Enhance Home Security with Custom Motion Detection Zones on Wyze Cam v4: A Guide to Advanced Features and Setup
For those looking to enhance their home security with the Wyze Cam v4, setting up custom motion detection zones is a great way to tailor your camera's monitoring capabilities to your specific needs. The Wyze Cam v4 offers advanced features such as 2.5K QHD resolution, Enhanced Color Night Vision, and a motion-activated spotlight, making it an excellent choice for both indoor and outdoor security. With its IP65 weather resistance, you can confidently use it in various environments. Additionally, the camera supports Wi-Fi 6 and integrates seamlessly with Alexa and Google Assistant for added convenience.
Wyze Cam v4: 2.5K QHD resolution, Enhanced Color Night Vision, motion-activated spotlight, IP65 weather resistance, Wi-Fi 6 support, Alexa and Google Assistant compatibility.
Feature | Wyze Cam v4 | Wyze Cam v4 Home Security Bundle |
Resolution | 2.5K QHD | 2.5K QHD |
Color Night Vision | Yes | Yes |
Motion-Activated Spotlight | Yes | Yes |
Wi-Fi Support | Wi-Fi 6 | Wi-Fi 6 |
Alexa and Google Assistant | Compatible | Compatible |
Local Recording | 24/7 with microSD card | 24/7 with microSD card |
Weather Resistance | IP65 | IP65 |
Number of Cameras | 1 | 4 |
Included MicroSD Cards | Not included | 4x 128GB |
Price | $35.98 (1 Pack) | $169.99 |
Warranty | 1-Year | 1-Year |
How do I set up the motion-activated spotlight on the Wyze Cam v4?Can you explain how the Enhanced Color Night Vision works on the Wyze Cam v4?What are the benefits of using Wi-Fi 6 with the Wyze Cam v4?
