Refurbished Outdoor HD Security Cameras for Property Surveillance
Refurbished Outdoor Cameras with HD Recording for Property Surveillance
When it comes to securing your property, having a reliable outdoor camera with high-definition recording is essential. Refurbished outdoor cams offer an affordable yet powerful solution to monitor your home or business with crystal-clear video quality and smart features. Below, we explore the top Wyze refurbished outdoor cameras and accessories designed to enhance your property surveillance with HD recording capabilities.
Wyze Cam v4: Advanced 2.5K QHD Outdoor Security Camera
Crisp 2.5K QHD Video Quality
The Wyze Cam v4 delivers stunning 2.5K QHD resolution (2560x1440), providing crystal-clear footage that captures every detail around your property. Whether it’s day or night, the enhanced color night vision ensures you never miss a thing.
Weather-Resistant and Durable
Rated IP65 for weather resistance, this camera is built to withstand rain, snow, and extreme temperatures from -4ºF to 122ºF (-20ºC to 50ºC), making it perfect for year-round outdoor surveillance.
Smart Features for Ultimate Security
  • Motion-activated spotlight to deter intruders
  • 24/7 local recording with microSD card support up to 512GB
  • Wi-Fi 6 support for faster and more reliable connectivity
  • Two-way audio with a built-in 99dB siren for alerts and communication
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
Flexible Mounting Options
Mount your Wyze Cam v4 on walls, ceilings, or use the magnetic mount for easy placement and angle adjustment.
Wyze Cam Pan v3: 360° Pan and 180° Tilt Outdoor Camera
Wyze Cam Pan v3 in snowy outdoor setting Experience full coverage with the Wyze Cam Pan v3, designed for all-weather outdoor use.
Full Coverage with Pan & Tilt
The Wyze Cam Pan v3 offers a 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your property without blind spots. Its 120° field of view combined with 8x digital zoom ensures you can zoom in on suspicious activity with ease.
Durable and Weatherproof
With an IP65 rating, this camera is built to endure harsh weather conditions, from rain to snow, and operates reliably between -4ºF and 122ºF (-20ºC to 50ºC).
HD Video and Smart Alerts
  • 1080p full HD video resolution with smooth 20 fps daytime and 15 fps nighttime recording
  • Infrared night vision with 4 IR LEDs for clear black-and-white images in the dark
  • Two-way audio with noise and echo cancellation for clear communication
  • Push notifications alert you instantly when motion is detected
Easy Installation
Requires the Wyze Outdoor Power Adapter (sold separately) for safe outdoor use. Mount it on walls or ceilings with included hardware.
Cam v4 + Lamp Socket v2 Bundle: Power and Illuminate Your Outdoor Cam
Smart Power Solution for Outdoor Cameras
This bundle pairs the Wyze Cam v4 with the Lamp Socket v2, allowing you to power your camera directly from an existing lamp socket without needing an outlet. It’s perfect for locations where power outlets are scarce.
Motion-Activated Lighting
The lamp socket supports motion-activated lights and dusk-to-dawn scheduling, enhancing your property’s security by illuminating dark areas when movement is detected.
Compatibility and Convenience
  • Compatible with multiple Wyze Cam models including Cam v4, Cam v3, and Cam Pan v3
  • Connects via standard E26 lamp sockets with 120V power input
  • Recommended for use with CFL or LED bulbs under 20W (incandescent bulbs not supported)
Why Choose Refurbished Wyze Outdoor Cameras?
Refurbished Wyze outdoor cameras provide a cost-effective way to secure your property without compromising on quality or features. Each unit undergoes rigorous testing to ensure it meets Wyze’s high standards, offering you peace of mind with a 1-year warranty.
With advanced HD recording, weather resistance, smart home compatibility, and flexible installation options, these cameras are ideal for anyone looking to enhance their property surveillance affordably and effectively.
Summary of Featured Products
Product NameVideo ResolutionWeather ResistanceSpecial FeaturesPrice Range (USD)
Wyze Cam v42.5K QHDIP65Color Night Vision, Spotlight, SirenFrom $35.98
Wyze Cam Pan v31080p HDIP65360° Pan, 180° Tilt, Two-way AudioFrom $39.98
Cam v4 + Lamp Socket v2 Bundle2.5K QHDDamp Location OnlyMotion-Activated Lights, Easy Power$49.96
Enhance Your Outdoor Surveillance Today
Investing in a refurbished Wyze outdoor camera with HD recording is a smart choice for property owners who want reliable, high-quality security without breaking the bank. Whether you need wide-angle coverage, pan-tilt flexibility, or smart lighting integration, Wyze offers solutions tailored to your outdoor surveillance needs.
