Simplify Wyze Cam Placement with a 20ft USB Extension Cable: Extended Reach & Weather Resistant
For those seeking to simplify the placement of their Wyze Cam, the Wyze Cam USB Extension Cable - 20ft is an ideal choice. Here's why it is highly recommended:
  • Extended Reach: This 20ft cable allows you to position your Wyze Cam exactly where you need it, overcoming the limitations of shorter cables.
  • Wide Compatibility: It is compatible with a variety of Wyze Cam models, including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2, v3, and the Wyze Cam OG series.
  • Weather Resistant: With an IP67 weather rating, this cable is built to withstand various weather conditions, making it suitable for both indoor and outdoor use.
  • Easy Installation: The cable is designed for simple installation, allowing you to set up your camera quickly and efficiently.
Please note that this extension cable is intended for charging purposes only and does not support data transmission. It is compatible with any 5V/2A Wyze-branded power adapters.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?Is the Wyze Cam USB Extension Cable suitable for outdoor use in all weather conditions?Do you have any ongoing sales or discounts for the Wyze Cam USB Extension Cable?
