For those looking to mount their Wyze Cam near an off-center window, we recommend the Wyze Cam USB Extension Cable - 20ft and the Wyze Cam Mounting Kit. Here's why these products are ideal for your setup:
- Wyze Cam USB Extension Cable - 20ft:
- Extended Reach: Enjoy the freedom of a 20ft cable, allowing you to position your camera exactly where you need it.
- Compatibility: Works seamlessly with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Weather Resistant: With an IP67 weather rating, this cable is suitable for both indoor and outdoor use.
- Wyze Cam Mounting Kit:
- Complete Setup: Includes a mounting bracket, adhesive, and a longer Micro USB cable for easy installation.
- Versatility: Compatible with Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro, making it a versatile choice for various camera models.
These accessories will help you achieve a clean and efficient setup for your Wyze Cam, ensuring optimal placement and performance.
