How to Activate Privacy Mode on Wyze Cam v4: Temporarily Disable Recording for Enhanced Privacy
For those looking to temporarily disable recording on the Wyze Cam v4, you can easily activate privacy mode. This feature allows you to pause the camera's recording and monitoring functions, ensuring your privacy when needed. The Wyze Cam v4 offers a range of advanced features, including crystal-clear 2.5K QHD resolution, Enhanced Color Night Vision, and a motion-activated spotlight, making it a top choice for home security. With its compatibility with Alexa and Google Assistant, you can conveniently control your camera settings, including privacy mode, using voice commands.
How do I activate privacy mode on the Wyze Cam v4?What are the advanced features of the Wyze Cam v4?Can I control the Wyze Cam v4 with voice commands?
