For those looking to extend the reach of their Wyze Cam mounted on a tall tripod, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here’s why this product stands out:
- Extended Reach: With a length of 20 feet, this cable provides ample length to position your camera exactly where you need it, even on a tall tripod.
- Compatibility: It is designed to work seamlessly with a variety of Wyze Cam models, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Weather Resistant: The cable has an IP67 weather rating, making it suitable for both indoor and outdoor use, ensuring durability in various weather conditions.
- Easy Installation: The cable is easy to install, allowing you to set up your camera quickly and efficiently.
This extension cable is perfect for those who need flexibility in camera placement without compromising on power supply.
