Wyze Battery Cam Solar Panel: No More Ladder Battery Swaps
Simple Solar Solution for Wyze Battery Cam Battery Swaps
If you're looking to avoid the hassle of climbing ladders to swap out batteries on your Wyze Battery Cam, a solar-powered solution is the perfect answer. Wyze offers a seamless way to keep your cameras powered continuously with minimal maintenance by pairing their advanced Wyze Battery Cam Pro with a dedicated solar panel accessory. This setup ensures your security cameras stay charged by harnessing the sun’s energy, eliminating frequent battery swaps and providing peace of mind.
Wyze Battery Cam Pro: Powerful, Wire-Free Security
Key Features and Benefits
  • 2.5K HDR Video Resolution: Capture crystal-clear footage with 2560 x 1440 resolution and H.264 encoding for smooth video streaming.
  • Wire-Free & No Hub Required: Completely wireless design with removable, rechargeable 6200mAh battery packs lasting up to 6 months on a single charge.
  • Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security by deterring intruders.
  • Radar + PIR Motion Detection: Advanced motion sensors provide accurate alerts and reduce false alarms.
  • Weatherproof (IP65): Durable for outdoor use in temperatures from -20°C to 50°C (-4°F to 122°F).
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for reliable performance.
  • Two-Way Audio: Communicate through the camera with a built-in speaker and microphone.
  • Local Storage & Cloud Options: Supports up to 256GB microSD cards and cloud recording with Cam Plus subscription.
  • Smart Home Integrations: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Dimensions & Design
  • Compact size (2.5 x 1.8 x 3.5 inches) and lightweight (0.94 lbs) with a matte finish.
  • Comes with a versatile wall mount for easy installation.
The Wyze Battery Cam Pro is ideal for anyone wanting high-quality, wire-free home security with flexible installation options.
Outdoor security camera mounted on a home exterior
Wyze Battery Cam Solar Panel: Hassle-Free Continuous Power
Why Choose the Wyze Solar Panel?
  • Extend Battery Life: Connects directly to your Wyze Battery Cam Pro to keep it charged using solar energy.
  • Weather Resistant (IP65): Built to withstand rain, snow, and sun exposure for reliable outdoor use.
  • Easy 360° Mount: Flexible mounting options let you position the panel for optimal sunlight anywhere around your home.
  • Long 13-Foot Power Cable: Provides versatile placement without worrying about proximity to the camera.
  • Compatibility: Works with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models.
Specifications
  • Solar Power Rating: 2.5W, 5V DC
  • Dimensions: 173 mm x 120 mm x 17 mm
  • Includes wall mount, USB-C adapter cable, screws, and quick start guide.
This solar panel accessory is the perfect companion to your Wyze Battery Cam Pro, enabling continuous recording without the need for manual battery swaps.
Wyze Battery Cam Pro + Solar Panel Bundle: The Ultimate Combo
Benefits of the Bundle
  • Combines the advanced Wyze Battery Cam Pro with the solar panel accessory for a complete, maintenance-free security solution.
  • Enjoy all the camera’s premium features plus the convenience of solar charging.
  • Save money and effort by purchasing the bundle at a discounted price compared to buying separately.
Features Recap
  • 2.5K HDR video with color night vision.
  • Integrated spotlight, siren, and radar + PIR motion detection.
  • Up to 6 months battery life with solar panel support.
  • IP65 weatherproof design for all-season outdoor use.
  • Dual-band WiFi and smart home compatibility.
The bundle is perfect for users who want a ready-to-go, wire-free security system that stays powered by the sun.
Additional Tips for Easy Battery Management
  • Removable Battery Packs: The Wyze Battery Cam Pro uses rechargeable 6200mAh battery packs that can be swapped out quickly if needed.
  • Optional Replacement Batteries: Keep spare Wyze Removable Battery Packs on hand to swap without waiting for charging.
  • Solar Panel for Continuous Power: Using the solar panel accessory drastically reduces the need for manual battery swaps, especially in sunny locations.
Conclusion
For a simple, effective solar solution to avoid climbing ladders for battery swaps on your Wyze Battery Cam, the Wyze Battery Cam Pro paired with the Wyze Battery Cam Solar Panel is the ideal choice. Whether you opt for the camera alone, the solar panel accessory, or the convenient bundle, you’ll enjoy wire-free, weatherproof security with extended battery life powered by the sun.
