter for outdoor use)Removable, rechargeable battery packsWired
Weather ResistanceIP65IP65IP65IP65IP65
Motion DetectionYes, with pre-roll recording (3-6 seconds)Yes, with motion trackingYes, with motion trackingRadar + PIR motion detectionYes, with motion detection zones
Special FeaturesMotion-activated voice deterrence (subscription required), works with existing chime, 30° corner kit included360° pan & 180° tilt, automatic motion tracking, privacy mode, Pan Scan™ patrol360° pan & 180° tilt, automatic motion tracking, privacy modeIntegrated spotlight & siren, radar + PIR detection, up to 6 months battery lifeMotion-activated spotlight, wide dynamic range, built-in siren, Alexa & Google Assistant compatible
DimensionsNot specified124mm (H) x 60mm (W) x 63mm (D)124mm (H) x 60mm (W) x 63mm (D)2.5 x 1.8 x 3.5 inches2in x 2in x 2 3/8in
WeightNot specified11.29 oz (320 g)11.29 oz (320 g)0.94 lbs0.49 lb (222 g)
ConnectivityWi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHz, Wi-Fi 6
Smart Home IntegrationAlexa, Google HomeAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Price$44.98 (Doorbell + Chime Controller)$39.98 (Cam Pan v3) + 30-Day Cam Plus Bundle$39.98 (Cam Pan v3)$159.98 (1 Pack)$35.98 (1 Pack)
What is the video resolution of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features stunning 2K (2048 x 1536) video resolution, providing crystal-clear footage of your doorstep both day and night.
Does the Wyze Video Doorbell v2 support local and cloud storage?Yes, the Wyze Video Doorbell v2 supports both local storage via a microSD card (up to 256GB) and cloud storage through the Wyze Security Plan, giving you flexible options to keep your video footage safe and accessible.
Is the Wyze Video Doorbell v2 weatherproof?Absolutely. The Wyze Video Doorbell v2 is IP65-rated, making it weather resistant and capable of withstanding rain, snow, and extreme temperatures from -20°C to 50°C (-4°F to 122°F).
What is included in the Wyze Video Doorbell v2 installation kit?The installation kit includes a chime controller, wall plate, wedge for angled mounting, wire caps, screws, anchors, and a quick start guide for hassle-free setup.
How do I install the Wyze Video Doorbell v2?To install the Wyze Video Doorbell v2: 1) Turn off power at your circuit breaker, 2) Remove your old doorbell, 3) Mount the chime controller, 4) Connect your home’s doorbell wires to the Wyze terminals, 5) Mount the doorbell using the wall plate and wedge, 6) Restore power, and 7) Follow the Wyze app instructions to complete setup.
Does the Wyze Video Doorbell v2 come with a free trial of Cam Plus?Yes, the Wyze Video Doorbell v2 includes a 30-day free trial of Cam Plus, which unlocks advanced features like unlimited event video cloud storage and smart notifications for people, packages, and vehicles.
What are the key features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 offers 360° pan and 180° tilt coverage, weatherproof IP65 rating, automatic motion tracking, privacy mode, two-way audio, and a 30-day free trial of Cam Plus for advanced cloud storage and smart alerts.
Can the Wyze Cam Pan v3 be used outdoors?Yes, the Wyze Cam Pan v3 is IP65-rated for weather resistance and can be used both indoors and outdoors. For outdoor use, pair it with the Wyze Outdoor Power Adapter (sold separately).
What makes the Wyze Battery Cam Pro unique?The Wyze Battery Cam Pro is a completely wire-free security camera with 2.5K HDR video, a rechargeable battery lasting up to 6 months, integrated spotlight and siren, radar + PIR motion detection, dual-band WiFi, and smart home integration with Alexa, Google Assistant, and IFTTT.
How long does the Wyze Battery Cam Pro battery last and how is it charged?The Wyze Battery Cam Pro features a 6200mAh rechargeable battery that can last up to 6 months on a single charge. Charging the battery takes approximately 9 hours.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65-rated for protection against rain and dust, and it operates in temperatures from -20°C to 50°C (-4°F to 122°F).
What are the main features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support for faster connections, compatibility with Alexa and Google Assistant, and 24/7 local recording with microSD cards.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and voice control.
What is Cam Plus and what does the free trial include?Cam Plus is Wyze’s premium cloud storage and smart notification service. The free 30-day trial includes unlimited event video cloud storage and advanced notifications for people, packages, and vehicles.
Why should I choose Wyze for my smart doorbell and security camera needs?Wyze offers affordable pricing, robust weather resistance, free 30-day Cam Plus trials, smart home integration, and a user-friendly app, making it a top choice for reliable and advanced home security solutions.
Can you tell me more about the features of the Wyze Cam Pan v3?How does the motion tracking feature work on the Wyze Cam Pan v3?Do you have any ongoing sales or discounts for the Wyze Video Doorbell or cameras?
