For those looking to maintain a low-profile setup for their Wyze cameras outdoors, we recommend the Wyze Outdoor Power Adapter. Here’s why it’s a great choice:
- Weather Resistance: The adapter is IP67 weather-resistant, ensuring your Wyze Camera can withstand rain, snow, or shine.
- Compatibility: It works seamlessly with Wyze Cam v3, v3 Pro, v4, OG series, Pan v3, and Battery Cam Pro when paired with the appropriate adapters.
- Discreet Design: The white color and compact dimensions (78.7 mm x 62.5 mm x 29.4 mm) make it easy to blend into various outdoor settings.
- Long Cable: With a total cable length of 12.5 ft, you have the flexibility to position your camera where you need it most.
- Easy Installation: Comes with wire clips and screws for tidy cable management.
Additionally, the Wyze L-Shaped Micro USB Adapter can be used with the Wyze Outdoor Power Adapter to ensure compatibility with specific camera models like the Wyze Cam Pan v3 and Cam v3 Pro. This adapter allows for a more streamlined and discreet connection.
