Maintain Privacy While Monitoring Outdoors with Wyze Window Mount for Bedroom Windows
Enhance your home security while maintaining privacy with the Wyze Window Mount. This accessory allows you to attach your Wyze Cam v3, v3 Pro, v4, or the Wyze Cam OG series to a window, providing a clear view without glare or reflection. It's perfect for discreetly monitoring the outside from the comfort of your bedroom. The Wyze Window Mount is available in style v2, which is compatible with a wide range of Wyze cameras and is currently in stock. Wyze Window Mount: Reduces glare, mounts on glass surfaces, provides a clear view free of glare or reflection.
Can the Wyze Window Mount be used with other Wyze camera models?What are the benefits of using the Wyze Window Mount for outdoor monitoring?Is the Wyze Window Mount easy to install on a window?