FeatureWyze Cam v4Wyze Cam Pan v3Cam v4 + Lamp Socket v2 Bundle
TypeWired Security CameraWired Pan & Tilt Security CameraWyze Cam v4 + Lamp Socket v2
Resolution2.5K QHD (2560x1440)Not specified (Pan v3 has 2.5K QHD sensor)2.5K QHD (Wyze Cam v4 included)
Field of View115.8° (DFOV), 98.5° (HFOV), 53.1° (VFOV)360° pan, 180° tiltSame as Wyze Cam v4
Night VisionEnhanced Color Night Vision + IR LEDsColor Night Vision with Starlight SensorSame as Wyze Cam v4
SpotlightMotion-activated spotlightNo spotlightSame as Wyze Cam v4
SirenBuilt-in 99 dB sirenNot specifiedSame as Wyze Cam v4
AudioEnhanced two-way talk, noise & echo cancellationTwo-way audioSame as Wyze Cam v4
Motion DetectionYes, with detection zonesYes, with motion tracking and detection zonesSame as Wyze Cam v4
Sound DetectionYesYesSame as Wyze Cam v4
Smoke & CO AlertsYesYesSame as Wyze Cam v4
Local StoragemicroSD card up to 512GB (sold separately)microSD card support (up to 256GB)Same as Wyze Cam v4
Cloud StorageSubscription availableSubscription availableSame as Wyze Cam v4
ConnectivityWi-Fi 6 (2.4 GHz), Bluetooth 5.2Wi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth (Lamp Socket)
Weather ResistanceIP65 (Outdoor capable)IP65 (Outdoor capable)Lamp Socket: Not weatherproof, suitable for damp locations
Power SourceWired (6-foot micro USB cable included)Wired (requires outdoor power adapter for outside)Wyze Cam v4 powered via lamp socket (no outlet needed)
Mounting OptionsStand, wall, ceiling, magnetic mountNot specifiedSame as Wyze Cam v4
Dimensions2in x 2in x 2 3/8in (Wyze Cam v4)Not specifiedLamp Socket: 56.5mm x 56.5mm x 65mm
Weight0.49 lb (222 g) (Wyze Cam v4)Not specifiedLamp Socket: 80 g
Compatible DevicesAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTCompatible with Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Special FeaturesAuto-zoom with AI, Wide Dynamic Range (WDR), Motion-activated spotlight, 8x digital zoom360° pan, 180° tilt, automatic motion tracking, Privacy ModePowers Wyze Cam v4, Motion-activated lights, Dusk to Dawn scheduling
Price$35.98 (single camera)$39.98 (single camera)$49.96 (bundle)
What are the benefits of choosing refurbished Wyze outdoor cameras for property surveillance?Refurbished Wyze outdoor cameras offer a cost-effective way to secure your property without sacrificing quality or features. Each camera undergoes rigorous testing to meet Wyze’s high standards and comes with a 1-year warranty. You get advanced HD recording, weather resistance, smart home compatibility, and flexible installation options at a more affordable price.
What video quality do Wyze refurbished outdoor cameras provide?Wyze refurbished outdoor cameras deliver high-definition video quality. The Wyze Cam v4 offers 2.5K QHD resolution (2560x1440) for crystal-clear footage, while the Wyze Cam Pan v3 provides 1080p full HD video with smooth recording both day and night.
Are Wyze refurbished outdoor cameras weather-resistant?Yes, both the Wyze Cam v4 and Wyze Cam Pan v3 are rated IP65 for weather resistance, making them suitable for outdoor use in rain, snow, and extreme temperatures ranging from -4ºF to 122ºF (-20ºC to 50ºC).
What smart features do Wyze refurbished outdoor cameras offer?Wyze refurbished outdoor cameras include smart features such as motion-activated spotlights, 24/7 local recording with microSD card support, Wi-Fi 6 connectivity, two-way audio with a built-in siren, and compatibility with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
How do I install Wyze refurbished outdoor cameras?Wyze outdoor cameras offer flexible mounting options. The Wyze Cam v4 can be mounted on walls, ceilings, or with a magnetic mount for easy placement. The Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter (sold separately) for safe outdoor use and can be mounted on walls or ceilings with included hardware.
What is the Wyze Cam Pan v3 and how does it enhance outdoor surveillance?The Wyze Cam Pan v3 is a refurbished outdoor camera with 360° horizontal pan and 180° vertical tilt, providing full coverage without blind spots. It features 1080p HD video, infrared night vision, two-way audio, and instant push notifications for detected motion, making it ideal for comprehensive property monitoring.
How does the Cam v4 + Lamp Socket v2 Bundle work for outdoor camera installation?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 directly from an existing E26 lamp socket, eliminating the need for a nearby power outlet. The lamp socket supports motion-activated lighting and dusk-to-dawn scheduling, enhancing security by illuminating dark areas when movement is detected.
Are Wyze refurbished outdoor cameras compatible with smart home systems?Yes, Wyze refurbished outdoor cameras are compatible with popular smart home systems, including Alexa, Google Assistant, and IFTTT, allowing for easy integration and voice control.
What warranty is provided with refurbished Wyze outdoor cameras?All refurbished Wyze outdoor cameras come with a 1-year warranty, ensuring peace of mind and reliable support for your property surveillance needs.
What accessories are recommended for Wyze refurbished outdoor cameras?Recommended accessories include the Wyze Outdoor Power Adapter for safe outdoor installation of the Cam Pan v3 and the Lamp Socket v2 for powering cameras from existing lamp sockets. These accessories enhance installation flexibility and security features.
Can you tell me more about the features of the Wyze Cam v4?What are the installation requirements for the Wyze Cam Pan v3?What kind of warranty do refurbished Wyze outdoor cameras come with?
