Wyze Cam Pan v3: Pan & Tilt Camera with Two-Way Audio for Kids
Pan and Tilt Camera with Two-Way Audio for Monitoring Kids in the Playroom: Wyze Cam Pan v3
When it comes to keeping a watchful eye on your kids in the playroom, a reliable pan and tilt camera with two-way audio is essential. The Wyze Cam Pan v3 stands out as a top choice, offering comprehensive coverage, crystal-clear video, and seamless communication capabilities. Whether you want to monitor playtime or interact with your children remotely, this camera delivers exceptional performance and smart features tailored for indoor use.
Wyze Cam Pan v3: Ultimate 360° Pan and 180° Tilt Monitoring
The Wyze Cam Pan v3 is a redesigned indoor/outdoor camera that provides a full 360° horizontal pan and 180° vertical tilt, ensuring no corner of the playroom goes unseen. Its 1080p Full HD resolution captures sharp, detailed video, while the 120° field of view offers a wide perspective to cover large areas effortlessly.
  • Two-Way Audio with Noise & Echo Cancellation: Built-in microphone and speaker allow you to listen and talk to your kids in real-time, making it perfect for interactive monitoring.
  • Night Vision: Equipped with 4 IR LEDs (850 nm), the camera ensures clear black-and-white video in low light, so you can keep an eye on your children even after lights out.
  • Color Night Vision: Unique to the Pan v3, it offers color video in dim lighting, enhancing visibility and detail.
  • Fast Rotation Speed: The camera can pan up to 110° per second, quickly following movement across the room.
  • Smart Alerts: Receive push notifications on your phone when motion or sound is detected, keeping you informed instantly.
  • Storage Options: Supports up to 256 GB microSD cards for local recording, plus cloud storage options.
  • Connectivity: Works on 2.4 GHz Wi-Fi networks and integrates with Alexa, Google Assistant, and IFTTT for smart home compatibility.
  • Durability: IP65 weather resistance rating means it can be used indoors or outdoors (with the appropriate power adapter), making it versatile beyond the playroom.
The camera’s compact size (124mm x 60mm x 63mm) and sleek matte finish in black or white blend seamlessly into any room décor.
“Wyze Cam Pan v3 offers peace of mind with its wide coverage and two-way audio, perfect for parents wanting to stay connected with their kids from anywhere.”
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 - Weather resistant and versatile
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Monitoring Experience
For those looking to maximize the value and features of the Wyze Cam Pan v3, the 30-Day Cam Plus Bundle is an excellent option. This bundle includes the camera along with a 30-day trial of Cam Plus, Wyze’s advanced subscription service that unlocks:
  • Person Detection: Get alerts specifically when a person is detected, reducing false alarms.
  • Motion Tracking: The camera automatically follows moving subjects, ensuring your kids stay in frame.
  • Extended Video History: Access continuous video recordings for 30 days, perfect for reviewing past events.
This bundle is ideal for parents who want enhanced security and monitoring capabilities without additional setup complexity.
Power Your Pan v3 Anywhere with the Lamp Socket v2 Bundle
The Pan v3 + Lamp Socket v2 Bundle offers a smart solution for powering your Wyze Cam Pan v3 without needing a traditional outlet. This lamp socket adapter fits into any standard E26 light socket, allowing you to:
  • Power the camera directly from a lamp socket, freeing up outlets and enabling flexible placement.
  • Use with CFL or LED bulbs under 20W (incandescent bulbs are not recommended due to thermal limits).
  • Compatible with multiple Wyze cameras including Pan v3, v3 Pro, and OG models.
This bundle is perfect for parents who want to install the camera in unconventional spots in the playroom or other rooms without extra wiring hassle.
Why Choose Wyze Cam Pan v3 for Playroom Monitoring?
  • Comprehensive Coverage: Pan and tilt functionality means you can see every angle of the playroom.
  • Two-Way Audio: Talk to your kids, soothe them, or give instructions remotely.
  • High-Quality Video: Crisp 1080p HD with color night vision ensures clear visuals day and night.
  • Smart Alerts & Integration: Stay connected with real-time notifications and smart home compatibility.
  • Durability & Flexibility: Indoor/outdoor use with weather resistance and multiple power options.
Two-way audio interaction with pet Stay connected with two-way audio for interactive monitoring
Summary of Key Specifications
FeatureWyze Cam Pan v3
Video Resolution1920 x 1080 (1080p Full HD)
Pan Range360° horizontal
Tilt Range180° vertical
Field of View120° FOV
Night Vision4 IR LEDs + Color Night Vision
AudioBuilt-in speaker & microphone, 2-way audio with noise & echo cancellation
Connectivity802.11 b/g/n 2.4 GHz Wi-Fi
StorageUp to 256 GB microSD + cloud options
Dimensions124mm x 60mm x 63mm
Weight11.29 oz (320 g)
Weather ResistanceIP65 rated (outdoor use with adapter)
CompatibilityAndroid 9.0+, iOS 15.0+, Alexa, Google Assistant, IFTTT
Warranty1 Year
Enhance Your Monitoring Setup
Consider pairing your Wyze Cam Pan v3 with accessories like the Lamp Socket v2 for flexible power options or the 30-Day Cam Plus Bundle for advanced monitoring features. These additions make it easier than ever to keep your kids safe and connected in the playroom.
By choosing the Wyze Cam Pan v3 and its bundles, you get a versatile, high-quality pan and tilt camera with two-way audio that’s perfect for monitoring your children’s playroom — giving you peace of mind and the ability to interact anytime, anywhere.
FeatureWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundlePan v3 + Lamp Socket v2 Bundle
Product DescriptionRedesigned indoor/outdoor 360° pan and 180° tilt security camera, IP65 weather resistant. Outdoor use requires Wyze Outdoor Power Adapter (sold separately).Same as Wyze Cam Pan v3 plus 30-day free trial of Cam Plus subscription (unlimited event video cloud storage, advanced notifications). Outdoor use requires Wyze Outdoor Power Adapter (sold separately).Wyze Cam Pan v3 bundled with Lamp Socket v2, allowing power without an outlet. Lamp socket suitable for damp locations, not weatherproof.
Pan & Tilt Coverage360° pan, 180° tilt360° pan, 180° tilt360° pan, 180° tilt (camera included)
Weather ResistanceIP65 (weather resistant)IP65 (weather resistant)Camera IP65; Lamp Socket not weatherproof, suitable for damp locations
Outdoor UseRequires Wyze Outdoor Power Adapter (sold separately)Requires Wyze Outdoor Power Adapter (sold separately)Lamp Socket powers camera without outlet; lamp socket not weatherproof
Cam Plus SubscriptionOptional, not includedIncluded 30-day free trial, auto-renews at $2.99/month/camNot included
Price$39.98 (1 Pack)$39.98 (includes 30-day Cam Plus trial)$53.96 (bundle price)
Color VariantsBlack, WhiteBlack, WhiteBlack, White
Pack Options1 Pack, 2 Pack, 3 Pack (varies)Single unit onlySingle unit (camera + lamp socket)
Lamp Socket FeaturesN/AN/AE26 socket, 120V~, 60Hz, max 20W lamp power, suitable for CFL/LED bulbs only, not incandescent
ConnectivityWi-Fi 2.4 GHz (802.11 b/g/n), BluetoothWi-Fi 2.4 GHz (802.11 b/g/n), BluetoothWi-Fi 2.4 GHz (802.11 b/g/n), Bluetooth (camera); lamp socket no wireless
Dimensions (Lamp Socket)N/AN/A56.5mm x 56.5mm x 65mm
Weight (Lamp Socket)N/AN/A80 g
Operating TemperatureNot specifiedNot specified-4°F to 120°F (-20°C to 50°C)
Warranty1 Year1 Year1 Year
Additional FeaturesAutomatic motion tracking, Privacy Mode, Two-way audio, Color Night Vision, Pan Scan™ waypoints, Smoke & CO alertsSame as Wyze Cam Pan v3 plus Cam Plus advanced notifications (crying baby, barking pet, person/package/vehicle detection)Same camera features plus lamp socket powers camera without outlet, motion-activated lights not specified for socket
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What makes the Wyze Cam Pan v3 ideal for monitoring kids in the playroom?The Wyze Cam Pan v3 is perfect for playroom monitoring due to its 360° pan and 180° tilt capabilities, 1080p Full HD video, two-way audio with noise and echo cancellation, and smart alerts. These features ensure you can see every corner, communicate with your kids in real-time, and receive instant notifications of any activity.
Does the Wyze Cam Pan v3 have two-way audio for communicating with my children?Yes, the Wyze Cam Pan v3 features built-in two-way audio with noise and echo cancellation, allowing you to listen and talk to your kids in real-time, making it easy to interact or provide instructions remotely.
Can the Wyze Cam Pan v3 be used at night or in low-light conditions?Absolutely. The Wyze Cam Pan v3 is equipped with 4 IR LEDs for clear black-and-white night vision and also offers color night vision, providing enhanced visibility and detail even in dim lighting.
What storage options are available for the Wyze Cam Pan v3?The Wyze Cam Pan v3 supports local storage with microSD cards up to 256 GB and also offers cloud storage options, giving you flexibility in how you save and access your video recordings.
Is the Wyze Cam Pan v3 compatible with smart home systems?Yes, the Wyze Cam Pan v3 works with Alexa, Google Assistant, and IFTTT, allowing seamless integration into your smart home setup for voice control and automation.
Can the Wyze Cam Pan v3 be used outdoors as well as indoors?Yes, the Wyze Cam Pan v3 has an IP65 weather resistance rating, making it suitable for both indoor and outdoor use when paired with the appropriate power adapter.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera and a 30-day trial of Cam Plus, which unlocks advanced features like person detection, motion tracking, and extended 30-day video history.
How does the Lamp Socket v2 Bundle enhance the Wyze Cam Pan v3 setup?The Pan v3 + Lamp Socket v2 Bundle allows you to power your camera directly from a standard E26 light socket, freeing up outlets and enabling flexible placement in areas without traditional power sources. It is compatible with CFL or LED bulbs under 20W.
What are the key technical specifications of the Wyze Cam Pan v3?The Wyze Cam Pan v3 features 1080p Full HD video resolution, 360° pan, 180° tilt, 120° field of view, night vision with 4 IR LEDs and color night vision, two-way audio, 2.4 GHz Wi-Fi connectivity, up to 256 GB microSD storage, IP65 weather resistance, and compatibility with Android, iOS, Alexa, Google Assistant, and IFTTT.
Does the Wyze Cam Pan v3 offer smart alerts for motion and sound?Yes, the Wyze Cam Pan v3 provides smart alerts by sending push notifications to your phone when motion or sound is detected, ensuring you are always informed of activity in the playroom.
Is the Wyze Cam Pan v3 easy to install and blend into home décor?Yes, the Wyze Cam Pan v3 has a compact size and a sleek matte finish available in black or white, making it easy to install and blend seamlessly into any room décor.
What are the key features of the Wyze Cam Pan v3 that make it suitable for monitoring kids?Can the Wyze Cam Pan v3 be used outdoors, and what are its weather resistance capabilities?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Pan v3?
