Lowest Price Waterproof RGB LED Curtain Lights for Indoors & Outdoors
Lowest Price Waterproof RGB LED Curtain Lights for Indoor & Outdoor Use
When searching for affordable, vibrant, and waterproof RGB LED curtain lights suitable for both indoor and outdoor settings, it’s essential to focus on products that combine durability, color customization, and smart control features. While Wyze offers a range of connected home lighting solutions, the closest match to waterproof RGB LED curtain lights is the Wyze Light Strip. Although it is designed for indoor use only and not waterproof, it offers brilliant RGB lighting at a low price. For true waterproof outdoor lighting, Wyze’s outdoor-rated smart devices like the Wyze Cam Pan v3 provide weather resistance but are security cameras rather than decorative lights. Below, we highlight the best Wyze products related to LED lighting and outdoor smart lighting, focusing on affordability, features, and usability.
Wyze Light Strip: Brilliant RGB Accent Lighting for Indoors
Vibrant Color Options & Customization
  • Available in 16.4 feet and 32.8 feet lengths, perfect for accentuating rooms, cabinets, or entertainment areas.
  • Offers 16 million colors to create any ambiance or mood.
  • Customizable zones for precise lighting control.
  • Music sync feature using a built-in microphone to pulse lights to your favorite tunes.
Easy Installation & Control
  • Adhesive backing for simple mounting on various surfaces.
  • Cuttable design allows you to tailor the length to your space.
  • Controlled via the Wyze app with Wi-Fi and Bluetooth connectivity.
  • Compatible with voice assistants for hands-free operation.
Specifications
  • Power: Corded electric with 12V adapter.
  • Wattage: 18 watts (16.4 ft) and 36 watts (32.8 ft).
  • Operating temperature: -4°F to 122°F (-20°C to 50°C).
  • Life expectancy: 25,000 hours.
  • Indoor use only (not waterproof).
While the Wyze Light Strip is not waterproof, it is the most affordable RGB LED lighting option from Wyze for indoor use, offering extensive color options and smart control.
Wyze Light Strip in Living Room Alt text: Wyze Light Strip installed behind sofa creating colorful ambient lighting in living room
Wyze Switch: Smart Control for Your Lighting Setup
Transform Your Existing Lights into Smart Lights
  • Control your lights remotely via the Wyze app.
  • Multi-tap functionality to control other Wyze devices like cameras and vacuums.
  • Set timers, schedules, and custom actions for convenience.
  • Vacation mode to simulate occupancy when away.
Affordable & Versatile
  • Available in 1-pack and 3-pack options.
  • Priced competitively to upgrade your home lighting without replacing fixtures.
  • Integrates seamlessly with the Wyze ecosystem for a connected smart home experience.
The Wyze Switch is ideal for controlling your LED lights, including light strips, but does not provide lighting itself.
Wyze Switch in Kitchen Alt text: Wyze Switch installed in kitchen wall with smart home voice assistant
Outdoor Smart Lighting & Security: Wyze Cam Pan v3
Weather-Resistant Outdoor Camera with Smart Lighting Features
  • IP65-rated for dust and water resistance, suitable for outdoor use.
  • 360° horizontal and 180° vertical pan with 1080p HD video.
  • Color night vision and motion-activated lighting.
  • Requires Wyze Outdoor Power Adapter (sold separately) for safe outdoor power.
Smart Home Integration
  • Works with Alexa, Google Assistant, and IFTTT.
  • Push notifications and two-way audio for security and communication.
  • Can be paired with Wyze Lamp Socket v2 for enhanced lighting control.
While not a curtain light, the Wyze Cam Pan v3 offers smart outdoor lighting and security in one device, perfect for enhancing your outdoor ambiance and safety.
Wyze Cam Pan v3 Outdoor Alt text: Wyze Cam Pan v3 mounted outdoors monitoring home security
Summary: Best Options for Waterproof RGB LED Curtain Lights
  • For indoor RGB LED lighting at the lowest price: Wyze Light Strip offers vibrant colors and smart control but is not waterproof.
  • For outdoor waterproof smart lighting: Wyze Cam Pan v3 provides weather-resistant lighting with security features but is not a decorative curtain light.
  • Smart control upgrade: Wyze Switch allows you to control your lighting setup remotely and automate your home lighting.
If you need true waterproof RGB LED curtain lights specifically for outdoor use, consider pairing Wyze smart switches with other waterproof LED curtain lights from specialized lighting brands, as Wyze currently does not offer waterproof RGB curtain lights.
