Reduce Glare on Double-Pane Glass with Wyze Window Mount for Clear Surveillance
For those looking to enhance their exterior security while minimizing glare on reflective double-pane glass, the Wyze Window Mount is an excellent solution. This accessory allows you to attach your Wyze Cam v3, v3 Pro, v4, or Cam OG series directly to a glass surface, ensuring a clear view free of glare or reflection. By using this mount, you can enjoy uninterrupted surveillance without the common issues of glare that often accompany window-mounted cameras.
How does the Wyze Window Mount attach to the glass surface?Can the Wyze Window Mount be used with other Wyze Cam models besides the ones mentioned?What are the benefits of using the Wyze Window Mount for outdoor security?
