Wyze Cam v4 Cloud Storage: Monthly Fee & Optional Subscription
Wyze Cam v4 Cloud Storage Monthly Fee and Optionality
Wyze Cam v4 offers flexible cloud storage options designed to fit your security needs. While the camera supports local storage via microSD card for continuous 24/7 recording without any subscription fees, cloud storage is available as an optional service to enhance your monitoring experience.
Is Cloud Storage Optional for Wyze Cam v4?
Yes, cloud storage is completely optional for Wyze Cam v4. You can use the camera with local storage alone by inserting a microSD card (up to 512GB supported) to record continuously without any monthly fees. This means you can have full video access without subscribing to any cloud plan.
However, if you want advanced features like person, package, vehicle detection, AI-based sound detection, and longer event video storage in the cloud, Wyze offers a subscription plan called
Cam Plus.
Cam Plus Subscription Details
- Free Trial: Wyze provides a 30-day free trial of Cam Plus with the purchase of Wyze Cam v4 Outdoor Bundle.
- Monthly Fee: After the trial, Cam Plus auto-renews at $2.99 per month per camera.
- Features Included: Unlimited event video cloud storage, smart detections (person, pet, package, vehicle), and faster notification speeds.
- No Commitment: You can cancel anytime without penalties.
- Compatibility: Cam Plus is optional and not required for basic camera operation or local recording.
Using Cam Plus enhances your security by providing AI-powered alerts and cloud backup, but it is not mandatory to use Wyze Cam v4 effectively.
Wyze Cam v4 Product Overview
Wyze Cam v4 is the clearest and most advanced Wyze camera yet, designed for both indoor and outdoor use with robust features that ensure your home stays safe day and night.
Key Features
- 2.5K Quad High Definition (QHD) Resolution: Capture crystal-clear video with 2560x1440 resolution for detailed monitoring.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, surpassing traditional black-and-white night vision.
- Wide Dynamic Range (WDR): Enjoy richer colors and better image quality in challenging lighting environments.
- IP65 Weather Resistance: Durable for outdoor use, able to withstand rain, snow, and dust.
- Motion-Activated Spotlight & 99dB Siren: Deter intruders with a bright spotlight and loud siren.
- Advanced Two-Way Talk: Clearer conversations with improved audio hardware and noise cancellation.
- Wi-Fi 6 Support: Maintain a stronger, more reliable connection with compatible routers.
- Smart Detection & Alerts: Motion, sound, smoke, and CO alarm alerts sent directly to your phone.
- Local Storage: Supports microSD cards up to 512GB for continuous 24/7 recording without subscription.
- Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Technical Specs
- Dimensions: 2in x 2in x 2 3/8in
- Weight: 0.49 lb (222 g)
- Field of View: 115.8° diagonal, 98.5° horizontal, 53.1° vertical
- Video Encoding: H.264
- Video FPS: 20 FPS daytime, 15 FPS nighttime
- Power: Wired with 6-foot micro USB cable
- Operating Temperature: -4ºF to 122ºF (-20ºC to 50ºC)
- Warranty: 1 Year
Wyze Cam v4 providing clear night vision and outdoor security
For those looking for a complete outdoor security solution, the Wyze Cam v4 Outdoor Bundle offers everything you need to get started with enhanced convenience.
Bundle Includes
- Wyze Cam v4 camera (available in Black, Grey, or White)
- Wyze Outdoor Power Adapter for weatherproof power supply
- 128GB Wyze MicroSD Card for local continuous recording
Benefits of the Outdoor Bundle
- Ready for outdoor installation with IP65 weather resistance.
- Continuous 24/7 local recording with included microSD card.
- Supports Wi-Fi 6 for reliable connectivity.
- Compatible with Alexa and Google Assistant for voice control.
- Motion-activated spotlight and siren for added security.
- Free 30-day trial of Cam Plus subscription included.
After the free trial, Cam Plus subscription renews at $2.99/month per camera but remains optional.
Wyze Cam v4 mounted outdoors for home security
Additional Wyze Cam v4 Options and Bundles
- Priced at $169.99, this bundle offers multiple cameras and accessories for comprehensive home security.
- Features include 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, and 128GB microSD card.
- Supports indoor and outdoor use with IP65 rating.
- Includes advanced person detection and smart alerts.
- Ideal for users wanting a multi-camera setup with local storage and optional cloud features.
Wyze Cam v4 + FREE 32GB MicroSD Card
- A budget-friendly option priced at $35.98.
- Includes Wyze Cam v4 with a free 32GB microSD card for local recording.
- Supports all core features: 2.5K QHD, color night vision, motion-activated spotlight, and Wi-Fi 6.
- Cloud storage remains optional with Cam Plus subscription.
Summary: Wyze Cam v4 Cloud Storage and Fees
Feature | Details |
Local Storage | Supported via microSD card (up to 512GB) |
Cloud Storage | Optional with Cam Plus subscription |
Cam Plus Monthly Fee | $2.99 per camera after 30-day free trial |
Cloud Storage Benefits | Unlimited event video storage, AI alerts |
Subscription Commitment | None, cancel anytime |
Basic Camera Use | No subscription required |
Wyze Cam v4 offers a flexible security solution where you can rely solely on local storage with no monthly fees or enhance your experience with affordable cloud storage and smart detection features.
Protect your home with Wyze Cam v4 — the smart, clear, and customizable security camera that fits your lifestyle and budget.