Product Summary
Wyze Bulb Color lifestyle image showing smart home ambiance
FeatureWyze Battery Cam ProWyze Battery Cam Solar PanelWyze Battery Cam Pro + Solar Panel
TypeCameraAccessoryCamera Bundle
Video Resolution2.5K HDR (2560 x 1440)N/A2.5K HDR (2560 x 1440)
WirelessYesN/AYes
Power SourceRemovable, Rechargeable Battery Packs (6200mAh)Solar Panel to extend battery lifeRemovable, Rechargeable Battery Packs + Solar Panel
Battery LifeUp to 6 MonthsExtends battery lifeExtended battery life via solar panel
Charging TimeApproximately 9 hoursN/AApproximately 9 hours (battery)
Weather ResistanceIP65IP65IP65
WiFi Support2.4 & 5 GHzN/A2.4 & 5 GHz
Motion DetectionRadar + PIR Motion DetectionN/ARadar + PIR Motion Detection
Integrated Spotlight & SirenYesN/AYes
Local StorageSupports up to 256 GB microSD cardsN/ASupports up to 256 GB microSD cards
Cloud StorageCam Plus subscription availableN/ACam Plus subscription available
Dimensions2.5 x 1.8 x 3.5 inchesSolar Panel: 173 mm x 120 mm x 17 mmCamera: 2.5 x 1.8 x 3.5 inches; Solar Panel: 173 mm x 120 mm x 17 mm
Weight0.94 lbsN/A0.94 lbs (camera); Solar Panel weight not specified
Mounting1/4” - 20 standard, wall mount included360° Freestyle Mount, 13 ft weatherproof cableSame as camera + solar panel mounting
PriceFrom $89.98 (1 pack)$24.99$109.98
Additional FeaturesColor Night Vision, Two-Way Audio, Bluetooth 5.1 setupWeather resistant, mountable anywhereCombination of camera and solar panel features
How does the Wyze Battery Cam Pro solar panel solution work?The Wyze Battery Cam Pro can be paired with a dedicated solar panel accessory that keeps the camera charged using solar energy. This setup eliminates the need for frequent battery swaps and ensures your security camera remains powered continuously with minimal maintenance.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, wire-free installation with a rechargeable 6200mAh battery, integrated spotlight and 100 dB siren, radar and PIR motion detection, IP65 weatherproof rating, dual-band WiFi support, two-way audio, local and cloud storage options, and compatibility with Alexa, Google Assistant, and IFTTT.
Is the Wyze Battery Cam Pro completely wireless?Yes, the Wyze Battery Cam Pro is completely wire-free and does not require a hub. It operates on removable, rechargeable battery packs that can last up to 6 months on a single charge, especially when paired with the solar panel accessory.
How does the Wyze Battery Cam Solar Panel extend battery life?The Wyze Battery Cam Solar Panel connects directly to your Wyze Battery Cam Pro and uses solar energy to keep the camera charged. This drastically reduces the need for manual battery swaps, especially in sunny locations.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is IP65 weather resistant, making it suitable for outdoor use in rain, snow, and sun exposure.
What cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models.
What is included with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel comes with a wall mount, USB-C adapter cable, screws, a 13-foot power cable for flexible placement, and a quick start guide.
What are the benefits of purchasing the Wyze Battery Cam Pro and Solar Panel bundle?The bundle combines the advanced features of the Wyze Battery Cam Pro with the convenience of the solar panel accessory, providing a maintenance-free, wire-free security solution. It also offers cost savings compared to buying the products separately.
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro’s rechargeable 6200mAh battery packs can last up to 6 months on a single charge, and even longer when used with the solar panel accessory.
Can I use spare batteries with the Wyze Battery Cam Pro?Yes, you can keep optional Wyze Removable Battery Packs on hand to quickly swap out batteries without waiting for charging, ensuring your camera remains operational at all times.
Does the Wyze Battery Cam Pro support local and cloud storage?Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB and offers cloud recording options with a Cam Plus subscription.
Is the Wyze Battery Cam Pro suitable for outdoor use?Absolutely. The Wyze Battery Cam Pro is IP65 weatherproof and designed to operate in temperatures ranging from -20°C to 50°C (-4°F to 122°F), making it ideal for all-season outdoor security.
What smart home integrations are available with the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
Can you tell me more about the features of the Wyze Battery Cam Pro?How does the solar panel connect to the Wyze Battery Cam Pro?What is the warranty policy for the Wyze Battery Cam Pro and solar panel?
