Optimize Your Wyze Cam with a Specialized Window Mount for Glare-Free Surveillance
We recommend the Wyze Window Mount for enhancing your security setup by attaching your Wyze Cam to a window. This accessory is specifically designed to reduce glare and reflections, ensuring a clear view through glass surfaces. Here are some key features of the Wyze Window Mount:
  • Compatibility: Works with Wyze Cam v3, Cam v3 Pro, Cam v4, Wyze Cam OG, and Wyze Cam OG Telephoto.
  • Glare Reduction: Enjoy a clear view free of glare or reflection, perfect for monitoring through windows.
  • Easy Installation: Mount your camera on a glass surface effortlessly.
This mount is an excellent choice for those looking to optimize their camera's performance when placed behind a window.
What are the installation steps for the Wyze Window Mount?Can the Wyze Window Mount be used with other Wyze Cam models?How does the glare reduction feature work in the Wyze Window Mount?