Feature | Wyze Cam v4 (Standalone) | Wyze Cam v4 Outdoor Bundle | Wyze Cam v4 + FREE 32GB MicroSD Card | Wyze Cam v4 Home Security Bundle |
Price | $100.00 | $69.99 | $35.98 | $169.99 |
Resolution | 2.5K QHD (2560x1440) | 2.5K QHD (2560x1440) | 2.5K QHD | 2.5K QHD (2560x1440) |
Color Night Vision | Yes | Yes | Yes | Yes |
Night Vision Type | B&W + Enhanced Color Night Vision | B&W + Enhanced Color Night Vision | B&W + Enhanced Color Night Vision | B&W + Enhanced Color Night Vision |
Motion-Activated Spotlight | Yes | Yes | Yes | Yes |
Weather Resistance | IP65 | IP65 | IP65 | IP65 |
Wi-Fi Support | 2.4 GHz Wi-Fi, Wi-Fi 6 | 2.4 GHz Wi-Fi, Wi-Fi 6 | Wi-Fi 6 | 2.4 GHz Wi-Fi, Wi-Fi 6 |
Continuous Local Recording | microSD card up to 512GB (sold separately) | microSD card up to 512GB + 128GB included | microSD card up to 512GB + 32GB included | microSD card up to 512GB + 128GB included |
MicroSD Card Included | No | Yes (128GB) | Yes (32GB) | Yes (128GB) |
Two-Way Talk | Yes | Yes | Yes | Improved 2-way audio |
Siren | Yes (99 dB) | Yes | Yes | Yes |
Smart Detection (Subscription) | Yes (with subscription) | Yes (with subscription) | Yes (with subscription) | Yes (with subscription) |
Motion Detection Zones | Yes | Yes | Yes | Yes |
Smoke & CO Alerts | Yes | Yes | Yes | Yes |
AI Auto-Zoom & Smart Focus | Yes | Yes | Yes | Yes |
Mounting Options | Stand, Wall, Ceiling, Magnetic | Stand, Wall, Ceiling, Magnetic | Stand, Wall, Ceiling, Magnetic | Stand, Wall, Ceiling, Magnetic |
Power | Wired (requires power adapter) | Wired + Outdoor Power Adapter | Wired (requires power adapter) | Wired (requires power adapter) |
Included Accessories | None | Outdoor Power Adapter + 128GB microSD | 32GB microSD Card | 128GB microSD Card |
Dimensions | 2in x 2in x 2 3/8in | Same as standalone | Same as standalone | Same as standalone |
Weight | 0.49 lb (222 g) | Same as standalone | Same as standalone | Same as standalone |
Warranty | 1 Year | 1 Year | 1 Year | 1 Year |
Is cloud storage required for Wyze Cam v4?
No, cloud storage is completely optional for Wyze Cam v4. You can use the camera with local storage by inserting a microSD card (up to 512GB supported) for continuous 24/7 recording without any monthly fees.How much does Wyze Cam v4 cloud storage cost?
Wyze Cam v4 offers an optional Cam Plus subscription for cloud storage at $2.99 per month per camera after a 30-day free trial. The subscription can be canceled anytime without penalties.What features are included with the Cam Plus subscription for Wyze Cam v4?
The Cam Plus subscription for Wyze Cam v4 includes unlimited event video cloud storage, smart detections such as person, pet, package, and vehicle detection, AI-based sound detection, and faster notification speeds.Can I use Wyze Cam v4 without a subscription?
Yes, you can use Wyze Cam v4 without any subscription. The camera supports local storage via microSD card for continuous recording and basic features without any monthly fees.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera (available in Black, Grey, or White), a Wyze Outdoor Power Adapter for weatherproof power supply, and a 128GB Wyze MicroSD Card for local continuous recording. It also comes with a free 30-day trial of Cam Plus.What are the key features of Wyze Cam v4?
Wyze Cam v4 features 2.5K Quad High Definition (QHD) resolution, enhanced color night vision, wide dynamic range (WDR), IP65 weather resistance, motion-activated spotlight, 99dB siren, advanced two-way talk, Wi-Fi 6 support, smart detection and alerts, local storage up to 512GB, and smart home integration with Alexa, Google Assistant, and IFTTT.Does Wyze Cam v4 support local storage?
Yes, Wyze Cam v4 supports local storage via microSD cards up to 512GB, allowing for continuous 24/7 recording without any subscription fees.What is the warranty period for Wyze Cam v4?
Wyze Cam v4 comes with a 1-year warranty.Is Wyze Cam v4 suitable for outdoor use?
Yes, Wyze Cam v4 is designed for both indoor and outdoor use, featuring IP65 weather resistance to withstand rain, snow, and dust.What smart home platforms are compatible with Wyze Cam v4?
Wyze Cam v4 works seamlessly with Alexa, Google Assistant, and IFTTT for smart home integration and voice control.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes multiple cameras and accessories, 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, a 128GB microSD card, and advanced person detection and smart alerts. It is ideal for comprehensive home security with local storage and optional cloud features.Does Wyze Cam v4 support Wi-Fi 6?
Yes, Wyze Cam v4 supports Wi-Fi 6 for a stronger and more reliable connection with compatible routers.What is the price of the Wyze Cam v4 + FREE 32GB MicroSD Card bundle?
The Wyze Cam v4 + FREE 32GB MicroSD Card bundle is priced at $35.98 and includes the camera with a free 32GB microSD card for local recording.
Can you explain the benefits of using the Cam Plus subscription with Wyze Cam v4?What features are included in the Wyze Cam v4 Outdoor Bundle?How does the local storage option work with the Wyze Cam v4?