Feature / ProductWyze Light StripWyze SwitchWyze Cam Pan v3 + 30-Day Cam Plus Bundle
TypeConnected HomeConnected HomeCameras
Price16.4 ft: $19.99 (Sold out)
32.8 ft: $35.99 (Sold out)
1 Pack: $14.99 (Sold out)
3 Pack: $41.98 (Sold out)
$39.98
DescriptionBrilliant LED accent lighting with 16 million colors, peel & stick installation, Music Mode, Sun Match, voice control, vacation mode, sleep routines, timers & automationsTurns normal lights into smart lights, multi-tap controls for other Wyze devices, voice control, timers, schedules, vacation mode, power loss recoveryRedesigned indoor/outdoor 360° pan and 180° tilt security camera, IP65 weather resistant, includes 30-Day Cam Plus subscription
Color Options16 million colorsN/ABlack, White
ConnectivityWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHzWi-Fi 2.4 GHz (5 GHz not supported)
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Special FeaturesMusic Mode with built-in mic, Sun Match, Vacation Mode, Sleep RoutinesMulti-tap for controlling Wyze devices, Smart Control for Wyze Bulbs, Vacation Mode, Power Loss Recovery360° pan, 180° tilt, 1080p video, color night vision, 2-way audio, built-in siren, noise & echo cancellation
Power SourceCorded ElectricWired switchPower adapter (5V/2000mA) included
DimensionsNot specifiedNot specified124mm (H) x 60mm (W) x 63mm (D)
WeightNot specifiedNot specified11.29 oz (320 g)
InstallationPeel, stick, and plug inEasy to install light switchMounting kit included (screw mount)
WarrantyNot specifiedNot specified1-Year
Included ItemsWyze Light Strip, power adapter, controller, adhesive clips, quick start guideWyze Switch, quick start guideWyze Cam Pan v3, 6' micro USB cable, power adapter, mounting kit, quick start guide
UsageIndoor accent lightingSmart light switch for home lightingIndoor/outdoor security camera
Are Wyze Light Strips waterproof and suitable for outdoor use?No, Wyze Light Strips are designed for indoor use only and are not waterproof. They offer vibrant RGB lighting and smart control features but should not be used outdoors or in wet environments.
What are the best Wyze products for affordable indoor RGB LED lighting?The Wyze Light Strip is the most affordable RGB LED lighting option from Wyze for indoor use. It offers 16 million colors, customizable zones, music sync, and smart control via the Wyze app and voice assistants.
Can I control Wyze Light Strips with my smartphone or voice assistant?Yes, Wyze Light Strips can be controlled through the Wyze app using Wi-Fi and Bluetooth connectivity. They are also compatible with popular voice assistants for hands-free operation.
Is there a Wyze product for waterproof outdoor smart lighting?While Wyze does not offer waterproof RGB LED curtain lights, the Wyze Cam Pan v3 is an IP65-rated, weather-resistant outdoor camera with smart lighting features. However, it is primarily a security camera, not a decorative light.
How can I make my existing lights smart with Wyze products?You can use the Wyze Switch to transform your existing lights into smart lights. The Wyze Switch allows remote control, scheduling, and integration with other Wyze devices through the Wyze app.
What is the length and power specification of Wyze Light Strips?Wyze Light Strips are available in 16.4 feet and 32.8 feet lengths. The 16.4 ft strip uses 18 watts, while the 32.8 ft strip uses 36 watts, both powered by a 12V adapter.
Does Wyze offer waterproof RGB LED curtain lights?No, Wyze currently does not offer waterproof RGB LED curtain lights. For outdoor waterproof decorative lighting, consider pairing Wyze smart switches with waterproof LED curtain lights from specialized lighting brands.
What smart features does the Wyze Cam Pan v3 offer for outdoor lighting?The Wyze Cam Pan v3 features IP65 weather resistance, 360° pan, 1080p HD video, color night vision, motion-activated lighting, and integration with Alexa, Google Assistant, and IFTTT. It can also be paired with the Wyze Lamp Socket v2 for enhanced lighting control.
Can the Wyze Switch control other Wyze devices besides lights?Yes, the Wyze Switch features multi-tap functionality, allowing you to control other Wyze devices such as cameras and vacuums, in addition to your lighting setup.
What is the life expectancy of Wyze Light Strips?Wyze Light Strips have a life expectancy of 25,000 hours, making them a durable and long-lasting option for indoor accent lighting.
What are the features of the Wyze Light Strip for indoor use?Can the Wyze Switch be used to control the Wyze Light Strip?What is the warranty policy for Wyze products?
