Wyze Cam Pan v3: Best Pan Tilt Indoor Camera with Night Vision
Discover the Wyze Cam Pan v3: The Ultimate Pan Tilt Indoor Camera with Seamless Day to Night Vision
When it comes to indoor security cameras that offer smooth pan and tilt functionality combined with reliable day-to-night vision, the Wyze Cam Pan v3 stands out as a top choice. Designed for both indoor and outdoor use, this camera delivers 360° horizontal and 180° vertical coverage, ensuring no blind spots in your home or office. Its advanced night vision capabilities make it an ideal solution for continuous monitoring, effortlessly transitioning from bright daylight to low-light or dark environments.
Wyze Cam Pan v3: Key Features and Specifications
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 offers a complete 360-degree horizontal rotation and 180-degree vertical tilt, allowing you to monitor every corner of your room without missing a thing. With a rotation speed of up to 110° per second, you can quickly scan your space or set automated patrols for comprehensive surveillance.
Crisp 1080p HD Video Quality
Equipped with a 1/2.9" CMOS image sensor, the camera streams clear 1080p Full HD video at 20 frames per second during the day and 15 frames per second at night. The 120° field of view combined with 8x digital zoom lets you focus on important details with ease.
Advanced Night Vision with IR LEDs
The Wyze Cam Pan v3 features 4 infrared LEDs (850 nm) that provide sharp black-and-white night vision. This ensures your home stays protected even in complete darkness. The camera automatically switches between day and night modes, delivering consistent video quality around the clock.
Durable and Weather Resistant
With an IP65 rating, the Pan v3 is built to withstand dust and water, making it suitable for indoor and outdoor environments. For outdoor use, pairing it with the Wyze Outdoor Power Adapter (sold separately) ensures safe and reliable operation.
Two-Way Audio with Noise Cancellation
Stay connected with your home or pets through the built-in speaker and microphone. The camera supports two-way audio with noise and echo cancellation, allowing clear conversations or alerts directly from your smartphone.
Smart Home Integration and Connectivity
Compatible with Alexa, Google Assistant, and IFTTT, the Wyze Cam Pan v3 fits seamlessly into your smart home ecosystem. It connects via 2.4 GHz Wi-Fi (802.11 b/g/n) and supports microSD cards up to 256 GB for local storage.
Compact and Stylish Design
Available in matte black or white polycarbonate finishes, the camera measures 124mm x 60mm x 63mm and weighs just 320 grams, making it easy to mount discreetly anywhere in your home.
"Wyze Cam Pan v3 combines powerful pan-tilt mechanics with reliable night vision, making it a versatile security solution for any indoor space."
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weather resistant for indoor/outdoor use
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Experience
For those looking to maximize their security setup, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera with added value. This bundle includes:
  • Wyze Cam Pan v3 camera (Black or White)
  • 6-foot micro USB cable and power adapter
  • Mounting kit and quick start guide
  • 30-day Cam Plus subscription for advanced cloud storage and AI detection features
Color Night Vision for Clearer Nighttime Footage
This bundle version supports color night vision, enhancing visibility in low-light conditions with vivid colors instead of traditional black-and-white infrared images. This feature is perfect for identifying people, pets, or objects more clearly at night.
Push Notifications and Smart Alerts
Receive instant push notifications on your phone when motion or sound is detected. The Cam Plus subscription unlocks person detection and package alerts, reducing false alarms and keeping you informed of important events.
Easy Setup and Compatibility
The bundle is compatible with Android 9.0+ and iOS 15.0+ devices, ensuring smooth app integration and remote control. It also supports Alexa, Google Assistant, and IFTTT for voice commands and automation.
"Get peace of mind with enhanced cloud features and color night vision in the Wyze Cam Pan v3 bundle."
Why Choose Wyze Cam Pan v3 for Your Indoor Security?
  • Seamless Day to Night Transition: Automatically switches between bright daytime video and infrared night vision with 4 IR LEDs, ensuring 24/7 monitoring without interruption.
  • Full Room Coverage: Pan and tilt capabilities cover every angle, eliminating blind spots.
  • Smart Home Ready: Works with popular voice assistants and automation platforms.
  • Durable and Weatherproof: IP65 rating means it can handle indoor and outdoor environments.
  • Two-Way Audio: Communicate directly through the camera with noise and echo cancellation for clear sound.
  • Expandable Storage: Supports up to 256 GB microSD cards for local video storage without monthly fees.
Additional Accessories for Wyze Cam Pan v3
Wyze Cam Pan v3 Skins by dBrand
Customize and protect your camera with stylish vinyl skins available in Green Camo and Triple Black. These skins provide scratch protection and a flawless fit, allowing your camera to blend seamlessly with your décor.
Wyze Cam Pan v3 USB Cable
Keep your camera powered with an official replacement USB cable designed specifically for the Pan v3, ensuring reliable connectivity and power supply.
Pan v3 + Lamp Socket v2 Bundle
Power your Wyze Cam Pan v3 through a lamp socket without needing a dedicated outlet. This bundle is perfect for smart lighting setups and offers easy installation with compatibility for CFL or LED bulbs under 20W.
