No Contract Fully Monitored Home Security with Wyze Cameras
Experience peace of mind with Wyze’s no-contract, fully monitored home security system. Designed for easy installation and seamless integration, Wyze offers a comprehensive suite of smart home monitoring devices that work together to keep your home safe and secure without the hassle of long-term contracts. Whether you want to detect motion, monitor entry points, or get alerts for leaks, Wyze’s home monitoring ecosystem has you covered.
The Heart of Your Security: Wyze Sense Hub
At the core of Wyze’s home monitoring system is the Wyze Sense Hub, the essential brain that connects all your sensors and devices. This compact, sleek hub communicates with sensors up to 500 feet away, ensuring reliable coverage throughout your home.
  • Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication.
  • Battery Backup: Built-in rechargeable battery with up to 10 hours of backup power.
  • Siren: Loud 88db siren to alert you and deter intruders.
  • Capacity: Supports up to 100 sensors for scalable home security.
  • Dimensions: Compact 4.5” x 4” x 1” size fits discreetly anywhere indoors.
This hub is indispensable for a fully monitored system, sending instant alerts to your phone and enabling remote control of your security devices.
Essential Sensors for Complete Home Monitoring
Wyze Sense Motion Sensor
Detect movement with precision using the Wyze Sense Motion Sensor. Perfect for monitoring hallways, entryways, or any room where motion detection is critical.
  • Detection Range: Up to 25 feet with a 120° field of view.
  • Smart Sensitivity: Adjustable settings to avoid false alarms from pets.
  • Easy Installation: Adhesive backing or screws for secure mounting.
  • Requirement: Works with Wyze Sense Hub or Wyze Home Monitoring.
Wyze Sense Entry Sensor
Keep track of doors, windows, and cabinets with the Wyze Sense Entry Sensor. Receive instant notifications whenever an entry point is opened or closed.
  • Multi-Pack: Available in 3-packs for comprehensive coverage.
  • Compatibility: Requires Wyze Sense Hub or Wyze Home Monitoring.
  • Installation: Simple peel-and-stick or screw mounting options.
Protect your home from water damage with the Wyze Sense Leak Sensor & Probe. Detect leaks early and get notified immediately to prevent costly repairs.
  • Sensor Range: Up to 500 feet from the hub.
  • Indoor Use: Designed for basements, kitchens, bathrooms, and laundry rooms.
  • Compatibility: Works with Wyze Sense v2 or Wyze Home Monitoring.
Wyze Sense Climate Sensor
Monitor temperature and humidity levels throughout your home to maintain comfort and prevent mold or damage.
  • Range: Communicates up to 500 feet from the hub.
  • Battery Life: Long-lasting CR2032 battery with up to 1.5 years of use.
  • Discreet Design: Sleek white matte finish blends into any room.
  • Mounting: Adhesive or optional screws for flexible placement.
Convenient Control with Wyze Sense Keypad
Take control of your home security system with the Wyze Sense Keypad. This handy device allows you to arm or disarm your system quickly without needing to use your phone.
  • Remote Disarm: Control your security system from anywhere.
  • Emergency Button: Instantly send alerts to first responders.
  • Placement: Portable and easy to place anywhere in your home.
  • Requirement: Must be used with Wyze Home Monitoring and Sense Hub.
Why Choose Wyze for Your No Contract Home Security?
Wyze offers a flexible, no-contract home security solution that is fully monitored and easy to customize. With affordable pricing and a wide range of sensors, you can build a system tailored to your home’s unique needs. The integration of smart sensors, a powerful hub, and convenient keypad control ensures you stay connected and protected 24/7.
Benefits at a Glance:
  • No long-term contracts or hidden fees.
  • Real-time alerts and monitoring via the Wyze app.
  • Scalable system supporting up to 100 sensors.
  • Easy DIY installation with adhesive or screws.
  • Compatible with Wyze cameras for video surveillance integration.
Wyze Home Security Lifestyle Secure your home effortlessly with Wyze smart cameras and sensors.
Enhance Your Security with Wyze Cameras
While this page focuses on Wyze’s fully monitored sensors and keypad system, pairing these devices with Wyze’s smart cameras creates a robust security network. Wyze cameras offer live video streaming, motion detection, and cloud storage options, complementing the sensor alerts for a comprehensive home security experience.
Summary of Wyze Home Monitoring Products
ProductKey FeaturesPrice (Approx.)
Wyze Sense HubCentral hub, 500 ft range, siren$45.98
Wyze Sense Motion SensorMotion detection, pet-friendly settings$20.98
Wyze Sense Entry SensorDetects open/close of doors/windows$41.98 (3-pack)
Wyze Sense Leak SensorLeak detection with probe$13.98+
Wyze Sense Climate SensorTemperature & humidity monitoring$41.98 (3-pack)
Wyze Sense KeypadRemote arm/disarm, emergency button$27.98
Secure your home today with Wyze’s no-contract, fully monitored home security system — smart, affordable, and designed for your peace of mind. Wyze Keypad Control Control your home security easily with the Wyze Sense Keypad.
