Effortlessly Set Up Your Wyze Cam v4 on Any Network While Traveling: A Guide to Seamless Security and Monitoring
When traveling with your Wyze Cam v4, setting it up on different networks is straightforward and convenient. The Wyze Cam v4 supports both 2.4 GHz Wi-Fi and Wi-Fi 6, ensuring compatibility with a wide range of networks. Simply connect the camera to the new network through the Wyze app on your smartphone, which is compatible with Android 9.0+ and iOS 15.0+. This flexibility allows you to maintain security and monitoring capabilities wherever you go. For those looking to enhance their security setup, consider the Wyze Cam v4 Home Security Bundle: Includes 4x Wyze Cam v4 and 4x Wyze MicroSD Card 128GB, offering comprehensive coverage and ample storage for your travels.
FeatureWyze Cam v4Wyze Cam v4 Home Security Bundle
Resolution2.5K QHD2.5K QHD
Color Night VisionYesYes
Motion-Activated SpotlightYesYes
Wi-Fi Support2.4 GHz, Wi-Fi 62.4 GHz, Wi-Fi 6
CompatibilityAlexa, Google AssistantAlexa, Google Assistant
Local RecordingMicroSD card up to 512 GB4x MicroSD Card 128GB included
Number of Cameras14
Price$35.98 (1 Pack)$169.99
Stock AvailabilityAvailableAvailable
Additional FeaturesEnhanced Two-Way Talk, Built-in SirenEnhanced Two-Way Talk, Built-in Siren
Warranty1-Year1-Year
How do I connect my Wyze Cam v4 to a new Wi-Fi network using the app?What features does the Wyze Cam v4 offer for night vision?Can I use the Wyze Cam v4 with both Android and iOS devices?
