For those looking to optimize camera audio detection while mounted behind a window, the Wyze Window Mount is a great accessory. This mount allows you to attach your Wyze Cam v3, Cam v3 Pro, Cam v4, Wyze Cam OG, or Wyze Cam OG Telephoto to a glass surface, providing a clear view free of glare or reflection. Here are some key features:
- Compatibility: Works with Wyze Cam v3, Cam v3 Pro, Cam v4, and the Wyze Cam OG series.
- Glare Reduction: Ensures a clear view by minimizing glare and reflections on the glass.
- Enhanced Security: Improves exterior security by allowing you to mount your camera on a window.
- Easy Installation: Simple to set up, making it convenient to enhance your camera's performance.
By using the Wyze Window Mount, you can maintain optimal audio detection and visual clarity, ensuring your security camera performs effectively even when mounted behind a window.
