Effortless Power Solution for Wyze Cam v3 on Tall Porches: Discover the Wyze Outdoor Power Adapter
For those looking to power their Wyze Cam v3 on a tall porch, the Wyze Outdoor Power Adapter is an excellent choice. This adapter is specifically designed to work with the Wyze Cam v3, providing a reliable power source that is IP67 weather-resistant, making it suitable for outdoor use in various weather conditions. The adapter comes with a 12.5-foot cable, which should offer ample length for most porch installations. Please note that it is important to plug the adapter directly into an outdoor-rated (covered) power outlet, as using an extension cord is not recommended. This ensures the best performance and safety for your device.
Feature | Wyze Cam v3 | Wyze Outdoor Power Adapter |
Type | Camera | Accessory |
Weather Resistance | IP65 weather-resistant | IP67 weather-resistant |
Power Source | Wired (requires power adapter) | Provides power to Wyze Cam v3 |
Cable Length | 6 Feet Flat USB Cable | 12.5 ft (3.8 m) total cable length |
Compatibility | Compatible with Wyze Cam v3 | Compatible with Wyze Cam v3, v3 Pro, v4, OG series, Pan v3, and Battery Cam Pro |
Operating Temperature | -5°F - 113°F (-20°C - 45°C) | -22℉ - 122℉ (-30°C - 50°C) |
Warranty | 1-Year | 1-Year |
Additional Features | 1080p Color Night Vision, Person Detection, Motion and Sound Detection | Includes wire clips, screws, and screw anchors for easy installation |
Price | $25.98 (1 Pack, White) | $19.99 (Outdoor Adapter + L-shaped Adapter + USB-C Adapter) |
Can you tell me more about the features of the Wyze Outdoor Power Adapter?Is the Wyze Outdoor Power Adapter compatible with other Wyze camera models?What is the maximum distance I can install the Wyze Cam v3 from the power outlet using the adapter?
