Outdoor Wyze Pan Camera with Power Adapter and MicroSD Card
When it comes to securing your outdoor spaces, Wyze offers some of the most versatile and reliable cameras designed to keep an eye on your property day and night. If you're searching for an
outdoor Wyze Pan camera bundled with a power adapter and a microSD card, this guide highlights the best options to meet your needs, featuring the
Wyze Cam Pan v3,
Wyze Cam v4 with free 32GB MicroSD card, and the essential
Wyze MicroSD Card accessory.
Wyze Cam Pan v3: The Ultimate Outdoor Pan & Tilt Security Camera
Weather-Resistant and Durable for Outdoor Use
The Wyze Cam Pan v3 is a fully
IP65 weather-resistant camera, making it perfect for outdoor environments. Whether rain, snow, or shine, this camera is built to withstand the elements and keep your home secure.
360° Pan and 180° Tilt Coverage
Enjoy complete coverage with the camera’s ability to pan 360 degrees and tilt 180 degrees. This wide range allows you to monitor every corner of your yard or property without blind spots.
Motion Tracking and Smart Alerts
Wyze Cam Pan v3 automatically detects motion, follows the movement quietly, and records it. This feature ensures you never miss any suspicious activity. Plus, it sends instant alerts to your phone for motion or sound detection.
Color Night Vision and Enhanced Image Quality
Equipped with a Starlight Sensor, the Pan v3 delivers
color night vision for clear, vibrant images even in low light. This is a significant upgrade over traditional black-and-white night vision, providing more detail when it matters most.
Two-Way Audio and Privacy Mode
Communicate directly through the camera with two-way audio, perfect for greeting visitors or warding off intruders. When you want privacy, activate Privacy Mode to turn the camera’s view downward and disable recording.
Requires Wyze Outdoor Power Adapter
For safe and continuous outdoor use, the Wyze Cam Pan v3 requires the
Wyze Outdoor Power Adapter + L-shaped MicroUSB (sold separately), ensuring reliable power supply in all weather conditions.
Wyze Cam Pan v3 in snowy outdoor setting, showcasing weather resistance and robust design.
Wyze Cam v4 + FREE 32GB MicroSD Card: Crystal Clear Outdoor Security
Stunning 2.5K QHD Resolution
Wyze Cam v4 offers the clearest image quality Wyze has ever produced with
2.5K Quad HD resolution. This means sharper, more detailed video footage to better identify faces, license plates, and other important details.
Enhanced Color Night Vision with Spotlight
Unlike many outdoor cameras, the Wyze Cam v4 features
enhanced color night vision combined with a motion-activated spotlight. This powerful duo illuminates dark areas, providing vibrant color video even at night.
Continuous 24/7 Local Recording
With the included
free 32GB MicroSD card, you can record continuously and store footage locally without relying solely on cloud storage. This ensures you have access to your video anytime, even without internet.
Wi-Fi 6 Support and Smart Home Integration
Wyze Cam v4 supports the latest Wi-Fi 6 technology for a stronger, more reliable connection. It also integrates seamlessly with Alexa and Google Assistant, allowing voice control and smart home automation.
Multiple Mounting Options and Weatherproof Design
The camera’s compact polycarbonate body is IP65 rated for outdoor use and can be mounted on walls, ceilings, or with magnetic mounts for flexible installation.
Wyze MicroSD Card: Essential Storage for Continuous Recording
Unlock Full Potential of Wyze Cameras
The
Wyze MicroSD Card is designed specifically for Wyze cameras to enable
continuous local recording and time-lapse features. Available in 32GB, 128GB, and 256GB sizes, it offers scalable storage options based on your needs.
Easy Timeline and Calendar Controls
Manage your recordings effortlessly with timeline controls and calendar views, making it simple to find and review important footage.
Compatible with Wyze Cam Pan v3 and Wyze Cam v4
This microSD card works perfectly with both the Wyze Cam Pan v3 and Wyze Cam v4, ensuring you get the most out of your outdoor security setup.
Why Choose Wyze Outdoor Cameras with Power Adapter and MicroSD Card?
Wyze outdoor cameras combined with the right power adapter and microSD card provide a complete security solution that is weatherproof, reliable, and packed with smart features. Whether you want panoramic coverage with the Pan v3 or ultra-clear video with the Cam v4, Wyze has you covered.
Wyze Cam v4 installed outdoors, blending into natural surroundings while providing vigilant security.
Summary of Featured Products
Product | Key Features | Price Range |
Wyze Cam Pan v3 | 360° pan, 180° tilt, IP65 weatherproof, motion tracking, color night vision, two-way audio | $39.98+ |
Wyze Cam v4 + FREE 32GB MicroSD Card | 2.5K QHD, enhanced color night vision, spotlight, Wi-Fi 6, Alexa/Google compatible | $35.98+ |
Wyze MicroSD Card | Local continuous recording, time lapse, multiple sizes (32GB, 128GB, 256GB) | $8.99+ |
Secure your outdoor spaces with Wyze’s advanced cameras, power adapters, and microSD cards — the perfect combination for reliable, high-quality home security.
What is the Wyze Cam Pan v3 and is it suitable for outdoor use?
The Wyze Cam Pan v3 is a weather-resistant, IP65-rated security camera designed for outdoor environments. It offers 360° pan and 180° tilt coverage, making it ideal for monitoring large outdoor spaces in any weather conditions.Does the Wyze Cam Pan v3 require a special power adapter for outdoor installation?
Yes, for safe and continuous outdoor use, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter with an L-shaped MicroUSB, which is sold separately. This ensures reliable power supply in all weather conditions.What are the key features of the Wyze Cam Pan v3 outdoor security camera?
The Wyze Cam Pan v3 features 360° pan, 180° tilt, IP65 weatherproof design, motion tracking, color night vision with a Starlight Sensor, two-way audio, and a privacy mode for enhanced security and convenience.What is included with the Wyze Cam v4 outdoor camera bundle?
The Wyze Cam v4 outdoor camera bundle includes the camera itself and a free 32GB MicroSD card, allowing for continuous 24/7 local recording without relying solely on cloud storage.What makes the Wyze Cam v4 a good choice for outdoor security?
The Wyze Cam v4 offers 2.5K Quad HD resolution for crystal-clear video, enhanced color night vision with a motion-activated spotlight, Wi-Fi 6 support for a strong connection, and smart home integration with Alexa and Google Assistant.Can I use a Wyze MicroSD card with both Wyze Cam Pan v3 and Wyze Cam v4?
Yes, the Wyze MicroSD card is fully compatible with both the Wyze Cam Pan v3 and Wyze Cam v4, enabling continuous local recording and time-lapse features.What storage options are available for Wyze MicroSD cards?
Wyze MicroSD cards are available in 32GB, 128GB, and 256GB sizes, allowing you to choose the storage capacity that best fits your recording needs.How does color night vision work on Wyze outdoor cameras?
Wyze outdoor cameras like the Cam Pan v3 and Cam v4 use advanced sensors and, in the case of the Cam v4, a motion-activated spotlight to provide vibrant, full-color night vision, offering clearer and more detailed images in low-light conditions.Are Wyze outdoor cameras compatible with smart home systems?
Yes, Wyze outdoor cameras such as the Cam v4 integrate seamlessly with Alexa and Google Assistant, allowing for voice control and smart home automation.Why should I choose a Wyze outdoor camera bundle with a power adapter and microSD card?
Choosing a Wyze outdoor camera bundle with a power adapter and microSD card provides a complete, weatherproof security solution with reliable power, continuous local recording, and advanced smart features for comprehensive home protection.