FeatureWyze Sense HubWyze Sense Motion SensorWyze Sense Entry SensorWyze Sense KeypadWyze Sense Leak Sensor & Probe
DescriptionConnects monitoring components and sends alerts. Core of Wyze Home Monitoring System.Detects motion up to 25 ft within 120° FOV.Detects when things open/close.Disarm home security remotely.Notifies of leaks.
RequiresNoneWyze Sense HubWyze Sense HubWyze Sense HubWyze Sense Hub
CompatibilityWyze Home Monitoring SystemWyze Sense v2 or Wyze Home MonitoringWyze Sense v2 or Wyze Home MonitoringWyze Home MonitoringWyze Sense v2 or Wyze Home Monitoring
Standalone FunctionalityYesNoNoNoNo
Detection TypeN/AMotionOpen/CloseN/ALeak detection
InstallationN/AAdhesive back or screwsN/APermanent adhesiveIndoor use only, probe sensors
Indoor/Outdoor UseIndoorIndoorIndoorIndoorIndoor only
Price (USD)$45.98$20.98 (1 Pack)$41.98 (3 Pack)$27.98$13.98 (2 Probes), $55.98 (3 Sensors + 1 Probe)
Additional FeaturesCentral hub for alertsAdjustable sensitivity, pet-friendly modeDetects open/close statusArm/disarm system, emergency buttonOperating temp: 32-104°F, humidity ≤85%
What is Wyze's no-contract fully monitored home security system?Wyze offers a fully monitored home security system that does not require any long-term contracts or hidden fees. The system is easy to install, customizable, and provides real-time alerts and monitoring through the Wyze app, giving you peace of mind without the hassle of traditional security contracts.
How does the Wyze Sense Hub work in the home security system?The Wyze Sense Hub is the central component of the Wyze home security system. It connects all your sensors and devices, supports up to 100 sensors, and communicates with them up to 500 feet away. The hub features Ethernet, WiFi, Bluetooth, and RF connectivity, a built-in 10-hour battery backup, and an 88db siren to alert you and deter intruders.
What types of sensors are included in the Wyze home monitoring system?Wyze's home monitoring system includes several types of sensors: the Wyze Sense Motion Sensor for detecting movement, the Wyze Sense Entry Sensor for monitoring doors and windows, the Wyze Sense Leak Sensor & Probe for detecting water leaks, and the Wyze Sense Climate Sensor for monitoring temperature and humidity.
How do I install Wyze home security sensors?Wyze sensors are designed for easy DIY installation. Most sensors come with adhesive backing for peel-and-stick mounting or optional screws for a more secure installation. The process is simple and does not require professional assistance.
Can I monitor my Wyze home security system remotely?Yes, you can monitor your Wyze home security system remotely using the Wyze app. The system sends instant alerts to your phone, allowing you to stay connected and control your security devices from anywhere.
Is the Wyze home security system compatible with Wyze cameras?Yes, the Wyze home security system is compatible with Wyze cameras. Integrating cameras with your sensors and hub provides live video streaming, motion detection, and cloud storage, creating a comprehensive home security solution.
What is the Wyze Sense Keypad and how does it work?The Wyze Sense Keypad is a portable device that allows you to arm or disarm your home security system without using your phone. It features an emergency button to instantly alert first responders and must be used with the Wyze Home Monitoring system and Sense Hub.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors, making it easy to scale your home security system to fit homes of any size.
Does the Wyze home security system have a battery backup?Yes, the Wyze Sense Hub includes a built-in rechargeable battery that provides up to 10 hours of backup power in case of an outage, ensuring your home remains protected.
What are the benefits of choosing Wyze for home security?Wyze offers a flexible, affordable, and fully monitored home security solution with no long-term contracts. The system is easy to install, supports real-time alerts, is scalable up to 100 sensors, and integrates seamlessly with Wyze cameras for enhanced security.
Where can I use the Wyze Sense Leak Sensor?The Wyze Sense Leak Sensor is designed for indoor use and is ideal for areas prone to water leaks, such as basements, kitchens, bathrooms, and laundry rooms. It can detect leaks up to 500 feet from the hub and sends instant notifications to your phone.
How long does the battery last in the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor uses a CR2032 battery that can last up to 1.5 years, providing long-term monitoring of temperature and humidity in your home.
What features does the Wyze Sense Keypad offer for home security control?How does the Wyze Sense Hub connect with other sensors in the system?Do you have any deals, ongoing sales, discounts, or promotions available?