Experience Clear, Smart, and Reliable Indoor Security with Wyze Cam Pan v3
Whether you want to monitor your home, keep an eye on pets, or secure your office, the Wyze Cam Pan v3 delivers exceptional pan-tilt coverage, crisp 1080p video, and advanced night vision that transitions effortlessly from day to night. Its smart features and durable design make it a versatile choice for any indoor environment. Two-way audio feature with pet interaction Stay connected with two-way audio for real-time communication
Feature / ProductWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundleWyze Cam Pan v3 Skins by dBrand (Skin Only)Wyze Cam Pan v3 USB CablePan v3 + Lamp Socket v2 Bundle
TypeCameraCamera BundleAccessory (Skin)Replacement PartBundle (Camera + Lamp Socket)
Price$39.98 (1 Pack)$39.98$11.98$1.99$53.96
Color VariantsBlack, WhiteBlack, WhiteGreen Camo, Triple BlackN/ABlack, White
Pack Options1, 2, 3 PacksSingle camera onlySingle skinSingle cableSingle bundle
Weather ResistanceIP65 rated (outdoor ready with adapter)IP65 rated (outdoor ready with adapter)Not applicableNot applicableCamera: IP65 with adapter; Lamp Socket: Not weatherproof, suitable for damp locations
Outdoor UseRequires Wyze Outdoor Power Adapter (sold separately)Requires Wyze Outdoor Power Adapter (sold separately)N/AN/AYes, with included lamp socket power option
Pan & Tilt Coverage360° pan, 180° tilt360° pan, 180° tiltN/AN/A360° pan, 180° tilt (camera included)
Motion TrackingYesYesN/AN/AYes (camera included)
Two-Way AudioYesYesN/AN/AYes (camera included)
Color Night VisionYes (Starlight Sensor)Yes (Starlight Sensor)N/AN/AYes (camera included)
Cam Plus SubscriptionOptional, not includedIncluded free 30 days, then $2.99/month/cam auto-renewN/AN/AOptional, not included
Custom Detection ZonesYesYesN/AN/AYes (camera included)
Smoke & CO AlertsYesYesN/AN/AYes (camera included)
Included ItemsCamera, USB cableCamera, USB cable, 30-day Cam Plus trial1x Skin, Installation instructionsUSB cableCamera, Lamp Socket v2
Material / BuildPolycarbonate bodyPolycarbonate bodyStylish vinyl skinUSB cablePolycarbonate & Plastic (lamp socket)
Dimensions (Lamp Socket)N/AN/AN/AN/A56.5mm x 56.5mm x 65mm
Weight (Lamp Socket)N/AN/AN/AN/A80 g
Power Input (Lamp Socket)N/AN/AN/AN/A120V~, 60Hz
Connectivity (Lamp Socket)Wi-Fi 2.4 GHzWi-Fi 2.4 GHzN/AN/AWi-Fi 2.4 GHz, Bluetooth
Warranty1 Year1 YearN/AN/A1 Year
Special NotesOutdoor use requires separate power adapterOutdoor use requires separate power adapterProtects device, prevents scratchesReplacement USB cable for Pan v3Incandescent bulbs not supported; use CFL or LED under 20W
What is the Wyze Cam Pan v3 and what makes it unique?The Wyze Cam Pan v3 is a versatile indoor and outdoor security camera featuring 360° pan and 180° tilt for full room coverage. It stands out with its seamless day-to-night vision, advanced night vision capabilities, and smart home integration, making it ideal for comprehensive home or office monitoring.
Does the Wyze Cam Pan v3 support both indoor and outdoor use?Yes, the Wyze Cam Pan v3 is designed for both indoor and outdoor environments. With an IP65 weather-resistant rating, it can withstand dust and water, making it suitable for various locations around your home or office.
What video quality does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 streams crisp 1080p Full HD video using a 1/2.9" CMOS image sensor. It delivers 20 frames per second during the day and 15 frames per second at night, ensuring clear footage at all times.
How does the night vision work on the Wyze Cam Pan v3?The Wyze Cam Pan v3 features 4 infrared LEDs (850 nm) for sharp black-and-white night vision, automatically switching between day and night modes. The Cam Plus bundle also offers color night vision for enhanced visibility in low-light conditions.
Can I use the Wyze Cam Pan v3 with Alexa or Google Assistant?Yes, the Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, allowing you to integrate it seamlessly into your smart home ecosystem for voice commands and automation.
Does the Wyze Cam Pan v3 support local video storage?Yes, the Wyze Cam Pan v3 supports microSD cards up to 256 GB for local video storage, enabling you to record and review footage without monthly fees.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The bundle includes the Wyze Cam Pan v3 camera (in black or white), a 6-foot micro USB cable and power adapter, a mounting kit, a quick start guide, and a 30-day Cam Plus subscription for advanced cloud storage and AI detection features.
What are the benefits of the Cam Plus subscription with the Wyze Cam Pan v3?The Cam Plus subscription provides advanced features such as color night vision, person detection, package alerts, and enhanced cloud storage. It also enables instant push notifications for motion or sound detection, reducing false alarms.
How does two-way audio work on the Wyze Cam Pan v3?The Wyze Cam Pan v3 is equipped with a built-in speaker and microphone, supporting two-way audio with noise and echo cancellation. This allows you to communicate clearly with people or pets through the camera using your smartphone.
What accessories are available for the Wyze Cam Pan v3?Available accessories include Wyze Cam Pan v3 Skins by dBrand for customization and protection, an official replacement USB cable, and the Pan v3 + Lamp Socket v2 Bundle for powering the camera through a lamp socket.
What devices are compatible with the Wyze Cam Pan v3 app?The Wyze Cam Pan v3 app is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher, ensuring smooth integration and remote control.
How easy is it to set up the Wyze Cam Pan v3?The Wyze Cam Pan v3 is easy to set up with the included mounting kit and quick start guide. It connects via 2.4 GHz Wi-Fi and can be controlled through the Wyze app for convenient monitoring and configuration.
What are the color and design options for the Wyze Cam Pan v3?The Wyze Cam Pan v3 is available in matte black or white polycarbonate finishes. It features a compact and stylish design, measuring 124mm x 60mm x 63mm and weighing 320 grams, making it easy to mount discreetly.
What are the key features of the Wyze Cam Pan v3?Can the Wyze Cam Pan v3 be used outdoors?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Pan v3?
