For those seeking a long-range outdoor extension for their Wyze security camera, the Wyze Outdoor Power Adapter is a top recommendation. Here's why it stands out:
- Weather Resistance: The adapter is IP67 weather-resistant, ensuring it can withstand various weather conditions, including rain, snow, or shine.
- Compatibility: It works seamlessly with several Wyze camera models, such as Wyze Cam v3, Wyze Cam v4, OG series, Pan v3, and Battery Cam Pro.
- Cable Length: With a 12.5 ft (3.8 m) cable length, it provides ample reach for outdoor setups, making it ideal for backyard installations.
- Included Accessories: The package includes wire clips, screws, and a weatherproof L-shaped Micro-USB adapter to ensure a secure and weatherproof connection.
Additionally, for versatile mounting options, consider the Wyze Universal Mount (Long). It is designed for various applications, such as ceiling or patio installations, and is compatible with a range of Wyze cameras. This mount provides a durable and flexible solution for positioning your cameras effectively.
