Effortlessly Transfer Your Wyze Camera Between Rooms with Quick Release Window Mounts
We recommend the Wyze Window Mount and the Wyze Cam Mounting Kit for your needs. Here's why these products are ideal for transferring your camera between rooms:
  • Wyze Window Mount:
  • Compatible with Wyze Cam v3, v3 Pro, v4, and the Wyze Cam OG series.
  • Allows you to mount your camera on a glass surface, providing a clear view free of glare or reflection.
  • Easy to attach and detach, making it convenient for quick transfers between rooms.
  • Wyze Cam Mounting Kit:
  • Compatible with Wyze Cam v2, v3, and v3 Pro.
  • Includes a mounting bracket, adhesive, and a longer Micro USB cable for flexible installation.
  • Provides a secure and stable mount, ensuring your camera stays in place during transfers.
These accessories will help you easily and efficiently move your Wyze cameras between different locations in your home.
FeatureWyze Window MountWyze Cam Mounting Kit
CompatibilityWyze Cam v3, v3 Pro, v4, Wyze Cam OG seriesWyze Cam v2, v3, v3 Pro
Mounting SurfaceGlass surface, reduces glare and reflectionWall mounting with bracket and adhesive
Included AccessoriesNot specifiedMounting bracket, adhesive, longer Micro USB cable
Price$4.99$5.99
Stock AvailabilityAvailableAvailable
CollectionsCamera Accessories, Best Sellers, Top SellersCamera Accessories, Smart Camera Accessories, Top Sellers
Return PolicyProducts of No ReturnProducts of No Return
InstallationEasy to attach and detach for quick transfersSecure and stable mount with included accessories
Can you tell me more about the Wyze Cam Mounting Kit and its features?Is the Wyze Window Mount easy to install and remove?What is the warranty policy for the Wyze Window Mount?
