Understanding Power Requirements for Products
To ensure your devices are powered correctly, it's important to know the specific power requirements for each product. For instance, the Wyze Cam Floodlight Plug-In Mount requires a power input of 110-120V AC and should be connected to a GFCI protected outlet, which is standard for most residential homes in the US. If you're considering other Wyze products, such as the Wyze Cam Floodlight Pro, it also requires a hardwired power supply of 110-120V AC. For those interested in smart home lighting, the Wyze Light Strip operates with an adapter input of 100-240V, 50/60 Hz, making it versatile for various power settings. These specifications ensure that your Wyze products function optimally and safely in your home.
FeatureWyze Light StripWyze Cam Floodlight Plug-In MountWyze Cam Floodlight Pro
TypeConnected HomeCamerasCameras
Power Input100-240V, 50/60 Hz110-120V ACHardwired 110-120V AC
Length16.4 ft or 32.8 ft20 ft power cordN/A
Colors16 million colorsN/AN/A
UsageIndoor use onlyOutdoor safeOutdoor safe
Connectivity802.11 b/g/n, 2.4 GHz, BluetoothN/A802.11 b/g/n, 2.4 GHz & 5 GHz dual-band
FeaturesMusic Mode, Sun Match, Trimmable DesignEasy to install, No junction box required180° wide-angle lens, 2.5K QHD video, 3000 lumen LED lights, AI motion detection
Operating Temperature-4°F to 122°F (-20°C to 50°C)-22°F to 122°F-4°F to 140°F (-20°C to 60°C)
WarrantyN/AN/A1-Year
Additional FeaturesVoice Control, Vacation Mode, Sleep RoutinesCompatible with Wyze Floodlights, Velcro cable strap includedColor Night Vision, Integrations with Alexa, Google Assistant, IFTTT
Life Expectancy25,000 hoursN/AN/A
Weather RatingNot weatherproofWeather-resistantIP65
Price$19.99 (16.4 ft), $35.99 (32.8 ft)$19.98$129.98 (White), $119.98 (Black)
Stock AvailabilityAvailableBlack available, White not availableAvailable
If you would like more help, you can chat with an agent via our Wyze Support chat.
What are the power input requirements for the Wyze Cam Floodlight Pro?How long does it take to install the plug-in mount?Should I connect the plug-in mount to a power source before installing the floodlight camera?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
