For those looking to enhance their home security by mounting a camera behind glass, we recommend the Wyze Window Mount. This accessory is perfect for attaching a Wyze Cam v3, Cam v3 Pro, Cam v4, Wyze Cam OG, or Wyze Cam OG Telephoto to your window, providing a clear view free of glare or reflection. Here are some key features:
- Compatibility: Works with Wyze Cam v3, Cam v3 Pro, Cam v4, Wyze Cam OG, and Wyze Cam OG Telephoto.
- Clear View: Designed to minimize glare and reflection, ensuring a clear view through glass.
- Easy Installation: Simply attach the mount to your window for a secure setup.
Additionally, if you're looking for more versatile mounting options, consider the Wyze Universal Mount (Long) and the Wyze Cam Mounting Kit:
- Wyze Universal Mount (Long):
- Versatile Applications: Suitable for ceiling or patio mounting.
- Durable Design: Made from heavy-duty metal for long-lasting use.
- Adjustable Angle: Allows for flexible positioning of your camera.
- Wyze Cam Mounting Kit:
- Includes Essentials: Comes with a mounting bracket, adhesive, and a longer Micro USB cable.
- Compatibility: Specifically designed for Wyze Cam v2, v3, and v3 Pro.
These accessories will help you set up your security cameras effectively, ensuring optimal coverage and performance.
