Refurbished Lightweight Cordless Handheld Vacuum with Long Battery
Refurbished Lightweight Cordless Handheld Vacuum with Long Battery Life for Portability
When it comes to portable cleaning solutions, a lightweight cordless handheld vacuum with long battery life is a must-have for effortless and efficient home maintenance. Whether you’re tackling pet hair, dust, or everyday messes, having a vacuum that combines power, portability, and convenience makes all the difference. Below, we highlight the top Wyze products designed to meet these needs, focusing on the Wyze Cordless Vacuum S and its essential accessories.
Wyze Cordless Vacuum S: Power Meets Portability
Ultra-Lightweight Design
Weighing just 2.8 pounds—lighter than a fluffy corgi puppy—this vacuum is designed for easy handling and extended use without fatigue. Its feather-light frame makes it perfect for quick cleanups or deep cleaning sessions around the house.
Industrial-Grade Suction Power
Equipped with two powerful brushless motors, the Wyze Cordless Vacuum S delivers an impressive 20,000 Pa suction power on turbo mode. This ensures thorough cleaning on all surfaces, from hardwood floors to carpets, effortlessly picking up dust, dirt, and pet hair.
Long-Lasting Interchangeable Battery
Enjoy up to 40 minutes of fade-free cleaning with the vacuum’s interchangeable lithium-ion battery. This extended runtime means you can clean your entire home without interruptions, and swapping batteries is quick and hassle-free.
Versatile Cleaning Speeds
Choose from three suction levels to match your cleaning needs:
  • Eco: 6,000 Pa for light dust and debris
  • Medium: 9,000 Pa for everyday messes
  • Turbo: 20,000 Pa for deep cleaning and stubborn dirt
Advanced Filtration System
The vacuum features a 3-stage filtration system: a cyclone separator, a metal screen for large particles, and a high-efficiency HEPA filter that removes 95% of particles smaller than 0.3 microns, ensuring cleaner air in your home.
User-Friendly Features
  • Six bright LED lights on the brush head illuminate hidden dust under furniture and in dark corners.
  • Easy one-finger dust cup release and washable filters make maintenance simple and hygienic.
  • Built-in filter brush helps keep the filter clean and efficient during use.
Wyze Cordless Vacuum S in action with pet Lightweight and pet-friendly cleaning with Wyze Cordless Vacuum S
Wyze Handheld Vacuum Filter: Keep Your Vacuum Performing Like New
To maintain peak performance and air quality, regularly replacing the Wyze Handheld Vacuum Filter is essential. Designed exclusively for the Wyze Handheld Vacuum, these filters trap fine dust and allergens, ensuring your vacuum continues to operate efficiently.
  • Available in single and 3-pack options
  • Easy to replace and washable for extended use
  • Helps prolong the life of your vacuum and maintain suction power
Why Choose Wyze for Your Cordless Vacuum Needs?
Wyze combines cutting-edge technology with user-centric design to deliver cordless vacuums that are not only powerful but also lightweight and easy to use. The Wyze Cordless Vacuum S stands out with its industrial-level suction, long battery life, and smart features like LED lighting and a multi-stage filtration system. Whether you’re a pet owner or someone who values quick and effective cleaning, this vacuum offers the perfect balance of portability and performance. Lifestyle image showing cordless vacuum cleaning under furniture Effortless cleaning with Wyze Cordless Vacuum S
Summary of Key Features
FeatureWyze Cordless Vacuum SWyze Handheld Vacuum Filter
Weight2.8 lbs (feather-light)N/A
Suction PowerUp to 20,000 PaN/A
Battery LifeUp to 40 minutes, interchangeableN/A
Filtration3-stage HEPA filtrationReplacement filter for HEPA system
LED Lighting6 bright LEDs on brush headN/A
MaintenanceWashable dust cup and filtersEasy filter replacement
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S — lightweight, powerful, and designed to keep your home spotless with ease.
Product Tags and Highlights
This selection of Wyze products offers the ideal solution for anyone seeking a refurbished lightweight cordless handheld vacuum with long battery life for maximum portability and cleaning efficiency.
TypeConnected HomeAccessories
Price$139.99 (compare at $193.99)$9.99 (1 Pack), $13.99 (3 Pack)
Battery Life40 minutes (interchangeable lithium-ion)N/A
Weight2.8 poundsN/A
MotorsTwo motors (one digital motor + one in brush)N/A
Cleaning Speeds3 speeds (Eco 6,000 Pa, Med 9,000 Pa, Turbo 20,000 Pa)N/A
LED DisplayYesN/A
LED Lights on Brush Head6 daylight-bright LEDsN/A
Filtration System3-stage (cyclone, metal screen, HEPA filter)Replacement filter for Wyze Handheld Vacuum
Filter TypeHEPA (removes 95% of particles <0.3 µm)Filter only
Dust CupEasy one-finger release, washableN/A
CompatibilityWyze Cordless Vacuum SOnly for Wyze Handheld Vacuum
Return Policy30-day hassle-free returns30-day hassle-free returns
What makes the Wyze Cordless Vacuum S a good choice for portable cleaning?The Wyze Cordless Vacuum S is ultra-lightweight at just 2.8 pounds, making it easy to carry and maneuver for quick cleanups or deep cleaning sessions. Its cordless design and long battery life provide maximum portability and convenience for efficient home maintenance.
How powerful is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features two brushless motors that deliver up to 20,000 Pa of industrial-grade suction power on turbo mode. This ensures thorough cleaning on all surfaces, including hardwood floors, carpets, and pet areas.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers up to 40 minutes of fade-free cleaning with its interchangeable lithium-ion battery. The battery is easy to swap, allowing for uninterrupted cleaning sessions.
What filtration system does the Wyze Cordless Vacuum S use?The vacuum uses a 3-stage filtration system, including a cyclone separator, a metal screen for large particles, and a high-efficiency HEPA filter that removes 95% of particles smaller than 0.3 microns. This ensures cleaner air in your home.
Are the filters for the Wyze Cordless Vacuum S washable and replaceable?Yes, the Wyze Cordless Vacuum S features washable filters and an easy one-finger dust cup release for simple maintenance. Replacement filters are available and help maintain peak performance and air quality.
What are the cleaning modes available on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers three suction levels: Eco (6,000 Pa) for light dust, Medium (9,000 Pa) for everyday messes, and Turbo (20,000 Pa) for deep cleaning and stubborn dirt.
How does the Wyze Cordless Vacuum S help with cleaning in dark or hard-to-reach areas?The vacuum is equipped with six bright LED lights on the brush head, illuminating hidden dust under furniture and in dark corners for more effective cleaning.
Why should I regularly replace the Wyze Handheld Vacuum Filter?Regularly replacing the Wyze Handheld Vacuum Filter ensures your vacuum maintains strong suction power and continues to trap fine dust and allergens, prolonging the life of your vacuum and improving air quality.
What are the main benefits of choosing Wyze for cordless vacuum needs?Wyze cordless vacuums combine powerful suction, lightweight design, long battery life, advanced HEPA filtration, and user-friendly features like LED lighting and easy maintenance, making them ideal for pet owners and anyone seeking efficient, portable cleaning solutions.
What are the key features of the Wyze Cordless Vacuum S?How do I maintain the Wyze Cordless Vacuum S for optimal performance?What is the warranty policy for the Wyze Cordless Vacuum S?
