For those interested in enhancing their home security with motion detection, the Wyze Sense Motion Sensor is an excellent choice. Here are some key features of the Wyze Sense Motion Sensor:
- Motion Detection: Detects motion up to 25 feet away within a 120° field of view, making it ideal for monitoring activity in various areas of your home.
- Adjustable Sensitivity: Customize the sensitivity settings to suit your needs, with options for "large pet installation" to avoid false alarms from pets.
- Easy Installation: Comes with an adhesive back for simple wall mounting, with the option to use screws for added security.
- Requires Wyze Sense Hub: Please note that the Wyze Sense Motion Sensor requires a Wyze Sense Hub to function and is not compatible with Wyze Sense v1.
- Indoor Use: Designed for indoor use only, ensuring optimal performance in a controlled environment.
- Long Battery Life: Offers up to 18 months of battery life, providing long-term reliability.
The Wyze Sense Motion Sensor is an ideal choice for those seeking to monitor movement within their home, providing peace of mind and enhanced security.
