Prevent Data Corruption with Reliable Wyze-Compatible MicroSD Cards for Seamless Security
If you're looking for a dependable memory card to prevent data corruption and ensure smooth operation with your Wyze devices, the Wyze MicroSD Card is an excellent choice. Here are some key features:
  • Continuous Recording and Time Lapses: Unlock continuous recording and time lapses for your Wyze Cams, ensuring you never miss a moment.
  • Multiple Storage Options: Available in 256GB, 128GB, and 32GB sizes, catering to different storage needs.
  • High Performance: Class 10 and UHS-3 (U3) for 128GB and 256GB variants, ensuring fast read and write speeds.
  • Compatibility: Works seamlessly with most Wyze Cams, allowing for easy setup and use.
Additionally, if you're interested in enhancing your home security, consider the Secure Entry Doorbell v2 Starter Kit and the Wyze Video Doorbell v2:
  • Secure Entry Doorbell v2 Starter Kit: Includes the Wyze Doorbell v2, a 128GB MicroSD card, and Wyze Lock Bolt, providing a comprehensive security solution.
  • Wyze Video Doorbell v2: Offers 2K video resolution, local microSD storage, two-way audio, and motion-activated voice deterrence, ensuring you can monitor your front door with clarity and detail.
These products are designed to work together to provide a robust and reliable security system for your home.
FeatureWyze MicroSD CardSecure Entry Doorbell v2 Starter KitWyze Video Doorbell v2
TypeAccessoriesCamerasCameras
Storage Options256GB, 128GB, 32GBIncludes 128GB MicroSD cardSupports up to 256GB microSD in FAT32 format
Video ResolutionN/A2K Video Resolution2K (2048 x 1536)
AudioN/ATwo-way audioTwo-way audio
Motion DetectionN/AMotion-Activated Voice DeterrenceMotion-Activated Voice Deterrence
Local StorageYesYesYes
Cloud StorageN/AAvailable with Wyze Security PlanAvailable with Wyze Security Plan
CompatibilityWyze CamsWorks with existing Doorbell ChimeWorks with Alexa, Google Assistant, IFTTT
Price$29.99 (256GB), $16.99 (128GB), $8.99 (32GB)$141.95$39.94
WarrantyN/A1-year1-year
CollectionsTop Sellers, Quick Order, All AccessoriesWyze Week, Top Sellers, Quick Order, BundlesWyze Week, Quick Order, Buy with Prime
Additional FeaturesContinuous recording, Time lapsesIncludes Wyze Lock Bolt, 3-6 seconds of pre-roll recordingReal-time alerts, Head-To-Toe Viewing
What are the different storage options available for the Wyze MicroSD Card?Can you explain how the continuous recording feature works with Wyze Cams?What is the warranty policy for the Wyze MicroSD Card?
